root/radiance/ray/src/rt/text.c
Revision: 2.25
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 3 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.24: +34 -24 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.25 static const char RCSid[] = "$Id: text.c,v 2.24 2004/02/12 18:55:50 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * text.c - functions for text patterns and mixtures.
6     */
7
8 greg 2.21 #include "copyright.h"
9 greg 2.20
10 greg 1.1 #include "ray.h"
11 greg 2.24 #include "paths.h"
12 greg 1.1 #include "otypes.h"
13 schorsch 2.25 #include "rtotypes.h"
14 greg 2.2 #include "font.h"
15
16 greg 1.1 /*
17     * A text pattern is specified as the text (a file or line),
18     * the upper left anchor point, the right motion vector, the down
19     * motion vector, and the foreground and background brightness.
20     * For a file, the description is as follows:
21     *
22     * modifier brighttext id
23     * 2 fontfile textfile
24     * 0
25 greg 2.4 * 11+
26 greg 1.1 * Ax Ay Az
27     * Rx Ry Rz
28     * Dx Dy Dz
29     * foreground background
30 greg 2.4 * [spacing]
31 greg 1.1 *
32     * For a single line, we use:
33     *
34     * modifier brighttext id
35     * N+2 fontfile . This is a line with N words...
36     * 0
37 greg 2.4 * 11+
38 greg 1.1 * Ax Ay Az
39     * Rx Ry Rz
40     * Dx Dy Dz
41     * foreground background
42 greg 2.4 * [spacing]
43 greg 1.1 *
44     * Colortext is identical, except colors are given rather than
45 greg 2.15 * brightnesses.
46 greg 1.1 *
47 greg 2.15 * Mixtext has foreground and background modifiers:
48     *
49 greg 1.1 * modifier mixtext id
50     * 4+ foremod backmod fontfile text..
51     * 0
52 greg 2.4 * 9+
53 greg 1.1 * Ax Ay Az
54     * Rx Ry Rz
55     * Dx Dy Dz
56 greg 2.4 * [spacing]
57 greg 1.1 */
58
59     #define fndx(m) ((m)->otype==MIX_TEXT ? 2 : 0)
60     #define tndx(m) ((m)->otype==MIX_TEXT ? 3 : 1)
61 greg 2.4 #define sndx(m) ((m)->otype==PAT_BTEXT ? 11 : \
62     (m)->otype==PAT_CTEXT ? 15 : 9)
63 greg 1.1
64 greg 1.8 typedef struct tline {
65     struct tline *next; /* pointer to next line */
66 greg 2.4 short *spc; /* character spacing */
67     int width; /* total line width */
68 greg 1.8 /* followed by the string */
69     } TLINE;
70
71 greg 1.9 #define TLSTR(l) ((char *)((l)+1))
72 greg 1.8
73 greg 1.7 typedef struct {
74     FVECT right, down; /* right and down unit vectors */
75     FONT *f; /* our font */
76 greg 1.8 TLINE tl; /* line list */
77 greg 1.7 } TEXT;
78
79 schorsch 2.25 static TLINE * tlalloc(char *s);
80     static TEXT * gettext(OBJREC *tm);
81     static int intext(FVECT p, OBJREC *m);
82     static int inglyph(double x, double y, GLYPH *gl);
83 greg 1.8
84 greg 1.1
85 schorsch 2.25 extern int
86     do_text(
87     register OBJREC *m,
88     RAY *r
89     )
90 greg 1.1 {
91 greg 1.10 FVECT v;
92 greg 1.1 int foreground;
93 greg 1.7 /* get transformed position */
94 greg 1.4 if (r->rox != NULL)
95     multp3(v, r->rop, r->rox->b.xfm);
96     else
97     VCOPY(v, r->rop);
98 greg 1.7 /* check if we are within a text glyph */
99     foreground = intext(v, m);
100 greg 1.1 /* modify */
101     if (m->otype == MIX_TEXT) {
102     OBJECT omod;
103     char *modname = m->oargs.sarg[foreground ? 0 : 1];
104     if (!strcmp(modname, VOIDID))
105     omod = OVOID;
106 gwlarson 2.18 else if ((omod = lastmod(objndx(m), modname)) == OVOID) {
107 greg 1.1 sprintf(errmsg, "undefined modifier \"%s\"", modname);
108     objerror(m, USER, errmsg);
109     }
110 greg 2.12 if (rayshade(r, omod)) {
111     if (m->omod != OVOID)
112     objerror(m, USER, "inappropriate modifier");
113     return(1);
114     }
115 greg 2.15 } else if (m->otype == PAT_BTEXT) {
116 greg 1.1 if (foreground)
117 greg 1.7 scalecolor(r->pcol, m->oargs.farg[9]);
118 greg 1.1 else
119 greg 1.7 scalecolor(r->pcol, m->oargs.farg[10]);
120 greg 1.1 } else { /* PAT_CTEXT */
121     COLOR cval;
122     if (foreground)
123 greg 1.7 setcolor(cval, m->oargs.farg[9],
124     m->oargs.farg[10],
125     m->oargs.farg[11]);
126 greg 1.1 else
127 greg 1.7 setcolor(cval, m->oargs.farg[12],
128     m->oargs.farg[13],
129     m->oargs.farg[14]);
130 greg 1.1 multcolor(r->pcol, cval);
131     }
132 greg 2.12 return(0);
133 greg 1.1 }
134
135
136 schorsch 2.25 static TLINE *
137     tlalloc( /* allocate and assign text line */
138     char *s
139     )
140 greg 1.8 {
141 greg 2.4 register int siz;
142 greg 1.8 register TLINE *tl;
143
144 greg 2.4 siz = strlen(s) + 1;
145     if ((tl=(TLINE *)malloc(sizeof(TLINE)+siz)) == NULL ||
146     (tl->spc=(short *)malloc(siz*sizeof(short))) == NULL)
147 greg 1.8 error(SYSTEM, "out of memory in tlalloc");
148     tl->next = NULL;
149     strcpy(TLSTR(tl), s);
150     return(tl);
151     }
152
153
154 schorsch 2.25 static TEXT *
155     gettext( /* get text structure for material */
156     register OBJREC *tm
157     )
158 greg 1.1 {
159 greg 1.7 #define R (tm->oargs.farg+3)
160     #define D (tm->oargs.farg+6)
161     FVECT DxR;
162     double d;
163 greg 1.1 FILE *fp;
164     char linbuf[512];
165 greg 1.8 TEXT *t;
166 greg 1.1 register int i;
167 greg 1.8 register TLINE *tlp;
168 greg 1.1 register char *s;
169
170 greg 1.7 if ((t = (TEXT *)tm->os) != NULL)
171     return(t);
172     /* check arguments */
173 greg 2.4 if (tm->oargs.nsargs - tndx(tm) < 1 || tm->oargs.nfargs < sndx(tm))
174 greg 1.7 objerror(tm, USER, "bad # arguments");
175     if ((t = (TEXT *)malloc(sizeof(TEXT))) == NULL)
176 greg 2.10 error(SYSTEM, "out of memory in gettext");
177 greg 1.7 /* compute vectors */
178     fcross(DxR, D, R);
179     fcross(t->right, DxR, D);
180 gregl 2.17 d = DOT(t->right,t->right);
181 gwlarson 2.19 if (d <= FTINY*FTINY*FTINY*FTINY)
182 gregl 2.17 objerror(tm, USER, "illegal motion vector");
183     d = DOT(D,D)/d;
184 greg 1.7 for (i = 0; i < 3; i++)
185     t->right[i] *= d;
186     fcross(t->down, R, DxR);
187 greg 1.9 d = DOT(R,R)/DOT(t->down,t->down);
188 greg 1.7 for (i = 0; i < 3; i++)
189     t->down[i] *= d;
190     /* get text */
191 greg 1.8 tlp = &t->tl;
192 greg 1.7 if (tm->oargs.nsargs - tndx(tm) > 1) { /* single line */
193     s = linbuf;
194     for (i = tndx(tm)+1; i < tm->oargs.nsargs; i++) {
195     strcpy(s, tm->oargs.sarg[i]);
196     s += strlen(s);
197     *s++ = ' ';
198 greg 1.1 }
199 greg 1.7 *--s = '\0';
200 greg 1.8 tlp->next = tlalloc(linbuf);
201     tlp = tlp->next;
202 greg 1.7 } else { /* text file */
203     if ((s = getpath(tm->oargs.sarg[tndx(tm)],
204 greg 2.22 getrlibpath(), R_OK)) == NULL) {
205 greg 1.7 sprintf(errmsg, "cannot find text file \"%s\"",
206     tm->oargs.sarg[tndx(tm)]);
207     error(USER, errmsg);
208     }
209     if ((fp = fopen(s, "r")) == NULL) {
210 greg 2.4 sprintf(errmsg, "cannot open text file \"%s\"", s);
211 greg 1.7 error(SYSTEM, errmsg);
212     }
213 greg 1.8 while (fgets(linbuf, sizeof(linbuf), fp) != NULL) {
214 greg 1.7 s = linbuf + strlen(linbuf) - 1;
215     if (*s == '\n')
216     *s = '\0';
217 greg 1.8 tlp->next = tlalloc(linbuf);
218     tlp = tlp->next;
219 greg 1.7 }
220     fclose(fp);
221 greg 1.1 }
222 greg 1.8 tlp->next = NULL;
223 greg 1.7 /* get the font */
224     t->f = getfont(tm->oargs.sarg[fndx(tm)]);
225 greg 2.4 /* compute character spacing */
226     i = sndx(tm);
227     d = i < tm->oargs.nfargs ? tm->oargs.farg[i] : 0.0;
228 greg 2.14 i = d * 255.0;
229 greg 2.6 t->tl.width = 0;
230 greg 2.4 for (tlp = t->tl.next; tlp != NULL; tlp = tlp->next) {
231     if (i < 0)
232     tlp->width = squeeztext(tlp->spc, TLSTR(tlp), t->f, -i);
233     else if (i > 0)
234     tlp->width = proptext(tlp->spc, TLSTR(tlp), t->f, i, 3);
235     else
236     tlp->width = uniftext(tlp->spc, TLSTR(tlp), t->f);
237 greg 2.6 if (tlp->width > t->tl.width)
238     t->tl.width = tlp->width;
239 greg 2.4 }
240 greg 1.7 /* we're done */
241     tm->os = (char *)t;
242     return(t);
243     #undef R
244     #undef D
245 greg 1.1 }
246
247
248 schorsch 2.25 extern void
249     freetext( /* free text structures associated with m */
250     OBJREC *m
251     )
252 greg 1.7 {
253 greg 2.9 register TEXT *tp;
254     register TLINE *tlp;
255 greg 1.7
256     tp = (TEXT *)m->os;
257     if (tp == NULL)
258     return;
259 greg 2.9 while ((tlp = tp->tl.next) != NULL) {
260     tp->tl.next = tlp->next;
261 greg 2.20 free((void *)tlp->spc);
262     free((void *)tlp);
263 greg 2.4 }
264 greg 2.20 freefont(tp->f); /* release font reference */
265     free((void *)tp);
266 greg 1.7 m->os = NULL;
267     }
268
269
270 schorsch 2.25 static int
271     intext( /* check to see if p is in text glyph */
272     FVECT p,
273     OBJREC *m
274     )
275 greg 1.7 {
276     register TEXT *tp;
277 greg 1.8 register TLINE *tlp;
278 greg 1.10 FVECT v;
279     double y, x;
280 greg 2.4 register int i, h;
281 greg 1.7 /* first, compute position in text */
282 greg 1.9 tp = gettext(m);
283 greg 1.7 v[0] = p[0] - m->oargs.farg[0];
284     v[1] = p[1] - m->oargs.farg[1];
285     v[2] = p[2] - m->oargs.farg[2];
286 greg 2.6 x = DOT(v, tp->right);
287     i = sndx(m);
288     if (i < m->oargs.nfargs)
289 greg 2.14 x *= tp->f->mwidth + 255.*fabs(m->oargs.farg[i]);
290 greg 2.6 else
291 greg 2.14 x *= 255.;
292 greg 2.6 h = x;
293 greg 2.4 i = y = DOT(v, tp->down);
294 greg 1.7 if (x < 0.0 || y < 0.0)
295     return(0);
296 greg 2.4 x -= (double)h;
297 greg 2.14 y = ((i+1) - y)*255.;
298 greg 2.4 /* find the line position */
299 greg 1.8 for (tlp = tp->tl.next; tlp != NULL; tlp = tlp->next)
300 greg 2.4 if (--i < 0)
301 greg 1.8 break;
302 greg 2.4 if (tlp == NULL || h >= tlp->width)
303 greg 1.7 return(0);
304 greg 2.4 for (i = 0; (h -= tlp->spc[i]) >= 0; i++)
305 greg 2.14 if (h < 255 && inglyph(h+x, y,
306 greg 2.4 tp->f->fg[TLSTR(tlp)[i]&0xff]))
307     return(1);
308     return(0);
309 greg 1.7 }
310
311
312 schorsch 2.25 static int
313     inglyph( /* (x,y) within font glyph gl? */
314     double x, /* real coordinates in range [0,255) */
315     double y,
316     register GLYPH *gl
317     )
318 greg 1.1 {
319     int n, ncross;
320 greg 2.5 int xlb, ylb;
321     int tv;
322 greg 2.2 register GORD *p0, *p1;
323 greg 1.1
324 greg 1.7 if (gl == NULL)
325 greg 1.1 return(0);
326 greg 2.5 xlb = x;
327     ylb = y;
328     if (gl->left > xlb || gl->right <= xlb || /* check extent */
329     gl->bottom > ylb || gl->top <= ylb)
330     return(0);
331     xlb = xlb<<1 | 1; /* add 1/2 to test points... */
332     ylb = ylb<<1 | 1; /* ...so no equal comparisons */
333 greg 2.2 n = gl->nverts; /* get # of vertices */
334     p0 = gvlist(gl) + 2*(n-1); /* connect last to first */
335     p1 = gvlist(gl);
336 greg 1.1 ncross = 0;
337     /* positive x axis cross test */
338     while (n--) {
339 greg 2.5 if ((p0[1]<<1 > ylb) ^ (p1[1]<<1 > ylb)) {
340 schorsch 2.23 tv = (p0[0]<<1 > xlb) | ((p1[0]<<1 > xlb) << 1);
341 greg 2.5 if (tv == 03)
342 greg 1.1 ncross++;
343 greg 2.5 else if (tv)
344 greg 1.1 ncross += (p1[1] > p0[1]) ^
345     ((p0[1]-y)*(p1[0]-x) >
346     (p0[0]-x)*(p1[1]-y));
347 greg 2.5 }
348 greg 1.1 p0 = p1;
349     p1 += 2;
350     }
351     return(ncross & 01);
352     }
