1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* t_func.c - routine for procedural textures. |
9 |
10 |
* 4/8/86 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
16 |
* A procedural texture perturbs the surface normal |
17 |
* at the point of intersection with an object. It has |
18 |
* the form: |
19 |
20 |
* modifier texfunc name |
21 |
* 4+ xvarname yvarname zvarname filename xf |
22 |
* 0 |
23 |
* n A1 A2 .. |
24 |
25 |
* Filename is the name of the file where the variable definitions |
26 |
* can be found. The list of real arguments can be accessed by |
27 |
* definitions in the file. The xf is a transformation to get |
28 |
* from the original coordinates to the current coordinates. |
29 |
30 |
31 |
typedef struct { |
32 |
struct { |
33 |
double sca; /* scale factor */ |
34 |
double xfm[4][4]; /* transformation matrix */ |
35 |
} fore, back; |
36 |
} XFORM; |
37 |
38 |
39 |
t_func(m, r) /* compute texture for ray */ |
40 |
register OBJREC *m; |
41 |
register RAY *r; |
42 |
43 |
extern double varvalue(); |
44 |
extern int errno; |
45 |
FVECT disp; |
46 |
double d; |
47 |
register XFORM *mxf; |
48 |
register int i; |
49 |
register char **sa; |
50 |
51 |
if (m->oargs.nsargs < 4) |
52 |
objerror(m, USER, "bad # arguments"); |
53 |
sa = m->oargs.sarg; |
54 |
55 |
if ((mxf = (XFORM *)m->os) == NULL) { |
56 |
mxf = (XFORM *)malloc(sizeof(XFORM)); |
57 |
if (mxf == NULL) |
58 |
goto memerr; |
59 |
mxf->fore.sca = 1.0; |
60 |
setident4(mxf->fore.xfm); |
61 |
if (xf(mxf->fore.xfm, &mxf->fore.sca, |
62 |
m->oargs.nsargs-4, sa+4) != m->oargs.nsargs-4) |
63 |
objerror(m, USER, "bad transform"); |
64 |
if (mxf->fore.sca < 0.0) |
65 |
mxf->fore.sca = -mxf->fore.sca; |
66 |
mxf->back.sca = 1.0; |
67 |
setident4(mxf->back.xfm); |
68 |
invxf(mxf->back.xfm, &mxf->back.sca, |
69 |
m->oargs.nsargs-4, sa+4); |
70 |
if (mxf->back.sca < 0.0) |
71 |
mxf->back.sca = -mxf->back.sca; |
72 |
m->os = (char *)mxf; |
73 |
74 |
75 |
setmap(m, r, mxf->back.xfm, mxf->back.sca); |
76 |
77 |
if (!vardefined(sa[0])) |
78 |
loadfunc(sa[3]); |
79 |
errno = 0; |
80 |
for (i = 0; i < 3; i++) |
81 |
disp[i] = varvalue(sa[i]); |
82 |
if (errno) { |
83 |
objerror(m, WARNING, "compute error"); |
84 |
return; |
85 |
86 |
multv3(disp, disp, mxf->fore.xfm); |
87 |
multv3(disp, disp, r->rofx); |
88 |
d = 1.0 / (mxf->fore.sca * r->rofs); |
89 |
90 |
r->pert[i] += disp[i] * d; |
91 |
return; |
92 |
memerr: |
93 |
error(SYSTEM, "out of memory in t_func"); |
94 |
