root/radiance/ray/src/rt/t_func.c
Tue Mar 30 16:13:01 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.6: +7 -5 lines
Wed Mar 5 16:16:53 2003 UTC (22 years, 4 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 4 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.3: +57 -5 lines
Wed Jan 12 16:46:54 1994 UTC (31 years, 5 months ago) by greg
Mon Nov 25 09:50:59 1991 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +16 -34 lines
Diff to previous 2.1
Tue Nov 12 17:08:24 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.9
Thu Aug 8 11:29:51 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +1 -2 lines
Diff to previous 1.8
added contexts to function files
Sat Dec 15 15:03:38 1990 UTC (34 years, 6 months ago) by greg
Changes since 1.7: +16 -23 lines
Diff to previous 1.7
Thu Oct 5 07:23:20 1989 UTC (35 years, 9 months ago) by greg
Changes since 1.6: +0 -4 lines
Diff to previous 1.6
Eliminated need to initialize matrix for call to xf() and invxf()
Wed Apr 19 21:20:29 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.5: +3 -1 lines
Diff to previous 1.5
added loop invariant
Tue Apr 11 13:30:33 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.4: +3 -4 lines
Diff to previous 1.4
Tue Mar 14 11:02:35 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.3: +5 -9 lines
Diff to previous 1.3
eliminated superfluous test
Tue Mar 14 10:41:23 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.2
changed order of parameters to setmap() for consistency with xfm()
Tue Feb 21 14:56:22 1989 UTC (36 years, 4 months ago) by greg
Diff to previous 1.1
portability fixes
Thu Feb 2 10:41:46 1989 UTC (36 years, 5 months ago) by greg
