root/radiance/ray/src/rt/t_data.c
Revision: 2.3
Committed: Tue Jun 30 19:10:38 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.2: +9 -11 lines
fixed bug associated with -DSMLFLT option
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * t_data.c - routine for stored textures
9 *
10 * 6/4/86
11 */
12
13 #include "ray.h"
14
15 #include "data.h"
16
17 #include "func.h"
18
19 /*
20 * A stored texture is specified as follows:
21 *
22 * modifier texdata name
23 * 8+ xfunc yfunc zfunc xdfname ydfname zdfname vfname v0 v1 .. xf
24 * 0
25 * n A1 A2 .. An
26 *
27 * Vfname is the name of the file where the variable definitions
28 * can be found. The list of real arguments can be accessed by
29 * definitions in the file. The dfnames are the data file
30 * names. The dimensions of the data files and the number
31 * of variables must match. The funcs take three arguments to produce
32 * interpolated values from the file. The xf is a transformation
33 * to get from the original coordinates to the current coordinates.
34 */
35
36
37 t_data(m, r) /* interpolate texture data */
38 register OBJREC *m;
39 RAY *r;
40 {
41 int nv;
42 FVECT disp;
43 double dval[3], pt[MAXDIM];
44 double d;
45 DATARRAY *dp;
46 register MFUNC *mf;
47 register int i;
48
49 if (m->oargs.nsargs < 8)
50 objerror(m, USER, "bad # arguments");
51 dp = getdata(m->oargs.sarg[3]);
52 i = (1 << (nv = dp->nd)) - 1;
53 mf = getfunc(m, 6, i<<7, 1);
54 setfunc(m, r);
55 errno = 0;
56 for (i = 0; i < nv; i++)
57 pt[i] = evalue(mf->ep[i]);
58 if (errno)
59 goto computerr;
60 dval[0] = datavalue(dp, pt);
61 for (i = 1; i < 3; i++) {
62 dp = getdata(m->oargs.sarg[i+3]);
63 if (dp->nd != nv)
64 objerror(m, USER, "dimension error");
65 dval[i] = datavalue(dp, pt);
66 }
67 errno = 0;
68 for (i = 0; i < 3; i++)
69 disp[i] = funvalue(m->oargs.sarg[i], 3, dval);
70 if (errno)
71 goto computerr;
72 if (mf->f != &unitxf)
73 multv3(disp, disp, mf->f->xfm);
74 if (r->rox != NULL) {
75 multv3(disp, disp, r->rox->f.xfm);
76 d = 1.0 / (mf->f->sca * r->rox->f.sca);
77 } else
78 d = 1.0 / mf->f->sca;
79 for (i = 0; i < 3; i++)
80 r->pert[i] += disp[i] * d;
81 return;
82 computerr:
83 objerror(m, WARNING, "compute error");
84 return;
85 }
