perf: Minor conditional optimizations
refactor: made font load errors non-fatal
Made error messages more consistent when library file not found
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
decreased epsilon for check of zero motion vector
added check for parallel or zero motion vectors
changed text(), which is reserved word on PowerPC, to do_text()
fixed bug for mixing non-materials
fixed problem with hexbit font (spacing from 256 to 255 per char)
fixed mixtures to work with materials
fixed bug where memory was allocated and discarded in tlalloc()
minor improvement to freetext()
fixed bug for when free() steps on
fixed proportional spacing distances
fixed bug in inglyph() causing sloppy glyph boundaries
initial implementation of proportional fonts
added checking of extents to inglyph()
initial move of getfont to separate routine
fixed bug in text initialization
changed storage of text lines
fixed long-standing bug in slanted text
got rid of scanf() calls
fixed coordinate mapping in inglyph()
changed handling of matrix transformations with new MAT4 & XF types dynamic allocation of ray transformations with newrayxf() added missing light source vector transformation to m_brdf.c
Changed getpath to check permissions
