1 |
/* Copyright (c) 1990 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* t_data.c - routine for stored textures |
9 |
10 |
* 6/4/86 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
#include "data.h" |
16 |
17 |
18 |
* A stored texture is specified as follows: |
19 |
20 |
* modifier texdata name |
21 |
* 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname v0 v1 .. xf |
22 |
* 0 |
23 |
* n A1 A2 .. An |
24 |
25 |
* Vfname is the name of the file where the variable definitions |
26 |
* can be found. The list of real arguments can be accessed by |
27 |
* definitions in the file. The dfnames are the data file |
28 |
* names. The dimensions of the data files and the number |
29 |
* of variables must match. The funcs take three arguments to produce |
30 |
* interpolated values from the file. The xf is a transformation |
31 |
* to get from the original coordinates to the current coordinates. |
32 |
33 |
34 |
35 |
t_data(m, r) /* interpolate texture data */ |
36 |
register OBJREC *m; |
37 |
RAY *r; |
38 |
39 |
extern double varvalue(), funvalue(), datavalue(); |
40 |
extern int errno; |
41 |
int nv; |
42 |
FVECT dval, disp; |
43 |
double pt[MAXDIM]; |
44 |
double d; |
45 |
DATARRAY *dp; |
46 |
register FULLXF *mxf; |
47 |
register char **sa; |
48 |
register int i; |
49 |
50 |
if (m->oargs.nsargs < 8) |
51 |
objerror(m, USER, "bad # arguments"); |
52 |
sa = m->oargs.sarg; |
53 |
54 |
for (i = 7; i < m->oargs.nsargs && sa[i][0] != '-'; i++) |
55 |
56 |
nv = i-7; |
57 |
if ((mxf = (FULLXF *)m->os) == NULL) { |
58 |
mxf = (FULLXF *)malloc(sizeof(FULLXF)); |
59 |
if (mxf == NULL) |
60 |
goto memerr; |
61 |
if (fullxf(mxf, m->oargs.nsargs-i, sa+i) != m->oargs.nsargs-i) |
62 |
objerror(m, USER, "bad transform"); |
63 |
if (mxf->f.sca < 0.0) |
64 |
mxf->f.sca = -mxf->f.sca; |
65 |
if (mxf->b.sca < 0.0) |
66 |
mxf->b.sca = -mxf->b.sca; |
67 |
m->os = (char *)mxf; |
68 |
69 |
70 |
setmap(m, r, &mxf->b); |
71 |
72 |
if (nv > MAXDIM) |
73 |
goto dimerr; |
74 |
if (!vardefined(sa[7])) |
75 |
loadfunc(sa[6]); |
76 |
errno = 0; |
77 |
for (i = 0; i < nv; i++) |
78 |
pt[i] = varvalue(sa[i+7]); |
79 |
if (errno) |
80 |
goto computerr; |
81 |
for (i = 0; i < 3; i++) { |
82 |
dp = getdata(sa[i+3]); |
83 |
if (dp->nd != nv) |
84 |
goto dimerr; |
85 |
dval[i] = datavalue(dp, pt); |
86 |
87 |
errno = 0; |
88 |
for (i = 0; i < 3; i++) |
89 |
disp[i] = funvalue(sa[i], 3, dval); |
90 |
if (errno) |
91 |
goto computerr; |
92 |
93 |
multv3(disp, disp, mxf->f.xfm); |
94 |
if (r->rox != NULL) { |
95 |
multv3(disp, disp, r->rox->f.xfm); |
96 |
d = 1.0 / (mxf->f.sca * r->rox->f.sca); |
97 |
} else |
98 |
d = 1.0 / mxf->f.sca; |
99 |
100 |
r->pert[i] += disp[i] * d; |
101 |
return; |
102 |
dimerr: |
103 |
objerror(m, USER, "dimension error"); |
104 |
memerr: |
105 |
error(SYSTEM, "out of memory in t_data"); |
106 |
computerr: |
107 |
objerror(m, WARNING, "compute error"); |
108 |
return; |
109 |
