| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* t_func.c - routine for procedural textures.
| 9 |
| 10 |
* 4/8/86
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
| 16 |
* A procedural texture perturbs the surface normal
| 17 |
* at the point of intersection with an object. It has
| 18 |
* the form:
| 19 |
| 20 |
* modifier texfunc name
| 21 |
* 4+ xvarname yvarname zvarname filename xf
| 22 |
* 0
| 23 |
* n A1 A2 ..
| 24 |
| 25 |
* Filename is the name of the file where the variable definitions
| 26 |
* can be found. The list of real arguments can be accessed by
| 27 |
* definitions in the file. The xf is a transformation to get
| 28 |
* from the original coordinates to the current coordinates.
| 29 |
| 30 |
| 31 |
typedef struct {
| 32 |
struct {
| 33 |
double sca; /* scale factor */
| 34 |
double xfm[4][4]; /* transformation matrix */
| 35 |
} fore, back;
| 36 |
} XFORM;
| 37 |
| 38 |
| 39 |
t_func(m, r) /* compute texture for ray */
| 40 |
register OBJREC *m;
| 41 |
register RAY *r;
| 42 |
| 43 |
extern double varvalue();
| 44 |
extern int errno;
| 45 |
FVECT disp;
| 46 |
double d;
| 47 |
register XFORM *mxf;
| 48 |
register int i;
| 49 |
register char **sa;
| 50 |
| 51 |
if (m->oargs.nsargs < 4)
| 52 |
objerror(m, USER, "bad # arguments");
| 53 |
sa = m->oargs.sarg;
| 54 |
| 55 |
if ((mxf = (XFORM *)m->os) == NULL) {
| 56 |
mxf = (XFORM *)malloc(sizeof(XFORM));
| 57 |
if (mxf == NULL)
| 58 |
goto memerr;
| 59 |
if (xf(mxf->fore.xfm, &mxf->fore.sca,
| 60 |
m->oargs.nsargs-4, sa+4) != m->oargs.nsargs-4)
| 61 |
objerror(m, USER, "bad transform");
| 62 |
if (mxf->fore.sca < 0.0)
| 63 |
mxf->fore.sca = -mxf->fore.sca;
| 64 |
invxf(mxf->back.xfm, &mxf->back.sca,
| 65 |
m->oargs.nsargs-4, sa+4);
| 66 |
if (mxf->back.sca < 0.0)
| 67 |
mxf->back.sca = -mxf->back.sca;
| 68 |
m->os = (char *)mxf;
| 69 |
| 70 |
| 71 |
setmap(m, r, mxf->back.xfm, mxf->back.sca);
| 72 |
| 73 |
if (!vardefined(sa[0]))
| 74 |
loadfunc(sa[3]);
| 75 |
errno = 0;
| 76 |
for (i = 0; i < 3; i++)
| 77 |
disp[i] = varvalue(sa[i]);
| 78 |
if (errno) {
| 79 |
objerror(m, WARNING, "compute error");
| 80 |
return;
| 81 |
| 82 |
multv3(disp, disp, mxf->fore.xfm);
| 83 |
multv3(disp, disp, r->rofx);
| 84 |
d = 1.0 / (mxf->fore.sca * r->rofs);
| 85 |
| 86 |
r->pert[i] += disp[i] * d;
| 87 |
return;
| 88 |
memerr:
| 89 |
error(SYSTEM, "out of memory in t_func");
| 90 |
