--- ray/src/rt/t_func.c 1989/04/19 21:20:29 1.6 +++ ray/src/rt/t_func.c 2003/02/25 02:47:23 2.5 @@ -1,17 +1,16 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: t_func.c,v 2.5 2003/02/25 02:47:23 greg Exp $"; #endif - /* * t_func.c - routine for procedural textures. - * - * 4/8/86 */ +#include "copyright.h" + #include "ray.h" +#include "func.h" + /* * A procedural texture perturbs the surface normal * at the point of intersection with an object. It has @@ -28,67 +27,36 @@ static char SCCSid[] = "$SunId$ LBL"; * from the original coordinates to the current coordinates. */ -typedef struct { - struct { - double sca; /* scale factor */ - double xfm[4][4]; /* transformation matrix */ - } fore, back; -} XFORM; - t_func(m, r) /* compute texture for ray */ register OBJREC *m; register RAY *r; { - extern double varvalue(); - extern int errno; FVECT disp; double d; - register XFORM *mxf; + register MFUNC *mf; register int i; - register char **sa; if (m->oargs.nsargs < 4) objerror(m, USER, "bad # arguments"); - sa = m->oargs.sarg; - - if ((mxf = (XFORM *)m->os) == NULL) { - mxf = (XFORM *)malloc(sizeof(XFORM)); - if (mxf == NULL) - goto memerr; - mxf->fore.sca = 1.0; - setident4(mxf->fore.xfm); - if (xf(mxf->fore.xfm, &mxf->fore.sca, - m->oargs.nsargs-4, sa+4) != m->oargs.nsargs-4) - objerror(m, USER, "bad transform"); - if (mxf->fore.sca < 0.0) - mxf->fore.sca = -mxf->fore.sca; - mxf->back.sca = 1.0; - setident4(mxf->back.xfm); - invxf(mxf->back.xfm, &mxf->back.sca, - m->oargs.nsargs-4, sa+4); - if (mxf->back.sca < 0.0) - mxf->back.sca = -mxf->back.sca; - m->os = (char *)mxf; - } - - setmap(m, r, mxf->back.xfm, mxf->back.sca); - - if (!vardefined(sa[0])) - loadfunc(sa[3]); + mf = getfunc(m, 3, 0x7, 1); + setfunc(m, r); errno = 0; - for (i = 0; i < 3; i++) - disp[i] = varvalue(sa[i]); - if (errno) { - objerror(m, WARNING, "compute error"); - return; + for (i = 0; i < 3; i++) { + disp[i] = evalue(mf->ep[i]); + if (errno) { + objerror(m, WARNING, "compute error"); + return(0); + } } - multv3(disp, disp, mxf->fore.xfm); - multv3(disp, disp, r->rofx); - d = 1.0 / (mxf->fore.sca * r->rofs); + if (mf->f != &unitxf) + multv3(disp, disp, mf->f->xfm); + if (r->rox != NULL) { + multv3(disp, disp, r->rox->f.xfm); + d = 1.0 / (mf->f->sca * r->rox->f.sca); + } else + d = 1.0 / mf->f->sca; for (i = 0; i < 3; i++) r->pert[i] += disp[i] * d; - return; -memerr: - error(SYSTEM, "out of memory in t_func"); + return(0); }
