root/Development/ray/src/rt/vga.c
Revision: 2.11
Committed: Fri Nov 5 03:31:38 2004 UTC (21 years, 2 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: vga.c,v 2.10 2004/03/30 16:13:01 schorsch Exp $";
5 * vga.c - driver for VGA graphics adaptor under MS-DOS
6 */
7
8 #include "copyright.h"
9
10 #include <graph.h>
11
12 #include "standard.h"
13 #include "driver.h"
14 #include "color.h"
15
16 #define GAMMA 2.2 /* exponent for color correction */
17
18
19 static struct driver * vga_init(char *name, char *id);
20 static void vga_errout(char *msg);
21 static dr_newcolrf_t vgacolr;
22
23 static dr_closef_t vga_close;
24 static dr_clearf_t vga_clear;
25 static dr_paintrf_t vga_paintr;
26 static dr_comoutf_t vga_comout;
27 static dr_cominf_t vga_comin;
28
29 static struct driver vga_driver = {
30 vga_close, vga_clear, vga_paintr, NULL,
31 vga_comout, vga_comin, NULL, 1.0
32 };
33
34 static char fatalerr[128];
35 static struct videoconfig config;
36
37
38
39 static struct driver *
40 vga_init( /* open VGA */
41 char *name,
42 char *id
43 )
44 {
45 static short mode_pref[] = {_MRES256COLOR, -1};
46 static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR,
47 _VRES256COLOR, _MRES256COLOR, -1};
48 char *ep;
49 register short *mp;
50
51 mp = !strcmp(name, "vga") ? mode_pref : smode_pref;
52 for ( ; *mp != -1; mp++)
53 if (_setvideomode(*mp))
54 break;
55 if (*mp == -1) {
56 _setvideomode(_DEFAULTMODE);
57 eputs(name);
58 eputs(": card not present or insufficient VGA memory\n");
59 return(NULL);
60 }
61 _getvideoconfig(&config);
62 _settextwindow(config.numtextrows-2, 1,
63 config.numtextrows, config.numtextcols);
64 vga_driver.xsiz = config.numxpixels;
65 vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3)
66 /config.numtextrows;
67 switch (config.mode) { /* correct problems */
68 case _XRES256COLOR:
69 vga_driver.ysiz -= 16;
70 break;
71 case _MRES256COLOR:
72 vga_driver.pixaspect = 1.2;
73 break;
74 }
75 _setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz);
76 if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */
77 make_gmap(atof(ep));
78 else
79 make_gmap(GAMMA);
80 _remappalette(1, _BRIGHTWHITE);
81 _settextcolor(1);
82 ms_gcinit(&vga_driver);
83 erract[USER].pf =
84 erract[SYSTEM].pf =
85 erract[INTERNAL].pf =
86 erract[CONSISTENCY].pf = vga_errout;
87 erract[COMMAND].pf = vga_comout;
88 if (erract[WARNING].pf != NULL)
89 erract[WARNING].pf = vga_comout;
90 return(&vga_driver);
91 }
92
93
94 static void
95 vga_close(void) /* close VGA */
96 {
97 ms_gcdone(&vga_driver);
98 _setvideomode(_DEFAULTMODE);
99 erract[USER].pf = /* reset error vector */
100 erract[SYSTEM].pf =
101 erract[INTERNAL].pf =
102 erract[CONSISTENCY].pf = eputs;
103 erract[COMMAND].pf = NULL;
104 if (erract[WARNING].pf != NULL)
105 erract[WARNING].pf = wputs;
106 if (fatalerr[0])
107 eputs(fatalerr); /* repeat error message */
108 }
109
110
111 static void
112 vga_clear( /* clear VGA */
113 int x,
114 int y
115 )
116 {
117 _clearscreen(_GCLEARSCREEN);
118 new_ctab(config.numcolors-2); /* init color table */
119 }
120
121
122 static void
123 vga_paintr( /* paint a rectangle */
124 COLOR col,
125 int xmin,
126 int ymin,
127 int xmax,
128 int ymax
129 )
130 {
131 _setcolor(get_pixel(col, vgacolr)+2);
132 _rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax,
133 xmax-1, vga_driver.ysiz-1-ymin);
134 vga_driver.inpready = kbhit();
135 }
136
137
138 static void
139 vga_comout( /* put s to text output */
140 register char *s
141 )
142 {
143 struct rccoord tpos;
144 char buf[128];
145 register char *cp;
146
147 for (cp = buf; ; s++) {
148 switch (*s) {
149 case '\b':
150 case '\r':
151 case '\0':
152 if (cp > buf) {
153 *cp = '\0';
154 _outtext(cp = buf);
155 }
156 if (*s == '\0')
157 break;
158 tpos = _gettextposition();
159 _settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1);
160 continue;
161 default:
162 *cp++ = *s;
163 continue;
164 }
165 return(0);
166 }
167 fatalerr[0] = '\0';
168 }
169
170
171 static void
172 vga_errout(
173 register char *msg
174 )
175 {
176 static char *fep = fatalerr;
177
178 _outtext(msg);
179 while (*msg)
180 *fep++ = *msg++;
181 *fep = '\0';
182 if (fep > fatalerr && fep[-1] == '\n')
183 fep = fatalerr;
184 }
185
186
187 static void
188 vga_comin( /* get input line from console */
189 char *buf,
190 char *prompt
191 )
192 {
193 extern int getch();
194
195 if (prompt != NULL)
196 _outtext(prompt);
197 editline(buf, getch, vga_comout);
198 vga_driver.inpready = kbhit();
199 }
200
201
202 static void
203 vgacolr( /* enter a color into our table */
204 int index,
205 int r,
206 int g,
207 int b
208 )
209 {
210 register long cl;
211
212 cl = (long)b<<14 & 0x3f0000L;
213 cl |= g<<6 & 0x3f00;
214 cl |= r>>2;
215 _remappalette(index+2, cl);
216 }
