root/radiance/ray/src/rt/t_data.c
Changes since 2.7: +7 -6 lines
Diff to previous 2.7 , to selected 1.7
Wed Mar 5 16:16:53 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 2.6 , to selected 1.7
Diff to previous 2.5 , to selected 1.7
Changes since 2.4: +57 -5 lines
Diff to previous 2.4 , to selected 1.7
Wed Jan 12 16:46:53 1994 UTC (30 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 1.7
Tue Jun 30 19:10:38 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.2: +9 -11 lines
Diff to previous 2.2 , to selected 1.7
fixed bug associated with -DSMLFLT option
Mon Nov 25 09:50:54 1991 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +26 -47 lines
Diff to previous 2.1 , to selected 1.7
Tue Nov 12 17:08:34 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.7
Revision 1.7 - (view) (download) (annotate) - [selected]
Thu Aug 8 11:29:56 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.6: +1 -2 lines
Diff to previous 1.6
added contexts to function files
Sat Dec 15 15:03:42 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.5: +16 -23 lines
Thu Oct 5 07:23:19 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +0 -4 lines
Eliminated need to initialize matrix for call to xf() and invxf()
Wed Apr 19 21:20:28 1989 UTC (35 years ago) by greg
added loop invariant
Tue Apr 11 13:30:37 1989 UTC (35 years ago) by greg
Changes since 1.2: +3 -4 lines
Tue Mar 28 07:44:15 1989 UTC (35 years, 1 month ago) by greg
brought calculation of nv outside if
Tue Mar 14 11:31:17 1989 UTC (35 years, 1 month ago) by greg
Diff to selected 1.7
