root/radiance/ray/src/rt/t_func.c
Revision: 1.5
Committed: Tue Apr 11 13:30:33 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.4: +3 -4 lines
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * t_func.c - routine for procedural textures.
9 *
10 * 4/8/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * A procedural texture perturbs the surface normal
17 * at the point of intersection with an object. It has
18 * the form:
19 *
20 * modifier texfunc name
21 * 4+ xvarname yvarname zvarname filename xf
22 * 0
23 * n A1 A2 ..
24 *
25 * Filename is the name of the file where the variable definitions
26 * can be found. The list of real arguments can be accessed by
27 * definitions in the file. The xf is a transformation to get
28 * from the original coordinates to the current coordinates.
29 */
30
31 typedef struct {
32 struct {
33 double sca; /* scale factor */
34 double xfm[4][4]; /* transformation matrix */
35 } fore, back;
36 } XFORM;
37
38
39 t_func(m, r) /* compute texture for ray */
40 register OBJREC *m;
41 register RAY *r;
42 {
43 extern double varvalue();
44 extern int errno;
45 FVECT disp;
46 register XFORM *mxf;
47 register int i;
48 register char **sa;
49
50 if (m->oargs.nsargs < 4)
51 objerror(m, USER, "bad # arguments");
52 sa = m->oargs.sarg;
53
54 if ((mxf = (XFORM *)m->os) == NULL) {
55 mxf = (XFORM *)malloc(sizeof(XFORM));
56 if (mxf == NULL)
57 goto memerr;
58 mxf->fore.sca = 1.0;
59 setident4(mxf->fore.xfm);
60 if (xf(mxf->fore.xfm, &mxf->fore.sca,
61 m->oargs.nsargs-4, sa+4) != m->oargs.nsargs-4)
62 objerror(m, USER, "bad transform");
63 if (mxf->fore.sca < 0.0)
64 mxf->fore.sca = -mxf->fore.sca;
65 mxf->back.sca = 1.0;
66 setident4(mxf->back.xfm);
67 invxf(mxf->back.xfm, &mxf->back.sca,
68 m->oargs.nsargs-4, sa+4);
69 if (mxf->back.sca < 0.0)
70 mxf->back.sca = -mxf->back.sca;
71 m->os = (char *)mxf;
72 }
73
74 setmap(m, r, mxf->back.xfm, mxf->back.sca);
75
76 if (!vardefined(sa[0]))
77 loadfunc(sa[3]);
78 errno = 0;
79 for (i = 0; i < 3; i++)
80 disp[i] = varvalue(sa[i]);
81 if (errno) {
82 objerror(m, WARNING, "compute error");
83 return;
84 }
85 multv3(disp, disp, mxf->fore.xfm);
86 multv3(disp, disp, r->rofx);
87 for (i = 0; i < 3; i++)
88 r->pert[i] += disp[i] / (mxf->fore.sca * r->rofs);
89 return;
90 memerr:
91 error(SYSTEM, "out of memory in t_func");
92 }
