root/radiance/ray/src/rt/vga.c
Revision: 2.9
Committed: Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
5 * vga.c - driver for VGA graphics adaptor under MS-DOS
6 */
7
8 #include "copyright.h"
9
10 #include "standard.h"
11
12 #include <graph.h>
13
14 #include "driver.h"
15
16 #include "color.h"
17
18 #define GAMMA 2.2 /* exponent for color correction */
19
20
21 int vga_close(), vga_clear(), vga_paintr(), vga_comout(), vga_errout(),
22 vga_comin();
23
24 static struct driver vga_driver = {
25 vga_close, vga_clear, vga_paintr, NULL,
26 vga_comout, vga_comin, NULL, 1.0
27 };
28
29 static char fatalerr[128];
30
31 static struct videoconfig config;
32
33 extern char *getenv();
34
35
36 struct driver *
37 vga_init(name, id) /* open VGA */
38 char *name, *id;
39 {
40 static short mode_pref[] = {_MRES256COLOR, -1};
41 static short smode_pref[] = {_XRES256COLOR, _SVRES256COLOR,
42 _VRES256COLOR, _MRES256COLOR, -1};
43 char *ep;
44 register short *mp;
45
46 mp = !strcmp(name, "vga") ? mode_pref : smode_pref;
47 for ( ; *mp != -1; mp++)
48 if (_setvideomode(*mp))
49 break;
50 if (*mp == -1) {
51 _setvideomode(_DEFAULTMODE);
52 eputs(name);
53 eputs(": card not present or insufficient VGA memory\n");
54 return(NULL);
55 }
56 _getvideoconfig(&config);
57 _settextwindow(config.numtextrows-2, 1,
58 config.numtextrows, config.numtextcols);
59 vga_driver.xsiz = config.numxpixels;
60 vga_driver.ysiz = (long)config.numypixels*(config.numtextrows-3)
61 /config.numtextrows;
62 switch (config.mode) { /* correct problems */
63 case _XRES256COLOR:
64 vga_driver.ysiz -= 16;
65 break;
66 case _MRES256COLOR:
67 vga_driver.pixaspect = 1.2;
68 break;
69 }
70 _setviewport(0, 0, vga_driver.xsiz, vga_driver.ysiz);
71 if ((ep = getenv("GAMMA")) != NULL) /* make gamma map */
72 make_gmap(atof(ep));
73 else
74 make_gmap(GAMMA);
75 _remappalette(1, _BRIGHTWHITE);
76 _settextcolor(1);
77 ms_gcinit(&vga_driver);
78 erract[USER].pf =
79 erract[SYSTEM].pf =
80 erract[INTERNAL].pf =
81 erract[CONSISTENCY].pf = vga_errout;
82 erract[COMMAND].pf = vga_comout;
83 if (erract[WARNING].pf != NULL)
84 erract[WARNING].pf = vga_comout;
85 return(&vga_driver);
86 }
87
88
89 static
90 vga_close() /* close VGA */
91 {
92 ms_gcdone(&vga_driver);
93 _setvideomode(_DEFAULTMODE);
94 erract[USER].pf = /* reset error vector */
95 erract[SYSTEM].pf =
96 erract[INTERNAL].pf =
97 erract[CONSISTENCY].pf = eputs;
98 erract[COMMAND].pf = NULL;
99 if (erract[WARNING].pf != NULL)
100 erract[WARNING].pf = wputs;
101 if (fatalerr[0])
102 eputs(fatalerr); /* repeat error message */
103 }
104
105
106 static
107 vga_clear(x, y) /* clear VGA */
108 int x, y;
109 {
110 _clearscreen(_GCLEARSCREEN);
111 new_ctab(config.numcolors-2); /* init color table */
112 }
113
114
115 static
116 vga_paintr(col, xmin, ymin, xmax, ymax) /* paint a rectangle */
117 COLOR col;
118 int xmin, ymin, xmax, ymax;
119 {
120 extern int vgacolr();
121
122 _setcolor(get_pixel(col, vgacolr)+2);
123 _rectangle(_GFILLINTERIOR, xmin, vga_driver.ysiz-ymax,
124 xmax-1, vga_driver.ysiz-1-ymin);
125 vga_driver.inpready = kbhit();
126 }
127
128
129 static
130 vga_comout(s) /* put s to text output */
131 register char *s;
132 {
133 struct rccoord tpos;
134 char buf[128];
135 register char *cp;
136
137 for (cp = buf; ; s++) {
138 switch (*s) {
139 case '\b':
140 case '\r':
141 case '\0':
142 if (cp > buf) {
143 *cp = '\0';
144 _outtext(cp = buf);
145 }
146 if (*s == '\0')
147 break;
148 tpos = _gettextposition();
149 _settextposition(tpos.row, *s=='\r' ? 1 : tpos.col-1);
150 continue;
151 default:
152 *cp++ = *s;
153 continue;
154 }
155 return(0);
156 }
157 fatalerr[0] = '\0';
158 }
159
160
161 static
162 vga_errout(msg)
163 register char *msg;
164 {
165 static char *fep = fatalerr;
166
167 _outtext(msg);
168 while (*msg)
169 *fep++ = *msg++;
170 *fep = '\0';
171 if (fep > fatalerr && fep[-1] == '\n')
172 fep = fatalerr;
173 }
174
175
176 static
177 vga_comin(buf, prompt) /* get input line from console */
178 char *buf;
179 char *prompt;
180 {
181 extern int getch();
182
183 if (prompt != NULL)
184 _outtext(prompt);
185 editline(buf, getch, vga_comout);
186 vga_driver.inpready = kbhit();
187 }
188
189
190 static
191 vgacolr(index, r, g, b) /* enter a color into our table */
192 int index;
193 int r, g, b;
194 {
195 register long cl;
196
197 cl = (long)b<<14 & 0x3f0000L;
198 cl |= g<<6 & 0x3f00;
199 cl |= r>>2;
200 _remappalette(index+2, cl);
201 }
