root/radiance/ray/src/rt/text.c
Revision: 1.4
Committed: Sat Dec 15 15:03:40 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.3: +5 -2 lines
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * text.c - functions for text patterns and mixtures.
9 *
10 * 11/12/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 /*
18 * A text pattern is specified as the text (a file or line),
19 * the upper left anchor point, the right motion vector, the down
20 * motion vector, and the foreground and background brightness.
21 * For a file, the description is as follows:
22 *
23 * modifier brighttext id
24 * 2 fontfile textfile
25 * 0
26 * 11
27 * Ax Ay Az
28 * Rx Ry Rz
29 * Dx Dy Dz
30 * foreground background
31 *
32 * For a single line, we use:
33 *
34 * modifier brighttext id
35 * N+2 fontfile . This is a line with N words...
36 * 0
37 * 11
38 * Ax Ay Az
39 * Rx Ry Rz
40 * Dx Dy Dz
41 * foreground background
42 *
43 * Colortext is identical, except colors are given rather than
44 * brightnesses. Mixtext has foreground and background modifiers:
45 *
46 * modifier mixtext id
47 * 4+ foremod backmod fontfile text..
48 * 0
49 * 9
50 * Ax Ay Az
51 * Rx Ry Rz
52 * Dx Dy Dz
53 */
54
55 #define fndx(m) ((m)->otype==MIX_TEXT ? 2 : 0)
56 #define tndx(m) ((m)->otype==MIX_TEXT ? 3 : 1)
57
58 extern char *libpath; /* library search path */
59
60 typedef unsigned char GLYPH;
61
62 typedef struct font {
63 GLYPH *fg[256]; /* font glyphs */
64 char *name; /* font file name */
65 struct font *next; /* next font in list */
66 } FONT;
67
68 extern GLYPH *getglyph();
69
70 extern FONT *getfont();
71
72 static FONT *fontlist = NULL; /* our font list */
73
74
75 text(m, r)
76 register OBJREC *m;
77 RAY *r;
78 {
79 double v[3], y, x;
80 int col, lno;
81 int foreground;
82 GLYPH *g;
83 register double *ap;
84
85 if (m->oargs.nsargs - tndx(m) < 1 ||
86 m->oargs.nfargs != (m->otype == PAT_BTEXT ? 11 :
87 m->otype == PAT_CTEXT ? 15 : 9))
88 objerror(m, USER, "bad # arguments");
89
90 /* first, discover position in text */
91 ap = m->oargs.farg;
92 if (r->rox != NULL)
93 multp3(v, r->rop, r->rox->b.xfm);
94 else
95 VCOPY(v, r->rop);
96 v[0] -= ap[0];
97 v[1] -= ap[1];
98 v[2] -= ap[2];
99 col = x = DOT(v, ap+3) / DOT(ap+3, ap+3);
100 lno = y = DOT(v, ap+6) / DOT(ap+6, ap+6);
101 x -= col;
102 y = (lno+1) - y;
103 /* get the font character, check it */
104 if ((g = getglyph(m, lno, col)) == NULL)
105 foreground = 0;
106 else
107 foreground = inglyph(x, y, g);
108 /* modify */
109 if (m->otype == MIX_TEXT) {
110 OBJECT omod;
111 char *modname = m->oargs.sarg[foreground ? 0 : 1];
112 if (!strcmp(modname, VOIDID))
113 omod = OVOID;
114 else if ((omod = modifier(modname)) == OVOID) {
115 sprintf(errmsg, "undefined modifier \"%s\"", modname);
116 objerror(m, USER, errmsg);
117 }
118 raymixture(r, omod, OVOID, 1.0);
119 } else if (m->otype == PAT_BTEXT) {
120 if (foreground)
121 scalecolor(r->pcol, ap[9]);
122 else
123 scalecolor(r->pcol, ap[10]);
124 } else { /* PAT_CTEXT */
125 COLOR cval;
126 if (foreground)
127 setcolor(cval, ap[9], ap[10], ap[11]);
128 else
129 setcolor(cval, ap[12], ap[13], ap[14]);
130 multcolor(r->pcol, cval);
131 }
132 }
133
134
135 GLYPH *
136 getglyph(tm, lno, col) /* get a glyph from a text description */
137 register OBJREC *tm;
138 int lno;
139 int col;
140 {
141 extern char *strcpy(), *fgets();
142 FILE *fp;
143 char linbuf[512];
144 register int i;
145 register char **txt;
146 register char *s;
147
148 if (lno < 0 || col < 0)
149 return(NULL);
150 if (tm->os == NULL) {
151 txt = (char **)malloc(2*sizeof(char **));
152 if (txt == NULL)
153 goto memerr;
154 if (tm->oargs.nsargs - tndx(tm) > 1) { /* single line */
155 s = linbuf;
156 for (i = tndx(tm)+1; i < tm->oargs.nsargs; i++) {
157 strcpy(s, tm->oargs.sarg[i]);
158 s += strlen(s);
159 *s++ = ' ';
160 }
161 *--s = '\0';
162 txt[0] = savqstr(linbuf);
163 txt[1] = NULL;
164 } else { /* text file */
165 if ((s = getpath(tm->oargs.sarg[tndx(tm)],
166 libpath, R_OK)) == NULL) {
167 sprintf(errmsg, "cannot find text file \"%s\"",
168 tm->oargs.sarg[tndx(tm)]);
169 error(USER, errmsg);
170 }
171 if ((fp = fopen(s, "r")) == NULL) {
172 sprintf(errmsg, "cannot open text file \"%s\"",
173 s);
174 error(SYSTEM, errmsg);
175 }
176 for (i=0; fgets(linbuf,sizeof(linbuf),fp)!=NULL; i++) {
177 s = linbuf + strlen(linbuf) - 1;
178 if (*s == '\n')
179 *s = '\0';
180 txt=(char **)realloc(txt,(i+2)*sizeof(char **));
181 if (txt == NULL)
182 goto memerr;
183 txt[i] = savqstr(linbuf);
184 }
185 txt[i] = NULL;
186 fclose(fp);
187 }
188 tm->os = (char *)txt;
189 }
190 txt = (char **)tm->os;
191 for (i = 0; i < lno; i++)
192 if (txt[i] == NULL)
193 break;
194 if ((s = txt[i]) == NULL || col >= strlen(s))
195 return(NULL);
196 else
197 return(getfont(tm->oargs.sarg[fndx(tm)])->fg[s[col]]);
198 memerr:
199 error(SYSTEM, "out of memory in getglyph");
200 }
201
202
203 FONT *
204 getfont(fname) /* return font fname */
205 char *fname;
206 {
207 FILE *fp;
208 char *pathname, *err;
209 int gn, ngv, gv;
210 register GLYPH *g;
211 register FONT *f;
212
213 for (f = fontlist; f != NULL; f = f->next)
214 if (!strcmp(f->name, fname))
215 return(f);
216 /* load the font file */
217 if ((pathname = getpath(fname, libpath, R_OK)) == NULL) {
218 sprintf(errmsg, "cannot find font file \"%s\"", fname);
219 error(USER, errmsg);
220 }
221 f = (FONT *)calloc(1, sizeof(FONT));
222 if (f == NULL)
223 goto memerr;
224 f->name = savestr(fname);
225 if ((fp = fopen(pathname, "r")) == NULL) {
226 sprintf(errmsg, "cannot open font file \"%s\"",
227 pathname);
228 error(SYSTEM, errmsg);
229 }
230 while (fscanf(fp, "%d", &gn) == 1) { /* get each glyph */
231 if (gn < 0 || gn > 255) {
232 err = "illegal";
233 goto fonterr;
234 }
235 if (f->fg[gn] != NULL) {
236 err = "duplicate";
237 goto fonterr;
238 }
239 if (fscanf(fp, "%d", &ngv) != 1 ||
240 ngv < 0 || ngv > 255) {
241 err = "bad # vertices for";
242 goto fonterr;
243 }
244 g = (GLYPH *)malloc((2*ngv+1)*sizeof(GLYPH));
245 if (g == NULL)
246 goto memerr;
247 f->fg[gn] = g;
248 *g++ = ngv;
249 ngv *= 2;
250 while (ngv--) {
251 if (fscanf(fp, "%d", &gv) != 1 ||
252 gv < 0 || gv > 255) {
253 err = "bad vertex for";
254 goto fonterr;
255 }
256 *g++ = gv;
257 }
258 }
259 fclose(fp);
260 f->next = fontlist;
261 return(fontlist = f);
262 fonterr:
263 sprintf(errmsg, "%s character (%d) in font file \"%s\"",
264 err, gn, pathname);
265 error(USER, errmsg);
266 memerr:
267 error(SYSTEM, "out of memory in fontglyph");
268 }
269
270
271 inglyph(x, y, gl) /* (x,y) within font glyph gl? */
272 double x, y;
273 GLYPH *gl;
274 {
275 int n, ncross;
276 int xlb, ylb;
277 register GLYPH *p0, *p1;
278
279 if (x < 0.0 || y < 0.0)
280 return(0);
281 xlb = x *= 255.0; /* get glyph coordinates */
282 ylb = y *= 255.0;
283 n = *gl++; /* get # of vertices */
284 p0 = gl + 2*(n-1); /* connect last to first */
285 p1 = gl;
286 ncross = 0;
287 /* positive x axis cross test */
288 while (n--) {
289 if ((p0[1] > ylb) ^ (p1[1] > ylb))
290 if (p0[0] > xlb && p1[0] > xlb)
291 ncross++;
292 else if (p0[0] > xlb || p1[0] > xlb)
293 ncross += (p1[1] > p0[1]) ^
294 ((p0[1]-y)*(p1[0]-x) >
295 (p0[0]-x)*(p1[1]-y));
296 p0 = p1;
297 p1 += 2;
298 }
299 return(ncross & 01);
300 }
