--- ray/src/rt/t_data.c 1991/11/12 17:08:34 2.1 +++ ray/src/rt/t_data.c 2010/10/25 22:57:45 2.9 @@ -1,18 +1,16 @@ -/* Copyright (c) 1990 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: t_data.c,v 2.9 2010/10/25 22:57:45 greg Exp $"; #endif - /* * t_data.c - routine for stored textures - * - * 6/4/86 */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "data.h" +#include "func.h" +#include "rtotypes.h" /* * A stored texture is specified as follows: @@ -32,77 +30,53 @@ static char SCCSid[] = "$SunId$ LBL"; */ -t_data(m, r) /* interpolate texture data */ -register OBJREC *m; -RAY *r; +extern int +t_data( /* interpolate texture data */ + register OBJREC *m, + RAY *r +) { - extern double varvalue(), funvalue(), datavalue(); - extern int errno; int nv; - FVECT dval, disp; - double pt[MAXDIM]; + FVECT disp; + double dval[3], pt[MAXDIM]; double d; DATARRAY *dp; - register FULLXF *mxf; - register char **sa; + register MFUNC *mf; register int i; if (m->oargs.nsargs < 8) objerror(m, USER, "bad # arguments"); - sa = m->oargs.sarg; - - for (i = 7; i < m->oargs.nsargs && sa[i][0] != '-'; i++) - ; - nv = i-7; - if ((mxf = (FULLXF *)m->os) == NULL) { - mxf = (FULLXF *)malloc(sizeof(FULLXF)); - if (mxf == NULL) - goto memerr; - if (fullxf(mxf, m->oargs.nsargs-i, sa+i) != m->oargs.nsargs-i) - objerror(m, USER, "bad transform"); - if (mxf->f.sca < 0.0) - mxf->f.sca = -mxf->f.sca; - if (mxf->b.sca < 0.0) - mxf->b.sca = -mxf->b.sca; - m->os = (char *)mxf; - } - - setmap(m, r, &mxf->b); - - if (nv > MAXDIM) - goto dimerr; - funcfile(sa[6]); + dp = getdata(m->oargs.sarg[3]); + i = (1 << (nv = dp->nd)) - 1; + mf = getfunc(m, 6, i<<7, 1); + setfunc(m, r); errno = 0; for (i = 0; i < nv; i++) - pt[i] = varvalue(sa[i+7]); - if (errno) + pt[i] = evalue(mf->ep[i]); + if (errno == EDOM || errno == ERANGE) goto computerr; - for (i = 0; i < 3; i++) { - dp = getdata(sa[i+3]); + dval[0] = datavalue(dp, pt); + for (i = 1; i < 3; i++) { + dp = getdata(m->oargs.sarg[i+3]); if (dp->nd != nv) - goto dimerr; + objerror(m, USER, "dimension error"); dval[i] = datavalue(dp, pt); } errno = 0; for (i = 0; i < 3; i++) - disp[i] = funvalue(sa[i], 3, dval); - if (errno) + disp[i] = funvalue(m->oargs.sarg[i], 3, dval); + if (errno == EDOM || errno == ERANGE) goto computerr; - - multv3(disp, disp, mxf->f.xfm); + if (mf->f != &unitxf) + multv3(disp, disp, mf->f->xfm); if (r->rox != NULL) { multv3(disp, disp, r->rox->f.xfm); - d = 1.0 / (mxf->f.sca * r->rox->f.sca); + d = 1.0 / (mf->f->sca * r->rox->f.sca); } else - d = 1.0 / mxf->f.sca; - for (i = 0; i < 3; i++) - r->pert[i] += disp[i] * d; - return; -dimerr: - objerror(m, USER, "dimension error"); -memerr: - error(SYSTEM, "out of memory in t_data"); + d = 1.0 / mf->f->sca; + VSUM(r->pert, r->pert, disp, d); + return(0); computerr: objerror(m, WARNING, "compute error"); - return; + return(0); }
