root/radiance/ray/src/rt/t_data.c
Wed Nov 15 18:02:53 2023 UTC (6 months, 1 week ago) by greg
Tue Jul 8 18:25:00 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.10: +5 -5 lines
Sat Jun 9 07:16:47 2012 UTC (11 years, 11 months ago) by greg
Changes since 2.9: +5 -5 lines
Mon Oct 25 22:57:45 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.7: +7 -6 lines
Wed Mar 5 16:16:53 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.4: +57 -5 lines
Wed Jan 12 16:46:53 1994 UTC (30 years, 4 months ago) by greg
Tue Jun 30 19:10:38 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +9 -11 lines
fixed bug associated with -DSMLFLT option
Mon Nov 25 09:50:54 1991 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +26 -47 lines
Tue Nov 12 17:08:34 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.7
Thu Aug 8 11:29:56 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.6: +1 -2 lines
Diff to previous 1.6
added contexts to function files
Sat Dec 15 15:03:42 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.5: +16 -23 lines
Diff to previous 1.5
Thu Oct 5 07:23:19 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +0 -4 lines
Diff to previous 1.4
Eliminated need to initialize matrix for call to xf() and invxf()
Wed Apr 19 21:20:28 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.3
added loop invariant
Tue Apr 11 13:30:37 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.2: +3 -4 lines
Diff to previous 1.2
Tue Mar 28 07:44:15 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1
brought calculation of nv outside if
Tue Mar 14 11:31:17 1989 UTC (35 years, 2 months ago) by greg
