root/radiance/ray/src/rt/t_data.c
Revision: 2.5
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.4: +57 -5 lines
5 * t_data.c - routine for stored textures
6 */
7
8 /* ====================================================================
9 * The Radiance Software License, Version 1.0
10 *
11 * Copyright (c) 1990 - 2002 The Regents of the University of California,
12 * through Lawrence Berkeley National Laboratory. All rights reserved.
13 *
14 * Redistribution and use in source and binary forms, with or without
15 * modification, are permitted provided that the following conditions
16 * are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 *
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in
23 * the documentation and/or other materials provided with the
24 * distribution.
25 *
26 * 3. The end-user documentation included with the redistribution,
27 * if any, must include the following acknowledgment:
28 * "This product includes Radiance software
29 * (http://radsite.lbl.gov/)
30 * developed by the Lawrence Berkeley National Laboratory
31 * (http://www.lbl.gov/)."
32 * Alternately, this acknowledgment may appear in the software itself,
33 * if and wherever such third-party acknowledgments normally appear.
34 *
35 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
36 * and "The Regents of the University of California" must
37 * not be used to endorse or promote products derived from this
38 * software without prior written permission. For written
39 * permission, please contact [email protected].
40 *
41 * 5. Products derived from this software may not be called "Radiance",
42 * nor may "Radiance" appear in their name, without prior written
43 * permission of Lawrence Berkeley National Laboratory.
44 *
45 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
46 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
47 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
48 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
49 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
50 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
51 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
52 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
53 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
54 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
55 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
56 * SUCH DAMAGE.
57 * ====================================================================
58 *
59 * This software consists of voluntary contributions made by many
60 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
61 * information on Lawrence Berkeley National Laboratory, please see
62 * <http://www.lbl.gov/>.
63 */
64
65 #include "ray.h"
66
67 #include "data.h"
68
69 #include "func.h"
70
71 /*
72 * A stored texture is specified as follows:
73 *
74 * modifier texdata name
75 * 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname v0 v1 .. xf
76 * 0
77 * n A1 A2 .. An
78 *
79 * Vfname is the name of the file where the variable definitions
80 * can be found. The list of real arguments can be accessed by
81 * definitions in the file. The dfnames are the data file
82 * names. The dimensions of the data files and the number
83 * of variables must match. The funcs take three arguments to produce
84 * interpolated values from the file. The xf is a transformation
85 * to get from the original coordinates to the current coordinates.
86 */
87
88
89 t_data(m, r) /* interpolate texture data */
90 register OBJREC *m;
91 RAY *r;
92 {
93 int nv;
94 FVECT disp;
95 double dval[3], pt[MAXDIM];
96 double d;
97 DATARRAY *dp;
98 register MFUNC *mf;
99 register int i;
100
101 if (m->oargs.nsargs < 8)
102 objerror(m, USER, "bad # arguments");
103 dp = getdata(m->oargs.sarg[3]);
104 i = (1 << (nv = dp->nd)) - 1;
105 mf = getfunc(m, 6, i<<7, 1);
106 setfunc(m, r);
107 errno = 0;
108 for (i = 0; i < nv; i++)
109 pt[i] = evalue(mf->ep[i]);
110 if (errno)
111 goto computerr;
112 dval[0] = datavalue(dp, pt);
113 for (i = 1; i < 3; i++) {
114 dp = getdata(m->oargs.sarg[i+3]);
115 if (dp->nd != nv)
116 objerror(m, USER, "dimension error");
117 dval[i] = datavalue(dp, pt);
118 }
119 errno = 0;
120 for (i = 0; i < 3; i++)
121 disp[i] = funvalue(m->oargs.sarg[i], 3, dval);
122 if (errno)
123 goto computerr;
124 if (mf->f != &unitxf)
125 multv3(disp, disp, mf->f->xfm);
126 if (r->rox != NULL) {
127 multv3(disp, disp, r->rox->f.xfm);
128 d = 1.0 / (mf->f->sca * r->rox->f.sca);
129 } else
130 d = 1.0 / mf->f->sca;
131 for (i = 0; i < 3; i++)
132 r->pert[i] += disp[i] * d;
133 return(0);
134 computerr:
135 objerror(m, WARNING, "compute error");
136 return(0);
137 }
