--- ray/src/rt/vga.c 1992/09/22 11:42:17 2.1 +++ ray/src/rt/vga.c 1992/11/02 16:01:05 2.5 @@ -19,34 +19,64 @@ static char SCCSid[] = "$SunId$ LBL"; #define GAMMA 2.2 /* exponent for color correction */ -int vga_close(), vga_clear(), vga_paintr(), vga_comout(), vga_comin(); +int vga_close(), vga_clear(), vga_paintr(), vga_comout(), vga_errout(), + vga_comin(); static struct driver vga_driver = { vga_close, vga_clear, vga_paintr, NULL, - vga_comout, vga_comin, NULL + vga_comout, vga_comin, NULL, 1.0 }; +static char fatalerr[128]; + static struct videoconfig config; +extern char *getenv(); + struct driver * vga_init(name, id) /* open VGA */ char *name, *id; { - if (_setvideomode(_MRES256COLOR) == 0) + static short mode_pref[] = {_MRES256COLOR, -1}; + static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR, + _VRES256COLOR, _MRES256COLOR, -1}; + char *ep; + register short *mp; + + mp = !strcmp(name, "vga") ? mode_pref : smode_pref; + for ( ; *mp != -1; mp++) + if (_setvideomode(*mp)) + break; + if (*mp == -1) { + _setvideomode(_DEFAULTMODE); + stderr_v(name); + stderr_v(": card not present or insufficient VGA memory\n"); return(NULL); + } _getvideoconfig(&config); _settextwindow(config.numtextrows-2, 1, config.numtextrows, config.numtextcols); vga_driver.xsiz = config.numxpixels; - vga_driver.ysiz = config.numypixels*(config.numtextrows-3) + vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3) /config.numtextrows; - vga_driver.pixaspect = .75*config.numxpixels/config.numypixels; + switch (config.mode) { /* correct problems */ + case _XRES256COLOR: + vga_driver.ysiz -= 16; + break; + case _MRES256COLOR: + vga_driver.pixaspect = 1.2; + break; + } _setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz); - make_gmap(GAMMA); /* make color map */ - _remappalette(1, 0x303030L); + if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */ + make_gmap(atof(ep)); + else + make_gmap(GAMMA); + _remappalette(1, _BRIGHTWHITE); _settextcolor(1); - errvec = vga_comout; + ms_gcinit(&vga_driver); + errvec = vga_errout; cmdvec = vga_comout; if (wrnvec != NULL) wrnvec = vga_comout; @@ -57,11 +87,14 @@ char *name, *id; static vga_close() /* close VGA */ { - errvec = stderr_v; /* reset error vector */ + ms_gcdone(&vga_driver); + _setvideomode(_DEFAULTMODE); + errvec = stderr_v; /* reset error vectors */ cmdvec = NULL; if (wrnvec != NULL) wrnvec = stderr_v; - _setvideomode(_DEFAULTMODE); + if (fatalerr[0]) + stderr_v(fatalerr); /* repeat error message */ } @@ -108,7 +141,7 @@ register char *s; if (*s == '\0') break; tpos = _gettextposition(); - _settextposition(tpos.row, *s=='\r' ? 0 : tpos.col-1); + _settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1); continue; default: *cp++ = *s; @@ -116,6 +149,22 @@ register char *s; } return(0); } + fatalerr[0] = '\0'; +} + + +static +vga_errout(msg) +register char *msg; +{ + static char *fep = fatalerr; + + _outtext(msg); + while (*msg) + *fep++ = *msg++; + *fep = '\0'; + if (fep > fatalerr && fep[-1] == '\n') + fep = fatalerr; }
