root/Development/ray/src/rt/tty.c
Revision: 2.5
Committed: Fri Nov 5 03:31:38 2004 UTC (21 years, 1 month ago) by greg
State: FILE REMOVED
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.5 static const char RCSid[] = "$Id: tty.c,v 2.4 2004/03/30 16:13:01 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * tty.c - i/o for terminal drivers.
6 greg 2.2 */
7
8 greg 2.3 #include "copyright.h"
9 greg 1.1
10     #include <stdio.h>
11     #include <signal.h>
12     #include <fcntl.h>
13     #include <sys/ioctl.h>
14
15     #include "driver.h"
16
17     /*
18     * Drivers using these routines must call getch()
19     * for input from stdin.
20     */
21
22     struct sgttyb ttymode; /* original tty modes */
23     int ttyfd; /* tty file descriptor */
24 schorsch 2.4 struct driver *ttydev; /* tty device */
25 greg 1.1
26 schorsch 2.4 static dr_cominf_t ttyin;
27     static dr_getchf_t;
28     static void ttydone(void);
29     static void newinp(void);
30 greg 1.1
31
32 schorsch 2.4 extern void /* XXX declare */
33     ttyset( /* set up raw tty device */
34     struct driver *dev,
35     int fd
36     )
37 greg 1.1 {
38     struct sgttyb flags;
39
40     if (!isatty(fd))
41     return(-1);
42
43     ttyfd = fd;
44     ioctl(ttyfd, TIOCGETP, &ttymode);
45     ioctl(ttyfd, TIOCGETP, &flags);
46     flags.sg_flags |= RAW; /* also turns output */
47     flags.sg_flags &= ~ECHO; /* processing off */
48     ioctl(ttyfd, TIOCSETP, &flags);
49     /* install input handler */
50     ttydev = dev;
51     ttydev->comin = ttyin;
52     ttydev->inpready = 0;
53     signal(SIGIO, newinp);
54     fcntl(ttyfd, F_SETFL, FASYNC);
55     return(0);
56     }
57
58
59 schorsch 2.4 static void
60     ttydone(void) /* restore tty modes */
61 greg 1.1 {
62     fcntl(ttyfd, F_SETFL, 0);
63     signal(SIGIO, SIG_DFL);
64     ioctl(ttyfd, TIOCSETP, &ttymode);
65     ttydev->comin = NULL;
66     ttydev->inpready = 0;
67     ttydev = NULL;
68     }
69
70
71 schorsch 2.4 static int
72     getch(void) /* get a character in raw mode */
73 greg 1.1 {
74     register int c;
75
76     fcntl(ttyfd, F_SETFL, 0); /* allow read to block */
77     if (ttydev->inpready > 0)
78     ttydev->inpready--;
79     c = getchar();
80     fcntl(ttyfd, F_SETFL, FASYNC);
81     return(c);
82     }
83
84
85 schorsch 2.4 static void
86     ttyin( /* read a line in raw mode */
87     char *buf,
88     char *prompt
89     )
90 greg 1.1 {
91
92 greg 1.3 if (prompt != NULL)
93     (*ttydev->comout)(prompt);
94 greg 1.2 editline(buf, getch, ttydev->comout);
95 greg 1.1 }
96
97
98 schorsch 2.4 static void
99     newinp(void) /* new input */
100 greg 1.1 {
101     ttydev->inpready++;
102     }
