root/Development/ray/src/rt/tty.c
Revision: 2.5
Committed: Fri Nov 5 03:31:38 2004 UTC (21 years, 2 months ago) by greg
State: FILE REMOVED
2 static const char RCSid[] = "$Id: tty.c,v 2.4 2004/03/30 16:13:01 schorsch Exp $";
5 * tty.c - i/o for terminal drivers.
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <signal.h>
12 #include <fcntl.h>
13 #include <sys/ioctl.h>
14
15 #include "driver.h"
16
17 /*
18 * Drivers using these routines must call getch()
19 * for input from stdin.
20 */
21
22 struct sgttyb ttymode; /* original tty modes */
23 int ttyfd; /* tty file descriptor */
24 struct driver *ttydev; /* tty device */
25
26 static dr_cominf_t ttyin;
27 static dr_getchf_t;
28 static void ttydone(void);
29 static void newinp(void);
30
31
32 extern void /* XXX declare */
33 ttyset( /* set up raw tty device */
34 struct driver *dev,
35 int fd
36 )
37 {
38 struct sgttyb flags;
39
40 if (!isatty(fd))
41 return(-1);
42
43 ttyfd = fd;
44 ioctl(ttyfd, TIOCGETP, &ttymode);
45 ioctl(ttyfd, TIOCGETP, &flags);
46 flags.sg_flags |= RAW; /* also turns output */
47 flags.sg_flags &= ~ECHO; /* processing off */
48 ioctl(ttyfd, TIOCSETP, &flags);
49 /* install input handler */
50 ttydev = dev;
51 ttydev->comin = ttyin;
52 ttydev->inpready = 0;
53 signal(SIGIO, newinp);
54 fcntl(ttyfd, F_SETFL, FASYNC);
55 return(0);
56 }
57
58
59 static void
60 ttydone(void) /* restore tty modes */
61 {
62 fcntl(ttyfd, F_SETFL, 0);
63 signal(SIGIO, SIG_DFL);
64 ioctl(ttyfd, TIOCSETP, &ttymode);
65 ttydev->comin = NULL;
66 ttydev->inpready = 0;
67 ttydev = NULL;
68 }
69
70
71 static int
72 getch(void) /* get a character in raw mode */
73 {
74 register int c;
75
76 fcntl(ttyfd, F_SETFL, 0); /* allow read to block */
77 if (ttydev->inpready > 0)
78 ttydev->inpready--;
79 c = getchar();
80 fcntl(ttyfd, F_SETFL, FASYNC);
81 return(c);
82 }
83
84
85 static void
86 ttyin( /* read a line in raw mode */
87 char *buf,
88 char *prompt
89 )
90 {
91
92 if (prompt != NULL)
93 (*ttydev->comout)(prompt);
94 editline(buf, getch, ttydev->comout);
95 }
96
97
98 static void
99 newinp(void) /* new input */
100 {
101 ttydev->inpready++;
102 }
