1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: srcsupp.c,v 2.20 2014/06/22 18:05:28 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Support routines for source objects and materials |
6 |
7 |
* External symbols declared in source.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "ray.h" |
13 |
14 |
#include "otypes.h" |
15 |
16 |
#include "source.h" |
17 |
18 |
#include "cone.h" |
19 |
20 |
#include "face.h" |
21 |
22 |
#define SRCINC 32 /* realloc increment for array */ |
23 |
24 |
SRCREC *source = NULL; /* our list of sources */ |
25 |
int nsources = 0; /* the number of sources */ |
26 |
27 |
SRCFUNC sfun[NUMOTYPE]; /* source dispatch table */ |
28 |
29 |
30 |
void |
31 |
initstypes(void) /* initialize source dispatch table */ |
32 |
33 |
extern VSMATERIAL mirror_vs, direct1_vs, direct2_vs; |
34 |
static SOBJECT fsobj = {fsetsrc, flatpart, fgetplaneq, fgetmaxdisk}; |
35 |
static SOBJECT ssobj = {ssetsrc, nopart}; |
36 |
static SOBJECT sphsobj = {sphsetsrc, nopart}; |
37 |
static SOBJECT cylsobj = {cylsetsrc, cylpart}; |
38 |
static SOBJECT rsobj = {rsetsrc, flatpart, rgetplaneq, rgetmaxdisk}; |
39 |
40 |
sfun[MAT_MIRROR].mf = &mirror_vs; |
41 |
sfun[MAT_DIRECT1].mf = &direct1_vs; |
42 |
sfun[MAT_DIRECT2].mf = &direct2_vs; |
43 |
sfun[OBJ_FACE].of = &fsobj; |
44 |
sfun[OBJ_SOURCE].of = &ssobj; |
45 |
sfun[OBJ_SPHERE].of = &sphsobj; |
46 |
sfun[OBJ_CYLINDER].of = &cylsobj; |
47 |
sfun[OBJ_RING].of = &rsobj; |
48 |
49 |
50 |
51 |
int |
52 |
newsource(void) /* allocate new source in our array */ |
53 |
54 |
if (nsources == 0) |
55 |
source = (SRCREC *)malloc(SRCINC*sizeof(SRCREC)); |
56 |
else if (nsources%SRCINC == 0) |
57 |
source = (SRCREC *)realloc((void *)source, |
58 |
(unsigned)(nsources+SRCINC)*sizeof(SRCREC)); |
59 |
if (source == NULL) |
60 |
return(-1); |
61 |
source[nsources].sflags = 0; |
62 |
source[nsources].nhits = 1; |
63 |
source[nsources].ntests = 2; /* initial hit probability = 50% */ |
64 |
#if SHADCACHE |
65 |
source[nsources].obscache = NULL; |
66 |
#endif |
67 |
return(nsources++); |
68 |
69 |
70 |
71 |
void |
72 |
setflatss( /* set sampling for a flat source */ |
73 |
SRCREC *src |
74 |
75 |
76 |
double mult; |
77 |
int i; |
78 |
79 |
getperpendicular(src->ss[SU], src->snorm); |
80 |
mult = .5 * sqrt( src->ss2 ); |
81 |
for (i = 0; i < 3; i++) |
82 |
src->ss[SU][i] *= mult; |
83 |
fcross(src->ss[SV], src->snorm, src->ss[SU]); |
84 |
85 |
86 |
87 |
void |
88 |
fsetsrc( /* set a face as a source */ |
89 |
SRCREC *src, |
90 |
OBJREC *so |
91 |
92 |
93 |
FACE *f; |
94 |
int i, j; |
95 |
double d; |
96 |
97 |
src->sa.success = 2*AIMREQT-1; /* bitch on second failure */ |
98 |
src->so = so; |
99 |
/* get the face */ |
100 |
f = getface(so); |
101 |
if (f->area == 0.0) |
102 |
objerror(so, USER, "zero source area"); |
103 |
/* find the center */ |
104 |
for (j = 0; j < 3; j++) { |
105 |
src->sloc[j] = 0.0; |
106 |
for (i = 0; i < f->nv; i++) |
107 |
src->sloc[j] += VERTEX(f,i)[j]; |
108 |
src->sloc[j] /= (double)f->nv; |
109 |
110 |
if (!inface(src->sloc, f)) |
111 |
objerror(so, USER, "cannot hit source center"); |
112 |
src->sflags |= SFLAT; |
113 |
VCOPY(src->snorm, f->norm); |
114 |
src->ss2 = f->area; |
115 |
/* find maximum radius */ |
116 |
src->srad = 0.; |
117 |
for (i = 0; i < f->nv; i++) { |
118 |
d = dist2(VERTEX(f,i), src->sloc); |
119 |
if (d > src->srad) |
120 |
src->srad = d; |
121 |
122 |
src->srad = sqrt(src->srad); |
123 |
/* compute size vectors */ |
124 |
if (f->nv == 4) /* parallelogram case */ |
125 |
126 |
src->ss[SU][j] = .5*(VERTEX(f,1)[j]-VERTEX(f,0)[j]); |
127 |
src->ss[SV][j] = .5*(VERTEX(f,3)[j]-VERTEX(f,0)[j]); |
128 |
129 |
else |
130 |
setflatss(src); |
131 |
132 |
133 |
134 |
void |
135 |
ssetsrc( /* set a source as a source */ |
136 |
SRCREC *src, |
137 |
OBJREC *so |
138 |
139 |
140 |
double theta; |
141 |
142 |
143 |
src->so = so; |
144 |
if (so->oargs.nfargs != 4) |
145 |
objerror(so, USER, "bad arguments"); |
146 |
src->sflags |= (SDISTANT|SCIR); |
147 |
VCOPY(src->sloc, so->oargs.farg); |
148 |
if (normalize(src->sloc) == 0.0) |
149 |
objerror(so, USER, "zero direction"); |
150 |
theta = PI/180.0/2.0 * so->oargs.farg[3]; |
151 |
if (theta <= FTINY) |
152 |
objerror(so, USER, "zero size"); |
153 |
src->ss2 = 2.0*PI * (1.0 - cos(theta)); |
154 |
/* the following is approximate */ |
155 |
src->srad = sqrt(src->ss2/PI); |
156 |
VCOPY(src->snorm, src->sloc); |
157 |
setflatss(src); /* hey, whatever works */ |
158 |
src->ss[SW][0] = src->ss[SW][1] = src->ss[SW][2] = 0.0; |
159 |
160 |
161 |
162 |
void |
163 |
sphsetsrc( /* set a sphere as a source */ |
164 |
SRCREC *src, |
165 |
OBJREC *so |
166 |
167 |
168 |
int i; |
169 |
170 |
171 |
src->so = so; |
172 |
173 |
objerror(so, USER, "bad # arguments"); |
174 |
if (so->oargs.farg[3] <= FTINY) |
175 |
objerror(so, USER, "illegal source radius"); |
176 |
src->sflags |= SCIR; |
177 |
178 |
src->srad = so->oargs.farg[3]; |
179 |
src->ss2 = PI * src->srad * src->srad; |
180 |
181 |
src->ss[SU][i] = src->ss[SV][i] = src->ss[SW][i] = 0.0; |
182 |
183 |
src->ss[i][i] = 0.7236 * so->oargs.farg[3]; |
184 |
185 |
186 |
187 |
void |
188 |
rsetsrc( /* set a ring (disk) as a source */ |
189 |
SRCREC *src, |
190 |
OBJREC *so |
191 |
192 |
193 |
CONE *co; |
194 |
195 |
196 |
src->so = so; |
197 |
/* get the ring */ |
198 |
co = getcone(so, 0); |
199 |
if (CO_R1(co) <= FTINY) |
200 |
201 |
VCOPY(src->sloc, CO_P0(co)); |
202 |
if (CO_R0(co) > 0.0) |
203 |
204 |
src->sflags |= (SFLAT|SCIR); |
205 |
VCOPY(src->snorm, co->ad); |
206 |
src->srad = CO_R1(co); |
207 |
208 |
setflatss(src); |
209 |
210 |
211 |
212 |
void |
213 |
cylsetsrc( /* set a cylinder as a source */ |
214 |
SRCREC *src, |
215 |
OBJREC *so |
216 |
217 |
218 |
CONE *co; |
219 |
int i; |
220 |
221 |
src->sa.success = 4*AIMREQT-1; /* bitch on fourth failure */ |
222 |
src->so = so; |
223 |
/* get the cylinder */ |
224 |
225 |
if (CO_R0(co) <= FTINY) |
226 |
227 |
if (CO_R0(co) > .2*co->al) /* heuristic constraint */ |
228 |
objerror(so, WARNING, "source aspect too small"); |
229 |
src->sflags |= SCYL; |
230 |
231 |
src->sloc[i] = .5 * (CO_P1(co)[i] + CO_P0(co)[i]); |
232 |
src->srad = .5*co->al; |
233 |
src->ss2 = 2.*CO_R0(co)*co->al; |
234 |
/* set sampling vectors */ |
235 |
236 |
src->ss[SU][i] = .5 * co->al * co->ad[i]; |
237 |
getperpendicular(src->ss[SW], co->ad); |
238 |
239 |
src->ss[SW][i] *= .8559 * CO_R0(co); |
240 |
fcross(src->ss[SV], src->ss[SW], co->ad); |
241 |
242 |
243 |
244 |
SPOT * |
245 |
makespot( /* make a spotlight */ |
246 |
OBJREC *m |
247 |
248 |
249 |
SPOT *ns; |
250 |
251 |
if ((ns = (SPOT *)m->os) != NULL) |
252 |
return(ns); |
253 |
if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL) |
254 |
return(NULL); |
255 |
if (m->oargs.farg[3] <= FTINY) |
256 |
objerror(m, USER, "zero angle"); |
257 |
ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3])); |
258 |
VCOPY(ns->aim, m->oargs.farg+4); |
259 |
if ((ns->flen = normalize(ns->aim)) == 0.0) |
260 |
objerror(m, USER, "zero focus vector"); |
261 |
m->os = (char *)ns; |
262 |
return(ns); |
263 |
264 |
265 |
266 |
int |
267 |
spotout( /* check if we're outside spot region */ |
268 |
RAY *r, |
269 |
SPOT *s |
270 |
271 |
272 |
double d; |
273 |
FVECT vd; |
274 |
275 |
if (s == NULL) |
276 |
return(0); |
277 |
if (s->flen < -FTINY) { /* distant source */ |
278 |
vd[0] = s->aim[0] - r->rorg[0]; |
279 |
vd[1] = s->aim[1] - r->rorg[1]; |
280 |
vd[2] = s->aim[2] - r->rorg[2]; |
281 |
d = DOT(r->rdir,vd); |
282 |
/* wrong side? |
283 |
if (d <= FTINY) |
284 |
return(1); */ |
285 |
d = DOT(vd,vd) - d*d; |
286 |
if (PI*d > s->siz) |
287 |
return(1); /* out */ |
288 |
return(0); /* OK */ |
289 |
290 |
/* local source */ |
291 |
if (s->siz < 2.0*PI * (1.0 + DOT(s->aim,r->rdir))) |
292 |
293 |
294 |
295 |
296 |
297 |
double |
298 |
fgetmaxdisk( /* get center and squared radius of face */ |
299 |
FVECT ocent, |
300 |
OBJREC *op |
301 |
302 |
303 |
double maxrad2; |
304 |
double d; |
305 |
int i, j; |
306 |
FACE *f; |
307 |
308 |
f = getface(op); |
309 |
if (f->area == 0.) |
310 |
return(0.); |
311 |
for (i = 0; i < 3; i++) { |
312 |
ocent[i] = 0.; |
313 |
for (j = 0; j < f->nv; j++) |
314 |
ocent[i] += VERTEX(f,j)[i]; |
315 |
ocent[i] /= (double)f->nv; |
316 |
317 |
d = DOT(ocent,f->norm); |
318 |
319 |
ocent[i] += (f->offset - d)*f->norm[i]; |
320 |
maxrad2 = 0.; |
321 |
for (j = 0; j < f->nv; j++) { |
322 |
d = dist2(VERTEX(f,j), ocent); |
323 |
if (d > maxrad2) |
324 |
maxrad2 = d; |
325 |
326 |
return(maxrad2); |
327 |
328 |
329 |
330 |
double |
331 |
rgetmaxdisk( /* get center and squared radius of ring */ |
332 |
FVECT ocent, |
333 |
OBJREC *op |
334 |
335 |
336 |
CONE *co; |
337 |
338 |
co = getcone(op, 0); |
339 |
VCOPY(ocent, CO_P0(co)); |
340 |
return(CO_R1(co)*CO_R1(co)); |
341 |
342 |
343 |
344 |
double |
345 |
fgetplaneq( /* get plane equation for face */ |
346 |
FVECT nvec, |
347 |
OBJREC *op |
348 |
349 |
350 |
FACE *fo; |
351 |
352 |
fo = getface(op); |
353 |
VCOPY(nvec, fo->norm); |
354 |
return(fo->offset); |
355 |
356 |
357 |
358 |
double |
359 |
rgetplaneq( /* get plane equation for ring */ |
360 |
FVECT nvec, |
361 |
OBJREC *op |
362 |
363 |
364 |
CONE *co; |
365 |
366 |
367 |
VCOPY(nvec, co->ad); |
368 |
return(DOT(nvec, CO_P0(co))); |
369 |
370 |
371 |
372 |
int |
373 |
commonspot( /* set sp1 to intersection of sp1 and sp2 */ |
374 |
SPOT *sp1, |
375 |
SPOT *sp2, |
376 |
FVECT org |
377 |
378 |
379 |
FVECT cent; |
380 |
double rad2, cos1, cos2; |
381 |
382 |
cos1 = 1. - sp1->siz/(2.*PI); |
383 |
cos2 = 1. - sp2->siz/(2.*PI); |
384 |
if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */ |
385 |
return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 - |
386 |
sqrt((1.-cos1*cos1)*(1.-cos2*cos2))); |
387 |
/* compute and check disks */ |
388 |
rad2 = intercircle(cent, sp1->aim, sp2->aim, |
389 |
1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.); |
390 |
if (rad2 <= FTINY || normalize(cent) == 0.) |
391 |
return(0); |
392 |
VCOPY(sp1->aim, cent); |
393 |
sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2)); |
394 |
return(1); |
395 |
396 |
397 |
398 |
int |
399 |
commonbeam( /* set sp1 to intersection of sp1 and sp2 */ |
400 |
SPOT *sp1, |
401 |
SPOT *sp2, |
402 |
FVECT dir |
403 |
404 |
405 |
FVECT cent, c1, c2; |
406 |
double rad2, d; |
407 |
/* move centers to common plane */ |
408 |
d = DOT(sp1->aim, dir); |
409 |
VSUM(c1, sp1->aim, dir, -d); |
410 |
d = DOT(sp2->aim, dir); |
411 |
VSUM(c2, sp2->aim, dir, -d); |
412 |
/* compute overlap */ |
413 |
rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI); |
414 |
if (rad2 <= FTINY) |
415 |
return(0); |
416 |
417 |
sp1->siz = PI*rad2; |
418 |
return(1); |
419 |
420 |
421 |
422 |
int |
423 |
checkspot( /* check spotlight for behind source */ |
424 |
SPOT *sp, /* spotlight */ |
425 |
FVECT nrm /* source surface normal */ |
426 |
427 |
428 |
double d, d1; |
429 |
430 |
d = DOT(sp->aim, nrm); |
431 |
if (d > FTINY) /* center in front? */ |
432 |
return(1); |
433 |
/* else check horizon */ |
434 |
d1 = 1. - sp->siz/(2.*PI); |
435 |
return(1.-FTINY-d*d < d1*d1); |
436 |
437 |
438 |
439 |
double |
440 |
spotdisk( /* intersect spot with object op */ |
441 |
FVECT oc, |
442 |
OBJREC *op, |
443 |
SPOT *sp, |
444 |
FVECT pos |
445 |
446 |
447 |
FVECT onorm; |
448 |
double offs, d, dist; |
449 |
450 |
offs = getplaneq(onorm, op); |
451 |
d = -DOT(onorm, sp->aim); |
452 |
if (d >= -FTINY && d <= FTINY) |
453 |
return(0.); |
454 |
dist = (DOT(pos, onorm) - offs)/d; |
455 |
if (dist < 0.) |
456 |
return(0.); |
457 |
VSUM(oc, pos, sp->aim, dist); |
458 |
return(sp->siz*dist*dist/PI/(d*d)); |
459 |
460 |
461 |
462 |
double |
463 |
beamdisk( /* intersect beam with object op */ |
464 |
FVECT oc, |
465 |
OBJREC *op, |
466 |
SPOT *sp, |
467 |
FVECT dir |
468 |
469 |
470 |
FVECT onorm; |
471 |
472 |
473 |
474 |
d = -DOT(onorm, dir); |
475 |
476 |
return(0.); |
477 |
dist = (DOT(sp->aim, onorm) - offs)/d; |
478 |
VSUM(oc, sp->aim, dir, dist); |
479 |
return(sp->siz/PI/(d*d)); |
480 |
481 |
482 |
483 |
double |
484 |
intercircle( /* intersect two circles */ |
485 |
FVECT cc, /* midpoint (return value) */ |
486 |
FVECT c1, /* circle centers */ |
487 |
FVECT c2, |
488 |
double r1s, /* radii squared */ |
489 |
double r2s |
490 |
491 |
492 |
double a2, d2, l; |
493 |
FVECT disp; |
494 |
495 |
VSUB(disp, c2, c1); |
496 |
d2 = DOT(disp,disp); |
497 |
/* circle within overlap? */ |
498 |
if (r1s < r2s) { |
499 |
if (r2s >= r1s + d2) { |
500 |
VCOPY(cc, c1); |
501 |
return(r1s); |
502 |
503 |
} else { |
504 |
if (r1s >= r2s + d2) { |
505 |
VCOPY(cc, c2); |
506 |
return(r2s); |
507 |
508 |
509 |
a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2); |
510 |
/* no overlap? */ |
511 |
if (a2 <= 0.) |
512 |
return(0.); |
513 |
/* overlap, compute center */ |
514 |
l = sqrt((r1s - a2)/d2); |
515 |
VSUM(cc, c1, disp, l); |
516 |
return(a2); |
517 |
