| 1 |
/* Copyright (c) 1989 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* t_data.c - routine for stored textures
| 9 |
| 10 |
* 6/4/86
| 11 |
| 12 |
| 13 |
#include "ray.h"
| 14 |
| 15 |
#include "data.h"
| 16 |
| 17 |
| 18 |
* A stored texture is specified as follows:
| 19 |
| 20 |
* modifier texdata name
| 21 |
* 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname v0 v1 .. xf
| 22 |
* 0
| 23 |
* n A1 A2 .. An
| 24 |
| 25 |
* Vfname is the name of the file where the variable definitions
| 26 |
* can be found. The list of real arguments can be accessed by
| 27 |
* definitions in the file. The dfnames are the data file
| 28 |
* names. The dimensions of the data files and the number
| 29 |
* of variables must match. The funcs take three arguments to produce
| 30 |
* interpolated values from the file. The xf is a transformation
| 31 |
* to get from the original coordinates to the current coordinates.
| 32 |
| 33 |
| 34 |
typedef struct {
| 35 |
struct {
| 36 |
double sca; /* scale factor */
| 37 |
double xfm[4][4]; /* transformation matrix */
| 38 |
} fore, back;
| 39 |
} XFORM;
| 40 |
| 41 |
| 42 |
t_data(m, r) /* interpolate texture data */
| 43 |
register OBJREC *m;
| 44 |
RAY *r;
| 45 |
| 46 |
extern double varvalue(), funvalue(), datavalue();
| 47 |
extern int errno;
| 48 |
int nv;
| 49 |
FVECT dval, disp;
| 50 |
double pt[MAXDIM];
| 51 |
double d;
| 52 |
DATARRAY *dp;
| 53 |
register XFORM *mxf;
| 54 |
register char **sa;
| 55 |
register int i;
| 56 |
| 57 |
if (m->oargs.nsargs < 8)
| 58 |
objerror(m, USER, "bad # arguments");
| 59 |
sa = m->oargs.sarg;
| 60 |
| 61 |
for (i = 7; i < m->oargs.nsargs && sa[i][0] != '-'; i++)
| 62 |
| 63 |
nv = i-7;
| 64 |
if ((mxf = (XFORM *)m->os) == NULL) {
| 65 |
mxf = (XFORM *)malloc(sizeof(XFORM));
| 66 |
if (mxf == NULL)
| 67 |
goto memerr;
| 68 |
mxf->fore.sca = 1.0;
| 69 |
setident4(mxf->fore.xfm);
| 70 |
if (xf(mxf->fore.xfm, &mxf->fore.sca,
| 71 |
m->oargs.nsargs-i, sa+i) != m->oargs.nsargs-i)
| 72 |
objerror(m, USER, "bad transform");
| 73 |
if (mxf->fore.sca < 0.0)
| 74 |
mxf->fore.sca = -mxf->fore.sca;
| 75 |
mxf->back.sca = 1.0;
| 76 |
setident4(mxf->back.xfm);
| 77 |
invxf(mxf->back.xfm, &mxf->back.sca,
| 78 |
m->oargs.nsargs-i, sa+i);
| 79 |
if (mxf->back.sca < 0.0)
| 80 |
mxf->back.sca = -mxf->back.sca;
| 81 |
m->os = (char *)mxf;
| 82 |
| 83 |
| 84 |
setmap(m, r, mxf->back.xfm, mxf->back.sca);
| 85 |
| 86 |
if (nv > MAXDIM)
| 87 |
goto dimerr;
| 88 |
if (!vardefined(sa[7]))
| 89 |
loadfunc(sa[6]);
| 90 |
errno = 0;
| 91 |
for (i = 0; i < nv; i++)
| 92 |
pt[i] = varvalue(sa[i+7]);
| 93 |
if (errno)
| 94 |
goto computerr;
| 95 |
for (i = 0; i < 3; i++) {
| 96 |
dp = getdata(sa[i+3]);
| 97 |
if (dp->nd != nv)
| 98 |
goto dimerr;
| 99 |
dval[i] = datavalue(dp, pt);
| 100 |
| 101 |
errno = 0;
| 102 |
| 103 |
disp[i] = funvalue(sa[i], 3, dval);
| 104 |
if (errno)
| 105 |
goto computerr;
| 106 |
| 107 |
multv3(disp, disp, mxf->fore.xfm);
| 108 |
multv3(disp, disp, r->rofx);
| 109 |
d = 1.0 / (mxf->fore.sca * r->rofs);
| 110 |
| 111 |
r->pert[i] += disp[i] * d;
| 112 |
return;
| 113 |
dimerr:
| 114 |
objerror(m, USER, "dimension error");
| 115 |
memerr:
| 116 |
error(SYSTEM, "out of memory in t_data");
| 117 |
computerr:
| 118 |
objerror(m, WARNING, "compute error");
| 119 |
return;
| 120 |
