--- ray/src/rt/text.c 1991/08/05 09:32:12 1.7 +++ ray/src/rt/text.c 1992/11/10 10:33:43 2.8 @@ -14,6 +14,8 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" +#include "font.h" + /* * A text pattern is specified as the text (a file or line), * the upper left anchor point, the right motion vector, the down @@ -23,22 +25,24 @@ static char SCCSid[] = "$SunId$ LBL"; * modifier brighttext id * 2 fontfile textfile * 0 - * 11 + * 11+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz * foreground background + * [spacing] * * For a single line, we use: * * modifier brighttext id * N+2 fontfile . This is a line with N words... * 0 - * 11 + * 11+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz * foreground background + * [spacing] * * Colortext is identical, except colors are given rather than * brightnesses. Mixtext has foreground and background modifiers: @@ -46,45 +50,47 @@ static char SCCSid[] = "$SunId$ LBL"; * modifier mixtext id * 4+ foremod backmod fontfile text.. * 0 - * 9 + * 9+ * Ax Ay Az * Rx Ry Rz * Dx Dy Dz + * [spacing] */ #define fndx(m) ((m)->otype==MIX_TEXT ? 2 : 0) #define tndx(m) ((m)->otype==MIX_TEXT ? 3 : 1) +#define sndx(m) ((m)->otype==PAT_BTEXT ? 11 : \ + (m)->otype==PAT_CTEXT ? 15 : 9) -extern char *libpath; /* library search path */ +typedef struct tline { + struct tline *next; /* pointer to next line */ + short *spc; /* character spacing */ + int width; /* total line width */ + /* followed by the string */ +} TLINE; -typedef unsigned char GLYPH; +#define TLSTR(l) ((char *)((l)+1)) -typedef struct font { - GLYPH *fg[256]; /* font glyphs */ - char *name; /* font file name */ - struct font *next; /* next font in list */ -} FONT; - typedef struct { - char **t; /* text array */ FVECT right, down; /* right and down unit vectors */ FONT *f; /* our font */ + TLINE tl; /* line list */ } TEXT; +extern char *libpath; + extern char *fgetword(); TEXT *gettext(); -FONT *getfont(); +TLINE *tlalloc(); -static FONT *fontlist = NULL; /* our font list */ - text(m, r) register OBJREC *m; RAY *r; { - double v[3]; + FVECT v; int foreground; /* get transformed position */ if (r->rox != NULL) @@ -124,6 +130,25 @@ RAY *r; } +TLINE * +tlalloc(s) /* allocate and assign text line */ +char *s; +{ + extern char *strcpy(); + register int siz; + register TLINE *tl; + + siz = strlen(s) + 1; + if ((tl=(TLINE *)malloc(sizeof(TLINE)+siz)) == NULL || + (tl->spc=(short *)malloc(siz*sizeof(short))) == NULL) + error(SYSTEM, "out of memory in tlalloc"); + tl->spc = NULL; + tl->next = NULL; + strcpy(TLSTR(tl), s); + return(tl); +} + + TEXT * gettext(tm) /* get text structure for material */ register OBJREC *tm; @@ -135,33 +160,30 @@ register OBJREC *tm; double d; FILE *fp; char linbuf[512]; - register TEXT *t; + TEXT *t; register int i; + register TLINE *tlp; register char *s; if ((t = (TEXT *)tm->os) != NULL) return(t); /* check arguments */ - if (tm->oargs.nsargs - tndx(tm) < 1 || - tm->oargs.nfargs != (tm->otype == PAT_BTEXT ? 11 : - tm->otype == PAT_CTEXT ? 15 : 9)) + if (tm->oargs.nsargs - tndx(tm) < 1 || tm->oargs.nfargs < sndx(tm)) objerror(tm, USER, "bad # arguments"); if ((t = (TEXT *)malloc(sizeof(TEXT))) == NULL) goto memerr; /* compute vectors */ fcross(DxR, D, R); fcross(t->right, DxR, D); - d = DOT(D,D) / DOT(t->right,t->right); + d = DOT(D,D)/DOT(t->right,t->right); for (i = 0; i < 3; i++) t->right[i] *= d; fcross(t->down, R, DxR); - d = DOT(R,R) / DOT(t->down,t->down); + d = DOT(R,R)/DOT(t->down,t->down); for (i = 0; i < 3; i++) t->down[i] *= d; /* get text */ - t->t = (char **)malloc(2*sizeof(char **)); - if (t->t == NULL) - goto memerr; + tlp = &t->tl; if (tm->oargs.nsargs - tndx(tm) > 1) { /* single line */ s = linbuf; for (i = tndx(tm)+1; i < tm->oargs.nsargs; i++) { @@ -170,8 +192,8 @@ register OBJREC *tm; *s++ = ' '; } *--s = '\0'; - t->t[0] = savqstr(linbuf); - t->t[1] = NULL; + tlp->next = tlalloc(linbuf); + tlp = tlp->next; } else { /* text file */ if ((s = getpath(tm->oargs.sarg[tndx(tm)], libpath, R_OK)) == NULL) { @@ -180,25 +202,39 @@ register OBJREC *tm; error(USER, errmsg); } if ((fp = fopen(s, "r")) == NULL) { - sprintf(errmsg, "cannot open text file \"%s\"", - s); + sprintf(errmsg, "cannot open text file \"%s\"", s); error(SYSTEM, errmsg); } - for (i=0; fgets(linbuf,sizeof(linbuf),fp)!=NULL; i++) { + while (fgets(linbuf, sizeof(linbuf), fp) != NULL) { s = linbuf + strlen(linbuf) - 1; if (*s == '\n') *s = '\0'; - t->t=(char **)realloc((char *)t->t, - (i+2)*sizeof(char **)); - if (t->t == NULL) - goto memerr; - t->t[i] = savqstr(linbuf); + tlp->next = tlalloc(linbuf); + tlp = tlp->next; } - t->t[i] = NULL; fclose(fp); } + tlp->next = NULL; /* get the font */ t->f = getfont(tm->oargs.sarg[fndx(tm)]); + /* compute character spacing */ + i = sndx(tm); + d = i < tm->oargs.nfargs ? tm->oargs.farg[i] : 0.0; + i = d * 256.0; + t->tl.width = 0; + for (tlp = t->tl.next; tlp != NULL; tlp = tlp->next) { + if ((tlp->spc = (short *)malloc( + (strlen(TLSTR(tlp))+1)*sizeof(short))) == NULL) + goto memerr; + if (i < 0) + tlp->width = squeeztext(tlp->spc, TLSTR(tlp), t->f, -i); + else if (i > 0) + tlp->width = proptext(tlp->spc, TLSTR(tlp), t->f, i, 3); + else + tlp->width = uniftext(tlp->spc, TLSTR(tlp), t->f); + if (tlp->width > t->tl.width) + t->tl.width = tlp->width; + } /* we're done */ tm->os = (char *)t; return(t); @@ -212,15 +248,17 @@ memerr: freetext(m) /* free text structures associated with m */ OBJREC *m; { - register TEXT *tp; - register int i; + TEXT *tp; + register TLINE *tlp, *tln; tp = (TEXT *)m->os; if (tp == NULL) return; - for (i = 0; tp->t[i] != NULL; i++) - freeqstr(tp->t[i]); - free((char *)tp->t); + for (tlp = tp->tl.next; tlp != NULL; tlp = tln) { + tln = tlp->next; + free((char *)tlp->spc); + free((char *)tlp); + } free((char *)tp); m->os = NULL; } @@ -228,136 +266,77 @@ OBJREC *m; intext(p, m) /* check to see if p is in text glyph */ FVECT p; -register OBJREC *m; +OBJREC *m; { register TEXT *tp; - register int i; - double v[3], y, x; - int col, lno; + register TLINE *tlp; + FVECT v; + double y, x; + register int i, h; /* first, compute position in text */ + tp = gettext(m); v[0] = p[0] - m->oargs.farg[0]; v[1] = p[1] - m->oargs.farg[1]; v[2] = p[2] - m->oargs.farg[2]; - col = x = DOT(v, tp->right); - lno = y = DOT(v, tp->down); + x = DOT(v, tp->right); + i = sndx(m); + if (i < m->oargs.nfargs) + x *= tp->f->mwidth + 256.*fabs(m->oargs.farg[i]); + else + x *= 256.; + h = x; + i = y = DOT(v, tp->down); if (x < 0.0 || y < 0.0) return(0); - x -= (double)col; - y = (lno+1) - y; - /* get the font character */ - tp = gettext(m); - for (i = 0; i < lno; i++) - if (tp->t[i] == NULL) - return(0); - if (col >= strlen(tp->t[i])) + x -= (double)h; + y = ((i+1) - y)*256.; + /* find the line position */ + for (tlp = tp->tl.next; tlp != NULL; tlp = tlp->next) + if (--i < 0) + break; + if (tlp == NULL || h >= tlp->width) return(0); - return(inglyph(x, y, tp->f->fg[tp->t[i][col]])); + for (i = 0; (h -= tlp->spc[i]) >= 0; i++) + if (h < 256 && inglyph(h+x, y, + tp->f->fg[TLSTR(tlp)[i]&0xff])) + return(1); + return(0); } -FONT * -getfont(fname) /* return font fname */ -char *fname; -{ - char buf[16]; - FILE *fp; - char *pathname, *err; - int gn, ngv, gv; - register GLYPH *g; - register FONT *f; - - for (f = fontlist; f != NULL; f = f->next) - if (!strcmp(f->name, fname)) - return(f); - /* load the font file */ - if ((pathname = getpath(fname, libpath, R_OK)) == NULL) { - sprintf(errmsg, "cannot find font file \"%s\"", fname); - error(USER, errmsg); - } - f = (FONT *)calloc(1, sizeof(FONT)); - if (f == NULL) - goto memerr; - f->name = savestr(fname); - if ((fp = fopen(pathname, "r")) == NULL) { - sprintf(errmsg, "cannot open font file \"%s\"", - pathname); - error(SYSTEM, errmsg); - } - while (fgetword(buf,sizeof(buf),fp) != NULL) { /* get each glyph */ - if (!isint(buf)) - goto nonint; - gn = atoi(buf); - if (gn < 0 || gn > 255) { - err = "illegal"; - goto fonterr; - } - if (f->fg[gn] != NULL) { - err = "duplicate"; - goto fonterr; - } - if (fgetword(buf,sizeof(buf),fp) == NULL || !isint(buf) || - (ngv = atoi(buf)) < 0 || ngv > 255) { - err = "bad # vertices for"; - goto fonterr; - } - g = (GLYPH *)malloc((2*ngv+1)*sizeof(GLYPH)); - if (g == NULL) - goto memerr; - f->fg[gn] = g; - *g++ = ngv; - ngv *= 2; - while (ngv--) { - if (fgetword(buf,sizeof(buf),fp) == NULL || - !isint(buf) || - (gv = atoi(buf)) < 0 || gv > 255) { - err = "bad vertex for"; - goto fonterr; - } - *g++ = gv; - } - } - fclose(fp); - f->next = fontlist; - return(fontlist = f); -nonint: - sprintf(errmsg, "non-integer in font file \"%s\"", pathname); - error(USER, errmsg); -fonterr: - sprintf(errmsg, "%s character (%d) in font file \"%s\"", - err, gn, pathname); - error(USER, errmsg); -memerr: - error(SYSTEM, "out of memory in fontglyph"); -} - - inglyph(x, y, gl) /* (x,y) within font glyph gl? */ -double x, y; -GLYPH *gl; +double x, y; /* real coordinates in range [0,256) */ +register GLYPH *gl; { int n, ncross; int xlb, ylb; - register GLYPH *p0, *p1; + int tv; + register GORD *p0, *p1; if (gl == NULL) return(0); - x *= 256.0; /* get glyph coordinates */ - y *= 256.0; - xlb = x + 0.5; - ylb = y + 0.5; - n = *gl++; /* get # of vertices */ - p0 = gl + 2*(n-1); /* connect last to first */ - p1 = gl; + xlb = x; + ylb = y; + if (gl->left > xlb || gl->right <= xlb || /* check extent */ + gl->bottom > ylb || gl->top <= ylb) + return(0); + xlb = xlb<<1 | 1; /* add 1/2 to test points... */ + ylb = ylb<<1 | 1; /* ...so no equal comparisons */ + n = gl->nverts; /* get # of vertices */ + p0 = gvlist(gl) + 2*(n-1); /* connect last to first */ + p1 = gvlist(gl); ncross = 0; /* positive x axis cross test */ while (n--) { - if ((p0[1] > ylb) ^ (p1[1] > ylb)) - if (p0[0] > xlb && p1[0] > xlb) + if ((p0[1]<<1 > ylb) ^ (p1[1]<<1 > ylb)) { + tv = p0[0]<<1 > xlb | (p1[0]<<1 > xlb) << 1; + if (tv == 03) ncross++; - else if (p0[0] > xlb || p1[0] > xlb) + else if (tv) ncross += (p1[1] > p0[1]) ^ ((p0[1]-y)*(p1[0]-x) > (p0[0]-x)*(p1[1]-y)); + } p0 = p1; p1 += 2; }
