root/radiance/ray/src/rt/t_data.c
Revision: 1.2
Committed: Tue Mar 28 07:44:15 1989 UTC (36 years, 1 month ago) by greg
brought calculation of nv outside if
1 /* Copyright (c) 1989 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * t_data.c - routine for stored textures
9 *
10 * 6/4/86
11 */
12
13 #include "ray.h"
14
15 #include "data.h"
16
17 /*
18 * A stored texture is specified as follows:
19 *
20 * modifier texdata name
21 * 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname v0 v1 .. xf
22 * 0
23 * n A1 A2 .. An
24 *
25 * Vfname is the name of the file where the variable definitions
26 * can be found. The list of real arguments can be accessed by
27 * definitions in the file. The dfnames are the data file
28 * names. The dimensions of the data files and the number
29 * of variables must match. The funcs take three arguments to produce
30 * interpolated values from the file. The xf is a transformation
31 * to get from the original coordinates to the current coordinates.
32 */
33
34 typedef struct {
35 struct {
36 double sca; /* scale factor */
37 double xfm[4][4]; /* transformation matrix */
38 } fore, back;
39 } XFORM;
40
41
42 t_data(m, r) /* interpolate texture data */
43 register OBJREC *m;
44 RAY *r;
45 {
46 extern double varvalue(), funvalue(), datavalue();
47 extern int errno;
48 int nv;
49 FVECT dval, disp;
50 double pt[MAXDIM];
51 DATARRAY *dp;
52 register XFORM *mxf;
53 register char **sa;
54 register int i;
55
56 if (m->oargs.nsargs < 8)
57 objerror(m, USER, "bad # arguments");
58 sa = m->oargs.sarg;
59
60 for (i = 7; i < m->oargs.nsargs && sa[i][0] != '-'; i++)
61 ;
62 nv = i-7;
63 if ((mxf = (XFORM *)m->os) == NULL) {
64 mxf = (XFORM *)malloc(sizeof(XFORM));
65 if (mxf == NULL)
66 goto memerr;
67 mxf->fore.sca = 1.0;
68 setident4(mxf->fore.xfm);
69 if (xf(mxf->fore.xfm, &mxf->fore.sca,
70 m->oargs.nsargs-i, sa+i) != m->oargs.nsargs-i)
71 objerror(m, USER, "bad transform");
72 if (mxf->fore.sca < 0.0)
73 mxf->fore.sca = -mxf->fore.sca;
74 mxf->back.sca = 1.0;
75 setident4(mxf->back.xfm);
76 invxf(mxf->back.xfm, &mxf->back.sca,
77 m->oargs.nsargs-i, sa+i);
78 if (mxf->back.sca < 0.0)
79 mxf->back.sca = -mxf->back.sca;
80 m->os = (char *)mxf;
81 }
82
83 setmap(m, r, mxf->back.xfm, mxf->back.sca);
84
85 if (nv > MAXDIM)
86 goto dimerr;
87 if (!vardefined(sa[7]))
88 loadfunc(sa[6]);
89 errno = 0;
90 for (i = 0; i < nv; i++)
91 pt[i] = varvalue(sa[i+7]);
92 if (errno)
93 goto computerr;
94 for (i = 0; i < 3; i++) {
95 dp = getdata(sa[i+3]);
96 if (dp->nd != nv)
97 goto dimerr;
98 dval[i] = datavalue(dp, pt);
99 }
100 errno = 0;
101 for (i = 0; i < 3; i++)
102 disp[i] = funvalue(sa[i], 3, dval);
103 if (errno)
104 goto computerr;
105
106 for (i = 0; i < 3; i++)
107 r->pert[i] += ( disp[0]*mxf->fore.xfm[0][i] +
108 disp[1]*mxf->fore.xfm[1][i] +
109 disp[2]*mxf->fore.xfm[2][i] )
110 / mxf->fore.sca;
111 return;
112 dimerr:
113 objerror(m, USER, "dimension error");
114 memerr:
115 error(SYSTEM, "out of memory in t_data");
116 computerr:
117 objerror(m, WARNING, "compute error");
118 return;
119 }
