1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: vga.c,v 2.9 2003/02/25 02:47:23 greg Exp $"; |
3 |
#endif |
4 |
5 |
* vga.c - driver for VGA graphics adaptor under MS-DOS |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <graph.h> |
11 |
12 |
#include "standard.h" |
13 |
#include "driver.h" |
14 |
#include "color.h" |
15 |
16 |
#define GAMMA 2.2 /* exponent for color correction */ |
17 |
18 |
19 |
static struct driver * vga_init(char *name, char *id); |
20 |
static void vga_errout(char *msg); |
21 |
static dr_newcolrf_t vgacolr; |
22 |
23 |
static dr_closef_t vga_close; |
24 |
static dr_clearf_t vga_clear; |
25 |
static dr_paintrf_t vga_paintr; |
26 |
static dr_comoutf_t vga_comout; |
27 |
static dr_cominf_t vga_comin; |
28 |
29 |
static struct driver vga_driver = { |
30 |
vga_close, vga_clear, vga_paintr, NULL, |
31 |
vga_comout, vga_comin, NULL, 1.0 |
32 |
33 |
34 |
static char fatalerr[128]; |
35 |
static struct videoconfig config; |
36 |
37 |
38 |
39 |
static struct driver * |
40 |
vga_init( /* open VGA */ |
41 |
char *name, |
42 |
char *id |
43 |
44 |
45 |
static short mode_pref[] = {_MRES256COLOR, -1}; |
46 |
static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR, |
47 |
_VRES256COLOR, _MRES256COLOR, -1}; |
48 |
char *ep; |
49 |
register short *mp; |
50 |
51 |
mp = !strcmp(name, "vga") ? mode_pref : smode_pref; |
52 |
for ( ; *mp != -1; mp++) |
53 |
if (_setvideomode(*mp)) |
54 |
break; |
55 |
if (*mp == -1) { |
56 |
_setvideomode(_DEFAULTMODE); |
57 |
eputs(name); |
58 |
eputs(": card not present or insufficient VGA memory\n"); |
59 |
return(NULL); |
60 |
61 |
_getvideoconfig(&config); |
62 |
_settextwindow(config.numtextrows-2, 1, |
63 |
config.numtextrows, config.numtextcols); |
64 |
vga_driver.xsiz = config.numxpixels; |
65 |
vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3) |
66 |
/config.numtextrows; |
67 |
switch (config.mode) { /* correct problems */ |
68 |
case _XRES256COLOR: |
69 |
vga_driver.ysiz -= 16; |
70 |
break; |
71 |
case _MRES256COLOR: |
72 |
vga_driver.pixaspect = 1.2; |
73 |
break; |
74 |
75 |
_setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz); |
76 |
if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */ |
77 |
make_gmap(atof(ep)); |
78 |
else |
79 |
make_gmap(GAMMA); |
80 |
_remappalette(1, _BRIGHTWHITE); |
81 |
_settextcolor(1); |
82 |
ms_gcinit(&vga_driver); |
83 |
erract[USER].pf = |
84 |
erract[SYSTEM].pf = |
85 |
erract[INTERNAL].pf = |
86 |
erract[CONSISTENCY].pf = vga_errout; |
87 |
erract[COMMAND].pf = vga_comout; |
88 |
if (erract[WARNING].pf != NULL) |
89 |
erract[WARNING].pf = vga_comout; |
90 |
return(&vga_driver); |
91 |
92 |
93 |
94 |
static void |
95 |
vga_close(void) /* close VGA */ |
96 |
97 |
ms_gcdone(&vga_driver); |
98 |
99 |
erract[USER].pf = /* reset error vector */ |
100 |
101 |
102 |
erract[CONSISTENCY].pf = eputs; |
103 |
erract[COMMAND].pf = NULL; |
104 |
105 |
erract[WARNING].pf = wputs; |
106 |
if (fatalerr[0]) |
107 |
eputs(fatalerr); /* repeat error message */ |
108 |
109 |
110 |
111 |
static void |
112 |
vga_clear( /* clear VGA */ |
113 |
int x, |
114 |
int y |
115 |
116 |
117 |
_clearscreen(_GCLEARSCREEN); |
118 |
new_ctab(config.numcolors-2); /* init color table */ |
119 |
120 |
121 |
122 |
static void |
123 |
vga_paintr( /* paint a rectangle */ |
124 |
COLOR col, |
125 |
int xmin, |
126 |
int ymin, |
127 |
int xmax, |
128 |
int ymax |
129 |
130 |
131 |
_setcolor(get_pixel(col, vgacolr)+2); |
132 |
_rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax, |
133 |
xmax-1, vga_driver.ysiz-1-ymin); |
134 |
vga_driver.inpready = kbhit(); |
135 |
136 |
137 |
138 |
static void |
139 |
vga_comout( /* put s to text output */ |
140 |
register char *s |
141 |
142 |
143 |
struct rccoord tpos; |
144 |
char buf[128]; |
145 |
register char *cp; |
146 |
147 |
for (cp = buf; ; s++) { |
148 |
switch (*s) { |
149 |
case '\b': |
150 |
case '\r': |
151 |
case '\0': |
152 |
if (cp > buf) { |
153 |
*cp = '\0'; |
154 |
_outtext(cp = buf); |
155 |
156 |
if (*s == '\0') |
157 |
break; |
158 |
tpos = _gettextposition(); |
159 |
_settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1); |
160 |
continue; |
161 |
default: |
162 |
*cp++ = *s; |
163 |
continue; |
164 |
165 |
return(0); |
166 |
167 |
fatalerr[0] = '\0'; |
168 |
169 |
170 |
171 |
static void |
172 |
vga_errout( |
173 |
register char *msg |
174 |
175 |
176 |
static char *fep = fatalerr; |
177 |
178 |
_outtext(msg); |
179 |
while (*msg) |
180 |
*fep++ = *msg++; |
181 |
*fep = '\0'; |
182 |
if (fep > fatalerr && fep[-1] == '\n') |
183 |
fep = fatalerr; |
184 |
185 |
186 |
187 |
static void |
188 |
vga_comin( /* get input line from console */ |
189 |
char *buf, |
190 |
char *prompt |
191 |
192 |
193 |
extern int getch(); |
194 |
195 |
if (prompt != NULL) |
196 |
_outtext(prompt); |
197 |
editline(buf, getch, vga_comout); |
198 |
199 |
200 |
201 |
202 |
static void |
203 |
vgacolr( /* enter a color into our table */ |
204 |
int index, |
205 |
int r, |
206 |
int g, |
207 |
int b |
208 |
209 |
210 |
register long cl; |
211 |
212 |
cl = (long)b<<14 & 0x3f0000L; |
213 |
cl |= g<<6 & 0x3f00; |
214 |
cl |= r>>2; |
215 |
_remappalette(index+2, cl); |
216 |
