root/radiance/ray/src/rt/sundev.c
Revision 2.7
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +0 -0 lines
FILE REMOVED
Tue Nov 11 20:03:01 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.5: +8 -10 lines
Wed Oct 26 10:04:20 1994 UTC (30 years, 7 months ago) by greg
changed getcombuf() to tocombuf() for multiple commands
Tue Sep 20 15:46:37 1994 UTC (30 years, 8 months ago) by greg
changed GAMMA environment variable to DISPLAY_GAMMA
Fri Jun 4 14:48:21 1993 UTC (32 years ago) by greg
added math.h for atof() usage
Wed Jun 24 09:12:54 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.1
Tue Nov 12 17:09:03 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.17
Tue Jun 26 09:00:21 1990 UTC (34 years, 11 months ago) by greg
Diff to previous 1.16
Tue Mar 6 18:41:34 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.15: +18 -17 lines
Diff to previous 1.15
final fixes for menu quit
Tue Mar 6 18:22:25 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.14: +21 -6 lines
Diff to previous 1.14
fixed menu quit and resize handling
Tue Mar 6 17:44:40 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.13: +27 -11 lines
Diff to previous 1.13
Tue Mar 6 16:34:05 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.12: +5 -2 lines
Diff to previous 1.12
fixed event handling in sun_comin()
Thu Feb 22 12:39:27 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.11: +33 -8 lines
Diff to previous 1.11
Thu Feb 22 11:46:18 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.10
Tue Jan 30 11:37:44 1990 UTC (35 years, 4 months ago) by greg
Diff to previous 1.9
Mon Jan 8 14:55:51 1990 UTC (35 years, 5 months ago) by greg
Diff to previous 1.8
added pixel aspect ratio
Wed Oct 25 15:43:06 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.7: +66 -121 lines
Diff to previous 1.7
Tue Oct 3 16:50:59 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.6: +3 -0 lines
Diff to previous 1.6
Fixed tty subwindow exiting
Tue Oct 3 14:06:53 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.5: +4 -5 lines
Diff to previous 1.5
Changed calling conventions slightly and added custom color map.
Tue Oct 3 11:10:04 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.4: +26 -26 lines
Diff to previous 1.4
Improved color table allocation, second cut.
Mon Oct 2 17:12:36 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.3: +27 -144 lines
Diff to previous 1.3
Mon Apr 17 10:08:14 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +25 -26 lines
Diff to previous 1.2
fixed bug in sun_getcur and added some error checking
Sat Apr 15 09:49:24 1989 UTC (36 years, 1 month ago) by greg
Changed exit signal from hangup to broken pipe
Thu Feb 2 10:41:45 1989 UTC (36 years, 4 months ago) by greg
