root/radiance/ray/src/rt/t_func.c
Revision: 2.1
Committed: Tue Nov 12 17:08:24 1991 UTC (32 years, 7 months ago) by greg
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * t_func.c - routine for procedural textures.
9 *
10 * 4/8/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * A procedural texture perturbs the surface normal
17 * at the point of intersection with an object. It has
18 * the form:
19 *
20 * modifier texfunc name
21 * 4+ xvarname yvarname zvarname filename xf
22 * 0
23 * n A1 A2 ..
24 *
25 * Filename is the name of the file where the variable definitions
26 * can be found. The list of real arguments can be accessed by
27 * definitions in the file. The xf is a transformation to get
28 * from the original coordinates to the current coordinates.
29 */
30
31
32 t_func(m, r) /* compute texture for ray */
33 register OBJREC *m;
34 register RAY *r;
35 {
36 extern double varvalue();
37 extern int errno;
38 FVECT disp;
39 double d;
40 register FULLXF *mxf;
41 register int i;
42 register char **sa;
43
44 if (m->oargs.nsargs < 4)
45 objerror(m, USER, "bad # arguments");
46 sa = m->oargs.sarg;
47
48 if ((mxf = (FULLXF *)m->os) == NULL) {
49 mxf = (FULLXF *)malloc(sizeof(FULLXF));
50 if (mxf == NULL)
51 goto memerr;
52 if (fullxf(mxf, m->oargs.nsargs-4, sa+4) != m->oargs.nsargs-4)
53 objerror(m, USER, "bad transform");
54 if (mxf->f.sca < 0.0)
55 mxf->f.sca = -mxf->f.sca;
56 if (mxf->b.sca < 0.0)
57 mxf->b.sca = -mxf->b.sca;
58 m->os = (char *)mxf;
59 }
60
61 setmap(m, r, &mxf->b);
62
63 funcfile(sa[3]);
64 errno = 0;
65 for (i = 0; i < 3; i++)
66 disp[i] = varvalue(sa[i]);
67 if (errno) {
68 objerror(m, WARNING, "compute error");
69 return;
70 }
71 multv3(disp, disp, mxf->f.xfm);
72 if (r->rox != NULL) {
73 multv3(disp, disp, r->rox->f.xfm);
74 d = 1.0 / (mxf->f.sca * r->rox->f.sca);
75 } else
76 d = 1.0 / mxf->f.sca;
77 for (i = 0; i < 3; i++)
78 r->pert[i] += disp[i] * d;
79 return;
80 memerr:
81 error(SYSTEM, "out of memory in t_func");
82 }
