root/radiance/ray/src/rt/text.c
Changes since 2.24: +34 -24 lines
Diff to previous 2.24
Revision 2.24 - (view) (download) (annotate) - [selected]
Thu Feb 12 18:55:50 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.23: +3 -1 lines
Diff to previous 2.23
Diff to previous 2.22 , to selected 2.24
Tue May 13 17:58:33 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21 , to selected 2.24
Changes since 2.20: +1 -56 lines
Diff to previous 2.20 , to selected 2.24
Changes since 2.19: +62 -13 lines
Diff to previous 2.19 , to selected 2.24
Thu May 20 13:51:19 1999 UTC (24 years, 11 months ago) by gwlarson
Diff to previous 2.18 , to selected 2.24
decreased epsilon for check of zero motion vector
Mon Aug 10 18:37:06 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 2.17 , to selected 2.24
Mon Nov 17 13:13:07 1997 UTC (26 years, 5 months ago) by gregl
Diff to previous 2.16 , to selected 2.24
added check for parallel or zero motion vectors
Sat Jun 22 09:48:52 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.15: +1 -1 lines
Diff to previous 2.15 , to selected 2.24
changed text(), which is reserved word on PowerPC, to do_text()
Tue Dec 5 20:21:39 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.24
fixed bug for mixing non-materials
Thu May 25 15:13:43 1995 UTC (28 years, 11 months ago) by greg
Changes since 2.13: +6 -6 lines
Diff to previous 2.13 , to selected 2.24
fixed problem with hexbit font (spacing from 256 to 255 per char)
Thu Apr 14 04:50:37 1994 UTC (30 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.24
Wed Jan 12 17:14:42 1994 UTC (30 years, 4 months ago) by greg
Diff to previous 2.11 , to selected 2.24
fixed mixtures to work with materials
Fri Jun 4 17:03:11 1993 UTC (30 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.24
Sun Nov 22 17:54:00 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.9: +1 -7 lines
Diff to previous 2.9 , to selected 2.24
fixed bug where memory was allocated and discarded in tlalloc()
Sun Nov 22 11:46:46 1992 UTC (31 years, 5 months ago) by greg
Diff to previous 2.8 , to selected 2.24
minor improvement to freetext()
Tue Nov 10 10:33:43 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.7: +4 -3 lines
Diff to previous 2.7 , to selected 2.24
fixed bug for when free() steps on
Fri Oct 2 16:20:26 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.6: +0 -1 lines
Diff to previous 2.6 , to selected 2.24
Thu Jun 25 12:05:10 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.5: +11 -1 lines
Diff to previous 2.5 , to selected 2.24
fixed proportional spacing distances
Fri Jun 19 14:20:22 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.4: +15 -10 lines
Diff to previous 2.4 , to selected 2.24
fixed bug in inglyph() causing sloppy glyph boundaries
Fri Jun 19 13:07:48 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.3: +59 -32 lines
Diff to previous 2.3 , to selected 2.24
initial implementation of proportional fonts
Tue Jun 16 13:24:23 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.2: +6 -1 lines
Diff to previous 2.2 , to selected 2.24
added checking of extents to inglyph()
Sat Jun 6 07:40:23 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.1: +7 -95 lines
Diff to previous 2.1 , to selected 2.24
initial move of getfont to separate routine
Tue Nov 12 17:10:02 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.10 , to selected 2.24
Wed Oct 23 13:43:49 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.9: +3 -2 lines
Diff to previous 1.9 , to selected 2.24
Wed Aug 7 08:37:27 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.8: +5 -5 lines
Diff to previous 1.8 , to selected 2.24
fixed bug in text initialization
Tue Aug 6 09:04:41 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.7: +48 -29 lines
Diff to previous 1.7 , to selected 2.24
changed storage of text lines
Mon Aug 5 09:32:12 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.6: +140 -87 lines
Diff to previous 1.6 , to selected 2.24
fixed long-standing bug in slanted text
Mon Jul 22 13:02:27 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.5: +15 -5 lines
Diff to previous 1.5 , to selected 2.24
got rid of scanf() calls
Thu Jan 3 11:54:54 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 1.4 , to selected 2.24
fixed coordinate mapping in inglyph()
Sat Dec 15 15:03:40 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.3: +5 -2 lines
Diff to previous 1.3 , to selected 2.24
Thu Jul 27 22:25:17 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.2 , to selected 2.24
Changed getpath to check permissions
Tue Apr 11 13:30:35 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.1: +4 -3 lines
Diff to previous 1.1 , to selected 2.24
Thu Feb 2 10:41:47 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.24
