root/radiance/ray/src/rt/text.c
Revision: 1.3
Committed: Thu Jul 27 22:25:17 1989 UTC (35 years, 9 months ago) by greg
Changed getpath to check permissions
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * text.c - functions for text patterns and mixtures.
9 *
10 * 11/12/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 /*
18 * A text pattern is specified as the text (a file or line),
19 * the upper left anchor point, the right motion vector, the down
20 * motion vector, and the foreground and background brightness.
21 * For a file, the description is as follows:
22 *
23 * modifier brighttext id
24 * 2 fontfile textfile
25 * 0
26 * 11
27 * Ax Ay Az
28 * Rx Ry Rz
29 * Dx Dy Dz
30 * foreground background
31 *
32 * For a single line, we use:
33 *
34 * modifier brighttext id
35 * N+2 fontfile . This is a line with N words...
36 * 0
37 * 11
38 * Ax Ay Az
39 * Rx Ry Rz
40 * Dx Dy Dz
41 * foreground background
42 *
43 * Colortext is identical, except colors are given rather than
44 * brightnesses. Mixtext has foreground and background modifiers:
45 *
46 * modifier mixtext id
47 * 4+ foremod backmod fontfile text..
48 * 0
49 * 9
50 * Ax Ay Az
51 * Rx Ry Rz
52 * Dx Dy Dz
53 */
54
55 #define fndx(m) ((m)->otype==MIX_TEXT ? 2 : 0)
56 #define tndx(m) ((m)->otype==MIX_TEXT ? 3 : 1)
57
58 extern char *libpath; /* library search path */
59
60 typedef unsigned char GLYPH;
61
62 typedef struct font {
63 GLYPH *fg[256]; /* font glyphs */
64 char *name; /* font file name */
65 struct font *next; /* next font in list */
66 } FONT;
67
68 extern GLYPH *getglyph();
69
70 extern FONT *getfont();
71
72 static FONT *fontlist = NULL; /* our font list */
73
74
75 text(m, r)
76 register OBJREC *m;
77 RAY *r;
78 {
79 double v[3], y, x;
80 int col, lno;
81 int foreground;
82 GLYPH *g;
83 register double *ap;
84
85 if (m->oargs.nsargs - tndx(m) < 1 ||
86 m->oargs.nfargs != (m->otype == PAT_BTEXT ? 11 :
87 m->otype == PAT_CTEXT ? 15 : 9))
88 objerror(m, USER, "bad # arguments");
89
90 /* first, discover position in text */
91 ap = m->oargs.farg;
92 multp3(v, r->rop, r->robx);
93 v[0] -= ap[0];
94 v[1] -= ap[1];
95 v[2] -= ap[2];
96 col = x = DOT(v, ap+3) / DOT(ap+3, ap+3);
97 lno = y = DOT(v, ap+6) / DOT(ap+6, ap+6);
98 x -= col;
99 y = (lno+1) - y;
100 /* get the font character, check it */
101 if ((g = getglyph(m, lno, col)) == NULL)
102 foreground = 0;
103 else
104 foreground = inglyph(x, y, g);
105 /* modify */
106 if (m->otype == MIX_TEXT) {
107 OBJECT omod;
108 char *modname = m->oargs.sarg[foreground ? 0 : 1];
109 if (!strcmp(modname, VOIDID))
110 omod = OVOID;
111 else if ((omod = modifier(modname)) == OVOID) {
112 sprintf(errmsg, "undefined modifier \"%s\"", modname);
113 objerror(m, USER, errmsg);
114 }
115 raymixture(r, omod, OVOID, 1.0);
116 } else if (m->otype == PAT_BTEXT) {
117 if (foreground)
118 scalecolor(r->pcol, ap[9]);
119 else
120 scalecolor(r->pcol, ap[10]);
121 } else { /* PAT_CTEXT */
122 COLOR cval;
123 if (foreground)
124 setcolor(cval, ap[9], ap[10], ap[11]);
125 else
126 setcolor(cval, ap[12], ap[13], ap[14]);
127 multcolor(r->pcol, cval);
128 }
129 }
130
131
132 GLYPH *
133 getglyph(tm, lno, col) /* get a glyph from a text description */
134 register OBJREC *tm;
135 int lno;
136 int col;
137 {
138 extern char *strcpy(), *fgets();
139 FILE *fp;
140 char linbuf[512];
141 register int i;
142 register char **txt;
143 register char *s;
144
145 if (lno < 0 || col < 0)
146 return(NULL);
147 if (tm->os == NULL) {
148 txt = (char **)malloc(2*sizeof(char **));
149 if (txt == NULL)
150 goto memerr;
151 if (tm->oargs.nsargs - tndx(tm) > 1) { /* single line */
152 s = linbuf;
153 for (i = tndx(tm)+1; i < tm->oargs.nsargs; i++) {
154 strcpy(s, tm->oargs.sarg[i]);
155 s += strlen(s);
156 *s++ = ' ';
157 }
158 *--s = '\0';
159 txt[0] = savqstr(linbuf);
160 txt[1] = NULL;
161 } else { /* text file */
162 if ((s = getpath(tm->oargs.sarg[tndx(tm)],
163 libpath, R_OK)) == NULL) {
164 sprintf(errmsg, "cannot find text file \"%s\"",
165 tm->oargs.sarg[tndx(tm)]);
166 error(USER, errmsg);
167 }
168 if ((fp = fopen(s, "r")) == NULL) {
169 sprintf(errmsg, "cannot open text file \"%s\"",
170 s);
171 error(SYSTEM, errmsg);
172 }
173 for (i=0; fgets(linbuf,sizeof(linbuf),fp)!=NULL; i++) {
174 s = linbuf + strlen(linbuf) - 1;
175 if (*s == '\n')
176 *s = '\0';
177 txt=(char **)realloc(txt,(i+2)*sizeof(char **));
178 if (txt == NULL)
179 goto memerr;
180 txt[i] = savqstr(linbuf);
181 }
182 txt[i] = NULL;
183 fclose(fp);
184 }
185 tm->os = (char *)txt;
186 }
187 txt = (char **)tm->os;
188 for (i = 0; i < lno; i++)
189 if (txt[i] == NULL)
190 break;
191 if ((s = txt[i]) == NULL || col >= strlen(s))
192 return(NULL);
193 else
194 return(getfont(tm->oargs.sarg[fndx(tm)])->fg[s[col]]);
195 memerr:
196 error(SYSTEM, "out of memory in getglyph");
197 }
198
199
200 FONT *
201 getfont(fname) /* return font fname */
202 char *fname;
203 {
204 FILE *fp;
205 char *pathname, *err;
206 int gn, ngv, gv;
207 register GLYPH *g;
208 register FONT *f;
209
210 for (f = fontlist; f != NULL; f = f->next)
211 if (!strcmp(f->name, fname))
212 return(f);
213 /* load the font file */
214 if ((pathname = getpath(fname, libpath, R_OK)) == NULL) {
215 sprintf(errmsg, "cannot find font file \"%s\"", fname);
216 error(USER, errmsg);
217 }
218 f = (FONT *)calloc(1, sizeof(FONT));
219 if (f == NULL)
220 goto memerr;
221 f->name = savestr(fname);
222 if ((fp = fopen(pathname, "r")) == NULL) {
223 sprintf(errmsg, "cannot open font file \"%s\"",
224 pathname);
225 error(SYSTEM, errmsg);
226 }
227 while (fscanf(fp, "%d", &gn) == 1) { /* get each glyph */
228 if (gn < 0 || gn > 255) {
229 err = "illegal";
230 goto fonterr;
231 }
232 if (f->fg[gn] != NULL) {
233 err = "duplicate";
234 goto fonterr;
235 }
236 if (fscanf(fp, "%d", &ngv) != 1 ||
237 ngv < 0 || ngv > 255) {
238 err = "bad # vertices for";
239 goto fonterr;
240 }
241 g = (GLYPH *)malloc((2*ngv+1)*sizeof(GLYPH));
242 if (g == NULL)
243 goto memerr;
244 f->fg[gn] = g;
245 *g++ = ngv;
246 ngv *= 2;
247 while (ngv--) {
248 if (fscanf(fp, "%d", &gv) != 1 ||
249 gv < 0 || gv > 255) {
250 err = "bad vertex for";
251 goto fonterr;
252 }
253 *g++ = gv;
254 }
255 }
256 fclose(fp);
257 f->next = fontlist;
258 return(fontlist = f);
259 fonterr:
260 sprintf(errmsg, "%s character (%d) in font file \"%s\"",
261 err, gn, pathname);
262 error(USER, errmsg);
263 memerr:
264 error(SYSTEM, "out of memory in fontglyph");
265 }
266
267
268 inglyph(x, y, gl) /* (x,y) within font glyph gl? */
269 double x, y;
270 GLYPH *gl;
271 {
272 int n, ncross;
273 int xlb, ylb;
274 register GLYPH *p0, *p1;
275
276 if (x < 0.0 || y < 0.0)
277 return(0);
278 xlb = x *= 255.0; /* get glyph coordinates */
279 ylb = y *= 255.0;
280 n = *gl++; /* get # of vertices */
281 p0 = gl + 2*(n-1); /* connect last to first */
282 p1 = gl;
283 ncross = 0;
284 /* positive x axis cross test */
285 while (n--) {
286 if ((p0[1] > ylb) ^ (p1[1] > ylb))
287 if (p0[0] > xlb && p1[0] > xlb)
288 ncross++;
289 else if (p0[0] > xlb || p1[0] > xlb)
290 ncross += (p1[1] > p0[1]) ^
291 ((p0[1]-y)*(p1[0]-x) >
292 (p0[0]-x)*(p1[1]-y));
293 p0 = p1;
294 p1 += 2;
295 }
296 return(ncross & 01);
297 }
