--- ray/src/rt/text.c 1992/06/16 13:24:23 2.3 +++ ray/src/rt/text.c 1992/06/19 13:07:48 2.4 @@ -25,22 +25,24 @@ static char SCCSid[] = "$SunId$ LBL"; * modifier brighttext id * 2 fontfile textfile * 0 - * 11 + * 11+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz * foreground background + * [spacing] * * For a single line, we use: * * modifier brighttext id * N+2 fontfile . This is a line with N words... * 0 - * 11 + * 11+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz * foreground background + * [spacing] * * Colortext is identical, except colors are given rather than * brightnesses. Mixtext has foreground and background modifiers: @@ -48,17 +50,22 @@ static char SCCSid[] = "$SunId$ LBL"; * modifier mixtext id * 4+ foremod backmod fontfile text.. * 0 - * 9 + * 9+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz + * [spacing] */ #define fndx(m) ((m)->otype==MIX_TEXT ? 2 : 0) #define tndx(m) ((m)->otype==MIX_TEXT ? 3 : 1) +#define sndx(m) ((m)->otype==PAT_BTEXT ? 11 : \ + (m)->otype==PAT_CTEXT ? 15 : 9) typedef struct tline { struct tline *next; /* pointer to next line */ + short *spc; /* character spacing */ + int width; /* total line width */ /* followed by the string */ } TLINE; @@ -128,11 +135,14 @@ tlalloc(s) /* allocate and assign text line */ char *s; { extern char *strcpy(); + register int siz; register TLINE *tl; - tl = (TLINE *)malloc(sizeof(TLINE)+1+strlen(s)); - if (tl == NULL) + siz = strlen(s) + 1; + if ((tl=(TLINE *)malloc(sizeof(TLINE)+siz)) == NULL || + (tl->spc=(short *)malloc(siz*sizeof(short))) == NULL) error(SYSTEM, "out of memory in tlalloc"); + tl->spc = NULL; tl->next = NULL; strcpy(TLSTR(tl), s); return(tl); @@ -158,12 +168,10 @@ register OBJREC *tm; if ((t = (TEXT *)tm->os) != NULL) return(t); /* check arguments */ - if (tm->oargs.nsargs - tndx(tm) < 1 || - tm->oargs.nfargs != (tm->otype == PAT_BTEXT ? 11 : - tm->otype == PAT_CTEXT ? 15 : 9)) + if (tm->oargs.nsargs - tndx(tm) < 1 || tm->oargs.nfargs < sndx(tm)) objerror(tm, USER, "bad # arguments"); if ((t = (TEXT *)malloc(sizeof(TEXT))) == NULL) - error(SYSTEM, "out of memory in gettext"); + goto memerr; /* compute vectors */ fcross(DxR, D, R); fcross(t->right, DxR, D); @@ -194,8 +202,7 @@ register OBJREC *tm; error(USER, errmsg); } if ((fp = fopen(s, "r")) == NULL) { - sprintf(errmsg, "cannot open text file \"%s\"", - s); + sprintf(errmsg, "cannot open text file \"%s\"", s); error(SYSTEM, errmsg); } while (fgets(linbuf, sizeof(linbuf), fp) != NULL) { @@ -210,9 +217,26 @@ register OBJREC *tm; tlp->next = NULL; /* get the font */ t->f = getfont(tm->oargs.sarg[fndx(tm)]); + /* compute character spacing */ + i = sndx(tm); + d = i < tm->oargs.nfargs ? tm->oargs.farg[i] : 0.0; + i = d * 256.0; + for (tlp = t->tl.next; tlp != NULL; tlp = tlp->next) { + if ((tlp->spc = (short *)malloc( + (strlen(TLSTR(tlp))+1)*sizeof(short))) == NULL) + goto memerr; + if (i < 0) + tlp->width = squeeztext(tlp->spc, TLSTR(tlp), t->f, -i); + else if (i > 0) + tlp->width = proptext(tlp->spc, TLSTR(tlp), t->f, i, 3); + else + tlp->width = uniftext(tlp->spc, TLSTR(tlp), t->f); + } /* we're done */ tm->os = (char *)t; return(t); +memerr: + error(SYSTEM, "out of memory in gettext"); #undef R #undef D } @@ -227,8 +251,10 @@ OBJREC *m; tp = (TEXT *)m->os; if (tp == NULL) return; - for (tlp = tp->tl.next; tlp != NULL; tlp = tlp->next); + for (tlp = tp->tl.next; tlp != NULL; tlp = tlp->next) { + free((char *)tlp->spc); free((char *)tlp); + } free((char *)tp); m->os = NULL; } @@ -242,26 +268,29 @@ OBJREC *m; register TLINE *tlp; FVECT v; double y, x; - int col; - register int lno; + register int i, h; /* first, compute position in text */ tp = gettext(m); v[0] = p[0] - m->oargs.farg[0]; v[1] = p[1] - m->oargs.farg[1]; v[2] = p[2] - m->oargs.farg[2]; - col = x = DOT(v, tp->right); - lno = y = DOT(v, tp->down); + h = x = DOT(v, tp->right)*256.; + i = y = DOT(v, tp->down); if (x < 0.0 || y < 0.0) return(0); - x -= (double)col; - y = (lno+1) - y; - /* get the font character */ + x -= (double)h; + y = ((i+1) - y)*256.; + /* find the line position */ for (tlp = tp->tl.next; tlp != NULL; tlp = tlp->next) - if (--lno < 0) + if (--i < 0) break; - if (tlp == NULL || col >= strlen(TLSTR(tlp))) + if (tlp == NULL || h >= tlp->width) return(0); - return(inglyph(x, y, tp->f->fg[TLSTR(tlp)[col]&0xff])); + for (i = 0; (h -= tlp->spc[i]) >= 0; i++) + if (h < 256 && inglyph(h+x, y, + tp->f->fg[TLSTR(tlp)[i]&0xff])) + return(1); + return(0); } @@ -270,17 +299,15 @@ double x, y; register GLYPH *gl; { int n, ncross; - int xlb, ylb; + int xtc, ytc; register GORD *p0, *p1; if (gl == NULL) return(0); - x *= 256.0; /* get glyph coordinates */ - y *= 256.0; - xlb = x + 0.5; - ylb = y + 0.5; - if (gl->left > xlb || gl->right <= xlb || - gl->bottom > ylb || gl->top <= ylb) + xtc = x + 0.5; /* compute test coordinates */ + ytc = y + 0.5; + if (gl->left > xtc || gl->right < xtc || + gl->bottom > ytc || gl->top < ytc) return(0); /* outside extent */ n = gl->nverts; /* get # of vertices */ p0 = gvlist(gl) + 2*(n-1); /* connect last to first */ @@ -288,10 +315,10 @@ register GLYPH *gl; ncross = 0; /* positive x axis cross test */ while (n--) { - if ((p0[1] > ylb) ^ (p1[1] > ylb)) - if (p0[0] > xlb && p1[0] > xlb) + if ((p0[1] > ytc) ^ (p1[1] > ytc)) + if (p0[0] > xtc && p1[0] > xtc) ncross++; - else if (p0[0] > xlb || p1[0] > xlb) + else if (p0[0] > xtc || p1[0] > xtc) ncross += (p1[1] > p0[1]) ^ ((p0[1]-y)*(p1[0]-x) > (p0[0]-x)*(p1[1]-y));
