| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: vga.c,v 2.9 2003/02/25 02:47:23 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* vga.c - driver for VGA graphics adaptor under MS-DOS
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <graph.h>
| 11 |
| 12 |
#include "standard.h"
| 13 |
#include "driver.h"
| 14 |
#include "color.h"
| 15 |
| 16 |
#define GAMMA 2.2 /* exponent for color correction */
| 17 |
| 18 |
| 19 |
static struct driver * vga_init(char *name, char *id);
| 20 |
static void vga_errout(char *msg);
| 21 |
static dr_newcolrf_t vgacolr;
| 22 |
| 23 |
static dr_closef_t vga_close;
| 24 |
static dr_clearf_t vga_clear;
| 25 |
static dr_paintrf_t vga_paintr;
| 26 |
static dr_comoutf_t vga_comout;
| 27 |
static dr_cominf_t vga_comin;
| 28 |
| 29 |
static struct driver vga_driver = {
| 30 |
vga_close, vga_clear, vga_paintr, NULL,
| 31 |
vga_comout, vga_comin, NULL, 1.0
| 32 |
| 33 |
| 34 |
static char fatalerr[128];
| 35 |
static struct videoconfig config;
| 36 |
| 37 |
| 38 |
| 39 |
| 40 |
vga_init( /* open VGA */
| 41 |
char *name,
| 42 |
char *id
| 43 |
| 44 |
| 45 |
static short mode_pref[] = {_MRES256COLOR, -1};
| 46 |
static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR,
| 47 |
_VRES256COLOR, _MRES256COLOR, -1};
| 48 |
char *ep;
| 49 |
register short *mp;
| 50 |
| 51 |
mp = !strcmp(name, "vga") ? mode_pref : smode_pref;
| 52 |
for ( ; *mp != -1; mp++)
| 53 |
if (_setvideomode(*mp))
| 54 |
break;
| 55 |
if (*mp == -1) {
| 56 |
_setvideomode(_DEFAULTMODE);
| 57 |
eputs(name);
| 58 |
eputs(": card not present or insufficient VGA memory\n");
| 59 |
return(NULL);
| 60 |
| 61 |
_getvideoconfig(&config);
| 62 |
_settextwindow(config.numtextrows-2, 1,
| 63 |
config.numtextrows, config.numtextcols);
| 64 |
vga_driver.xsiz = config.numxpixels;
| 65 |
vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3)
| 66 |
/config.numtextrows;
| 67 |
switch (config.mode) { /* correct problems */
| 68 |
case _XRES256COLOR:
| 69 |
vga_driver.ysiz -= 16;
| 70 |
break;
| 71 |
case _MRES256COLOR:
| 72 |
vga_driver.pixaspect = 1.2;
| 73 |
break;
| 74 |
| 75 |
_setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz);
| 76 |
if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */
| 77 |
make_gmap(atof(ep));
| 78 |
else
| 79 |
make_gmap(GAMMA);
| 80 |
_remappalette(1, _BRIGHTWHITE);
| 81 |
_settextcolor(1);
| 82 |
ms_gcinit(&vga_driver);
| 83 |
erract[USER].pf =
| 84 |
erract[SYSTEM].pf =
| 85 |
erract[INTERNAL].pf =
| 86 |
erract[CONSISTENCY].pf = vga_errout;
| 87 |
erract[COMMAND].pf = vga_comout;
| 88 |
if (erract[WARNING].pf != NULL)
| 89 |
erract[WARNING].pf = vga_comout;
| 90 |
return(&vga_driver);
| 91 |
| 92 |
| 93 |
| 94 |
static void
| 95 |
vga_close(void) /* close VGA */
| 96 |
| 97 |
ms_gcdone(&vga_driver);
| 98 |
| 99 |
erract[USER].pf = /* reset error vector */
| 100 |
erract[SYSTEM].pf =
| 101 |
| 102 |
erract[CONSISTENCY].pf = eputs;
| 103 |
erract[COMMAND].pf = NULL;
| 104 |
| 105 |
erract[WARNING].pf = wputs;
| 106 |
if (fatalerr[0])
| 107 |
eputs(fatalerr); /* repeat error message */
| 108 |
| 109 |
| 110 |
| 111 |
static void
| 112 |
vga_clear( /* clear VGA */
| 113 |
int x,
| 114 |
int y
| 115 |
| 116 |
| 117 |
_clearscreen(_GCLEARSCREEN);
| 118 |
new_ctab(config.numcolors-2); /* init color table */
| 119 |
| 120 |
| 121 |
| 122 |
static void
| 123 |
vga_paintr( /* paint a rectangle */
| 124 |
COLOR col,
| 125 |
int xmin,
| 126 |
int ymin,
| 127 |
int xmax,
| 128 |
int ymax
| 129 |
| 130 |
| 131 |
_setcolor(get_pixel(col, vgacolr)+2);
| 132 |
_rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax,
| 133 |
xmax-1, vga_driver.ysiz-1-ymin);
| 134 |
vga_driver.inpready = kbhit();
| 135 |
| 136 |
| 137 |
| 138 |
static void
| 139 |
vga_comout( /* put s to text output */
| 140 |
register char *s
| 141 |
| 142 |
| 143 |
struct rccoord tpos;
| 144 |
char buf[128];
| 145 |
register char *cp;
| 146 |
| 147 |
for (cp = buf; ; s++) {
| 148 |
switch (*s) {
| 149 |
case '\b':
| 150 |
case '\r':
| 151 |
case '\0':
| 152 |
if (cp > buf) {
| 153 |
*cp = '\0';
| 154 |
_outtext(cp = buf);
| 155 |
| 156 |
if (*s == '\0')
| 157 |
break;
| 158 |
tpos = _gettextposition();
| 159 |
_settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1);
| 160 |
continue;
| 161 |
default:
| 162 |
*cp++ = *s;
| 163 |
continue;
| 164 |
| 165 |
return(0);
| 166 |
| 167 |
fatalerr[0] = '\0';
| 168 |
| 169 |
| 170 |
| 171 |
static void
| 172 |
vga_errout(
| 173 |
register char *msg
| 174 |
| 175 |
| 176 |
static char *fep = fatalerr;
| 177 |
| 178 |
_outtext(msg);
| 179 |
while (*msg)
| 180 |
*fep++ = *msg++;
| 181 |
*fep = '\0';
| 182 |
if (fep > fatalerr && fep[-1] == '\n')
| 183 |
fep = fatalerr;
| 184 |
| 185 |
| 186 |
| 187 |
static void
| 188 |
vga_comin( /* get input line from console */
| 189 |
char *buf,
| 190 |
char *prompt
| 191 |
| 192 |
| 193 |
extern int getch();
| 194 |
| 195 |
if (prompt != NULL)
| 196 |
_outtext(prompt);
| 197 |
editline(buf, getch, vga_comout);
| 198 |
| 199 |
| 200 |
| 201 |
| 202 |
static void
| 203 |
vgacolr( /* enter a color into our table */
| 204 |
int index,
| 205 |
int r,
| 206 |
int g,
| 207 |
int b
| 208 |
| 209 |
| 210 |
register long cl;
| 211 |
| 212 |
cl = (long)b<<14 & 0x3f0000L;
| 213 |
cl |= g<<6 & 0x3f00;
| 214 |
cl |= r>>2;
| 215 |
_remappalette(index+2, cl);
| 216 |
