root/radiance/ray/src/rt/t_func.c
Tue Dec 3 19:36:58 2024 UTC (8 months ago) by greg
CVS Tags: HEAD, rad6R0
perf: Minor conditional optimizations
Tue Jul 8 18:25:00 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.9: +6 -6 lines
Sat Jun 9 07:16:47 2012 UTC (13 years, 1 month ago) by greg
Mon Oct 25 22:57:45 2010 UTC (14 years, 9 months ago) by greg
Tue Mar 30 16:13:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.6: +7 -5 lines
Wed Mar 5 16:16:53 2003 UTC (22 years, 5 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 5 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.3: +57 -5 lines
Wed Jan 12 16:46:54 1994 UTC (31 years, 7 months ago) by greg
Mon Nov 25 09:50:59 1991 UTC (33 years, 8 months ago) by greg
Changes since 2.1: +16 -34 lines
Tue Nov 12 17:08:24 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.9
Thu Aug 8 11:29:51 1991 UTC (34 years ago) by greg
Changes since 1.8: +1 -2 lines
Diff to previous 1.8
added contexts to function files
Sat Dec 15 15:03:38 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.7: +16 -23 lines
Diff to previous 1.7
Thu Oct 5 07:23:20 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.6: +0 -4 lines
Diff to previous 1.6
Eliminated need to initialize matrix for call to xf() and invxf()
Wed Apr 19 21:20:29 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.5: +3 -1 lines
Diff to previous 1.5
added loop invariant
Tue Apr 11 13:30:33 1989 UTC (36 years, 4 months ago) by greg
Changes since 1.4: +3 -4 lines
Diff to previous 1.4
Tue Mar 14 11:02:35 1989 UTC (36 years, 5 months ago) by greg
Changes since 1.3: +5 -9 lines
Diff to previous 1.3
eliminated superfluous test
Tue Mar 14 10:41:23 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.2
changed order of parameters to setmap() for consistency with xfm()
Tue Feb 21 14:56:22 1989 UTC (36 years, 5 months ago) by greg
Diff to previous 1.1
portability fixes
Thu Feb 2 10:41:46 1989 UTC (36 years, 6 months ago) by greg
