1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Support routines for source objects and materials |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "otypes.h" |
14 |
15 |
#include "source.h" |
16 |
17 |
#include "cone.h" |
18 |
19 |
#include "face.h" |
20 |
21 |
#define SRCINC 4 /* realloc increment for array */ |
22 |
23 |
SRCREC *source = NULL; /* our list of sources */ |
24 |
int nsources = 0; /* the number of sources */ |
25 |
26 |
SRCFUNC sfun[NUMOTYPE]; /* source dispatch table */ |
27 |
28 |
29 |
initstypes() /* initialize source dispatch table */ |
30 |
31 |
extern VSMATERIAL mirror_vs, direct1_vs, direct2_vs; |
32 |
extern int fsetsrc(), ssetsrc(), sphsetsrc(), cylsetsrc(), rsetsrc(); |
33 |
extern int nopart(), flatpart(), cylpart(); |
34 |
extern double fgetplaneq(), rgetplaneq(); |
35 |
extern double fgetmaxdisk(), rgetmaxdisk(); |
36 |
static SOBJECT fsobj = {fsetsrc, flatpart, fgetplaneq, fgetmaxdisk}; |
37 |
static SOBJECT ssobj = {ssetsrc, nopart}; |
38 |
static SOBJECT sphsobj = {sphsetsrc, nopart}; |
39 |
static SOBJECT cylsobj = {cylsetsrc, cylpart}; |
40 |
static SOBJECT rsobj = {rsetsrc, flatpart, rgetplaneq, rgetmaxdisk}; |
41 |
42 |
sfun[MAT_MIRROR].mf = &mirror_vs; |
43 |
sfun[MAT_DIRECT1].mf = &direct1_vs; |
44 |
sfun[MAT_DIRECT2].mf = &direct2_vs; |
45 |
sfun[OBJ_FACE].of = &fsobj; |
46 |
sfun[OBJ_SOURCE].of = &ssobj; |
47 |
sfun[OBJ_SPHERE].of = &sphsobj; |
48 |
sfun[OBJ_CYLINDER].of = &cylsobj; |
49 |
sfun[OBJ_RING].of = &rsobj; |
50 |
51 |
52 |
53 |
int |
54 |
newsource() /* allocate new source in our array */ |
55 |
56 |
if (nsources == 0) |
57 |
source = (SRCREC *)malloc(SRCINC*sizeof(SRCREC)); |
58 |
else if (nsources%SRCINC == 0) |
59 |
source = (SRCREC *)realloc((char *)source, |
60 |
(unsigned)(nsources+SRCINC)*sizeof(SRCREC)); |
61 |
if (source == NULL) |
62 |
return(-1); |
63 |
source[nsources].sflags = 0; |
64 |
source[nsources].nhits = 1; |
65 |
source[nsources].ntests = 2; /* initial hit probability = 1/2 */ |
66 |
return(nsources++); |
67 |
68 |
69 |
70 |
setflatss(src) /* set sampling for a flat source */ |
71 |
register SRCREC *src; |
72 |
73 |
double mult; |
74 |
register int i; |
75 |
76 |
src->ss[SV][0] = src->ss[SV][1] = src->ss[SV][2] = 0.0; |
77 |
for (i = 0; i < 3; i++) |
78 |
if (src->snorm[i] < 0.6 && src->snorm[i] > -0.6) |
79 |
break; |
80 |
src->ss[SV][i] = 1.0; |
81 |
fcross(src->ss[SU], src->ss[SV], src->snorm); |
82 |
mult = .5 * sqrt( src->ss2 / DOT(src->ss[SU],src->ss[SU]) ); |
83 |
84 |
src->ss[SU][i] *= mult; |
85 |
fcross(src->ss[SV], src->snorm, src->ss[SU]); |
86 |
87 |
88 |
89 |
fsetsrc(src, so) /* set a face as a source */ |
90 |
91 |
OBJREC *so; |
92 |
93 |
register FACE *f; |
94 |
register int i, j; |
95 |
double d; |
96 |
97 |
src->sa.success = 2*AIMREQT-1; /* bitch on second failure */ |
98 |
src->so = so; |
99 |
/* get the face */ |
100 |
f = getface(so); |
101 |
/* find the center */ |
102 |
for (j = 0; j < 3; j++) { |
103 |
src->sloc[j] = 0.0; |
104 |
for (i = 0; i < f->nv; i++) |
105 |
src->sloc[j] += VERTEX(f,i)[j]; |
106 |
src->sloc[j] /= (double)f->nv; |
107 |
108 |
if (!inface(src->sloc, f)) |
109 |
objerror(so, USER, "cannot hit center"); |
110 |
src->sflags |= SFLAT; |
111 |
VCOPY(src->snorm, f->norm); |
112 |
src->ss2 = f->area; |
113 |
/* find maximum radius */ |
114 |
src->srad = 0.; |
115 |
for (i = 0; i < f->nv; i++) { |
116 |
d = dist2(VERTEX(f,i), src->sloc); |
117 |
if (d > src->srad) |
118 |
src->srad = d; |
119 |
120 |
src->srad = sqrt(src->srad); |
121 |
/* compute size vectors */ |
122 |
if (f->nv == 4 || (f->nv == 5 && /* parallelogram case */ |
123 |
dist2(VERTEX(f,0),VERTEX(f,4)) <= FTINY*FTINY)) |
124 |
125 |
src->ss[SU][j] = .5*(VERTEX(f,1)[j]-VERTEX(f,0)[j]); |
126 |
src->ss[SV][j] = .5*(VERTEX(f,3)[j]-VERTEX(f,0)[j]); |
127 |
128 |
else |
129 |
setflatss(src); |
130 |
131 |
132 |
133 |
ssetsrc(src, so) /* set a source as a source */ |
134 |
135 |
register OBJREC *so; |
136 |
137 |
double theta; |
138 |
139 |
140 |
src->so = so; |
141 |
if (so->oargs.nfargs != 4) |
142 |
objerror(so, USER, "bad arguments"); |
143 |
src->sflags |= SDISTANT; |
144 |
VCOPY(src->sloc, so->oargs.farg); |
145 |
if (normalize(src->sloc) == 0.0) |
146 |
objerror(so, USER, "zero direction"); |
147 |
theta = PI/180.0/2.0 * so->oargs.farg[3]; |
148 |
if (theta <= FTINY) |
149 |
objerror(so, USER, "zero size"); |
150 |
src->ss2 = 2.0*PI * (1.0 - cos(theta)); |
151 |
/* the following is approximate */ |
152 |
src->srad = sqrt(src->ss2/PI); |
153 |
VCOPY(src->snorm, src->sloc); |
154 |
setflatss(src); /* hey, whatever works */ |
155 |
src->ss[SW][0] = src->ss[SW][1] = src->ss[SW][2] = 0.0; |
156 |
157 |
158 |
159 |
sphsetsrc(src, so) /* set a sphere as a source */ |
160 |
161 |
162 |
163 |
register int i; |
164 |
165 |
166 |
src->so = so; |
167 |
168 |
objerror(so, USER, "bad # arguments"); |
169 |
if (so->oargs.farg[3] <= FTINY) |
170 |
objerror(so, USER, "illegal radius"); |
171 |
172 |
src->srad = so->oargs.farg[3]; |
173 |
src->ss2 = PI * src->srad * src->srad; |
174 |
175 |
src->ss[SU][i] = src->ss[SV][i] = src->ss[SW][i] = 0.0; |
176 |
177 |
src->ss[i][i] = .7236 * so->oargs.farg[3]; |
178 |
179 |
180 |
181 |
rsetsrc(src, so) /* set a ring (disk) as a source */ |
182 |
183 |
OBJREC *so; |
184 |
185 |
register CONE *co; |
186 |
187 |
188 |
src->so = so; |
189 |
/* get the ring */ |
190 |
co = getcone(so, 0); |
191 |
VCOPY(src->sloc, CO_P0(co)); |
192 |
if (CO_R0(co) > 0.0) |
193 |
194 |
195 |
VCOPY(src->snorm, co->ad); |
196 |
src->srad = CO_R1(co); |
197 |
198 |
setflatss(src); |
199 |
200 |
201 |
202 |
cylsetsrc(src, so) /* set a cylinder as a source */ |
203 |
204 |
OBJREC *so; |
205 |
206 |
207 |
register int i; |
208 |
209 |
src->sa.success = 4*AIMREQT-1; /* bitch on fourth failure */ |
210 |
src->so = so; |
211 |
/* get the cylinder */ |
212 |
213 |
if (CO_R0(co) > .2*co->al) /* heuristic constraint */ |
214 |
objerror(so, WARNING, "source aspect too small"); |
215 |
src->sflags |= SCYL; |
216 |
217 |
src->sloc[i] = .5 * (CO_P1(co)[i] + CO_P0(co)[i]); |
218 |
src->srad = .5*co->al; |
219 |
src->ss2 = 2.*CO_R0(co)*co->al; |
220 |
/* set sampling vectors */ |
221 |
222 |
src->ss[SU][i] = .5 * co->al * co->ad[i]; |
223 |
224 |
225 |
if (co->ad[i] < 0.6 && co->ad[i] > -0.6) |
226 |
break; |
227 |
228 |
fcross(src->ss[SW], src->ss[SV], co->ad); |
229 |
normalize(src->ss[SW]); |
230 |
231 |
src->ss[SW][i] *= .8559 * CO_R0(co); |
232 |
fcross(src->ss[SV], src->ss[SW], co->ad); |
233 |
234 |
235 |
236 |
SPOT * |
237 |
makespot(m) /* make a spotlight */ |
238 |
register OBJREC *m; |
239 |
240 |
register SPOT *ns; |
241 |
242 |
if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL) |
243 |
return(NULL); |
244 |
ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3])); |
245 |
VCOPY(ns->aim, m->oargs.farg+4); |
246 |
if ((ns->flen = normalize(ns->aim)) == 0.0) |
247 |
objerror(m, USER, "zero focus vector"); |
248 |
return(ns); |
249 |
250 |
251 |
252 |
double |
253 |
fgetmaxdisk(ocent, op) /* get center and squared radius of face */ |
254 |
FVECT ocent; |
255 |
OBJREC *op; |
256 |
257 |
double maxrad2; |
258 |
double d; |
259 |
260 |
register FACE *f; |
261 |
262 |
f = getface(op); |
263 |
if (f->area == 0.) |
264 |
return(0.); |
265 |
for (i = 0; i < 3; i++) { |
266 |
ocent[i] = 0.; |
267 |
for (j = 0; j < f->nv; j++) |
268 |
ocent[i] += VERTEX(f,j)[i]; |
269 |
ocent[i] /= (double)f->nv; |
270 |
271 |
d = DOT(ocent,f->norm); |
272 |
273 |
ocent[i] += (f->offset - d)*f->norm[i]; |
274 |
maxrad2 = 0.; |
275 |
for (j = 0; j < f->nv; j++) { |
276 |
d = dist2(VERTEX(f,j), ocent); |
277 |
if (d > maxrad2) |
278 |
maxrad2 = d; |
279 |
280 |
return(maxrad2); |
281 |
282 |
283 |
284 |
double |
285 |
rgetmaxdisk(ocent, op) /* get center and squared radius of ring */ |
286 |
FVECT ocent; |
287 |
OBJREC *op; |
288 |
289 |
290 |
291 |
co = getcone(op, 0); |
292 |
VCOPY(ocent, CO_P0(co)); |
293 |
return(CO_R1(co)*CO_R1(co)); |
294 |
295 |
296 |
297 |
double |
298 |
fgetplaneq(nvec, op) /* get plane equation for face */ |
299 |
FVECT nvec; |
300 |
OBJREC *op; |
301 |
302 |
register FACE *fo; |
303 |
304 |
fo = getface(op); |
305 |
VCOPY(nvec, fo->norm); |
306 |
return(fo->offset); |
307 |
308 |
309 |
310 |
double |
311 |
rgetplaneq(nvec, op) /* get plane equation for ring */ |
312 |
FVECT nvec; |
313 |
OBJREC *op; |
314 |
315 |
316 |
317 |
318 |
VCOPY(nvec, co->ad); |
319 |
return(DOT(nvec, CO_P0(co))); |
320 |
321 |
322 |
323 |
commonspot(sp1, sp2, org) /* set sp1 to intersection of sp1 and sp2 */ |
324 |
register SPOT *sp1, *sp2; |
325 |
FVECT org; |
326 |
327 |
FVECT cent; |
328 |
double rad2, cos1, cos2; |
329 |
330 |
cos1 = 1. - sp1->siz/(2.*PI); |
331 |
cos2 = 1. - sp2->siz/(2.*PI); |
332 |
if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */ |
333 |
return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 - |
334 |
sqrt((1.-cos1*cos1)*(1.-cos2*cos2))); |
335 |
/* compute and check disks */ |
336 |
rad2 = intercircle(cent, sp1->aim, sp2->aim, |
337 |
1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.); |
338 |
if (rad2 <= FTINY || normalize(cent) == 0.) |
339 |
return(0); |
340 |
VCOPY(sp1->aim, cent); |
341 |
sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2)); |
342 |
return(1); |
343 |
344 |
345 |
346 |
commonbeam(sp1, sp2, dir) /* set sp1 to intersection of sp1 and sp2 */ |
347 |
348 |
FVECT dir; |
349 |
350 |
FVECT cent, c1, c2; |
351 |
double rad2, d; |
352 |
register int i; |
353 |
/* move centers to common plane */ |
354 |
d = DOT(sp1->aim, dir); |
355 |
356 |
c1[i] = sp1->aim[i] - d*dir[i]; |
357 |
d = DOT(sp2->aim, dir); |
358 |
359 |
c2[i] = sp2->aim[i] - d*dir[i]; |
360 |
/* compute overlap */ |
361 |
rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI); |
362 |
if (rad2 <= FTINY) |
363 |
return(0); |
364 |
365 |
sp1->siz = PI*rad2; |
366 |
return(1); |
367 |
368 |
369 |
370 |
checkspot(sp, nrm) /* check spotlight for behind source */ |
371 |
register SPOT *sp; /* spotlight */ |
372 |
FVECT nrm; /* source surface normal */ |
373 |
374 |
double d, d1; |
375 |
376 |
d = DOT(sp->aim, nrm); |
377 |
if (d > FTINY) /* center in front? */ |
378 |
return(1); |
379 |
/* else check horizon */ |
380 |
d1 = 1. - sp->siz/(2.*PI); |
381 |
return(1.-FTINY-d*d < d1*d1); |
382 |
383 |
384 |
385 |
double |
386 |
spotdisk(oc, op, sp, pos) /* intersect spot with object op */ |
387 |
FVECT oc; |
388 |
OBJREC *op; |
389 |
register SPOT *sp; |
390 |
FVECT pos; |
391 |
392 |
FVECT onorm; |
393 |
double offs, d, dist; |
394 |
register int i; |
395 |
396 |
offs = getplaneq(onorm, op); |
397 |
d = -DOT(onorm, sp->aim); |
398 |
if (d >= -FTINY && d <= FTINY) |
399 |
return(0.); |
400 |
dist = (DOT(pos, onorm) - offs)/d; |
401 |
if (dist < 0.) |
402 |
return(0.); |
403 |
404 |
oc[i] = pos[i] + dist*sp->aim[i]; |
405 |
return(sp->siz*dist*dist/PI/(d*d)); |
406 |
407 |
408 |
409 |
double |
410 |
beamdisk(oc, op, sp, dir) /* intersect beam with object op */ |
411 |
FVECT oc; |
412 |
OBJREC *op; |
413 |
414 |
FVECT dir; |
415 |
416 |
FVECT onorm; |
417 |
418 |
register int i; |
419 |
420 |
421 |
d = -DOT(onorm, dir); |
422 |
423 |
return(0.); |
424 |
dist = (DOT(sp->aim, onorm) - offs)/d; |
425 |
426 |
oc[i] = sp->aim[i] + dist*dir[i]; |
427 |
return(sp->siz/PI/(d*d)); |
428 |
429 |
430 |
431 |
double |
432 |
intercircle(cc, c1, c2, r1s, r2s) /* intersect two circles */ |
433 |
FVECT cc; /* midpoint (return value) */ |
434 |
FVECT c1, c2; /* circle centers */ |
435 |
double r1s, r2s; /* radii squared */ |
436 |
437 |
double a2, d2, l; |
438 |
FVECT disp; |
439 |
register int i; |
440 |
441 |
442 |
disp[i] = c2[i] - c1[i]; |
443 |
d2 = DOT(disp,disp); |
444 |
/* circle within overlap? */ |
445 |
if (r1s < r2s) { |
446 |
if (r2s >= r1s + d2) { |
447 |
VCOPY(cc, c1); |
448 |
return(r1s); |
449 |
450 |
} else { |
451 |
if (r1s >= r2s + d2) { |
452 |
VCOPY(cc, c2); |
453 |
return(r2s); |
454 |
455 |
456 |
a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2); |
457 |
/* no overlap? */ |
458 |
if (a2 <= 0.) |
459 |
return(0.); |
460 |
/* overlap, compute center */ |
461 |
l = sqrt((r1s - a2)/d2); |
462 |
463 |
cc[i] = c1[i] + l*disp[i]; |
464 |
return(a2); |
465 |
466 |
467 |
468 |
sourcehit(r) /* check to see if ray hit distant source */ |
469 |
register RAY *r; |
470 |
471 |
int first, last; |
472 |
register int i; |
473 |
474 |
if (r->rsrc >= 0) { /* check only one if aimed */ |
475 |
first = last = r->rsrc; |
476 |
} else { /* otherwise check all */ |
477 |
first = 0; last = nsources-1; |
478 |
479 |
for (i = first; i <= last; i++) |
480 |
if ((source[i].sflags & (SDISTANT|SVIRTUAL)) == SDISTANT) |
481 |
482 |
* Check to see if ray is within |
483 |
* solid angle of source. |
484 |
485 |
if (2.0*PI * (1.0 - DOT(source[i].sloc,r->rdir)) |
486 |
<= source[i].ss2) { |
487 |
r->ro = source[i].so; |
488 |
if (!(source[i].sflags & SSKIP)) |
489 |
break; |
490 |
491 |
492 |
if (r->ro != NULL) { |
493 |
494 |
r->ron[i] = -r->rdir[i]; |
495 |
r->rod = 1.0; |
496 |
r->rox = NULL; |
497 |
return(1); |
498 |
499 |
return(0); |
500 |
501 |
502 |
503 |
504 |
* The following macros were separated from the m_light() routine |
505 |
* because they are very nasty and difficult to understand. |
506 |
507 |
508 |
/* wrongillum * |
509 |
510 |
* We cannot allow an illum to pass to another illum, because that |
511 |
* would almost certainly constitute overcounting. |
512 |
* However, we do allow an illum to pass to another illum |
513 |
* that is actually going to relay to a virtual light source. |
514 |
515 |
516 |
#define wrongillum(m, r) (!(source[r->rsrc].sflags&SVIRTUAL) && \ |
517 |
objptr(source[r->rsrc].so->omod)->otype==MAT_ILLUM) |
518 |
519 |
/* wrongsource * |
520 |
521 |
* This source is the wrong source (ie. overcounted) if we are |
522 |
* aimed to a different source than the one we hit and the one |
523 |
* we hit is not an illum which should be passed. |
524 |
525 |
526 |
#define wrongsource(m, r) (r->rsrc>=0 && source[r->rsrc].so!=r->ro && \ |
527 |
(m->otype!=MAT_ILLUM || wrongillum(m,r))) |
528 |
529 |
/* badspecular * |
530 |
531 |
* Any undirected specular ray that hits a light source |
532 |
* should be discarded. This is because the source contribution to |
533 |
* specular components is calculated separately to reduce variance. |
534 |
535 |
536 |
#define badspecular(m, r) (r->rsrc<0 && r->crtype&SPECULAR) |
537 |
538 |
/* distglow * |
539 |
540 |
* A distant glow is an object that sometimes acts as a light source, |
541 |
* but is too far away from the test point to be one in this case. |
542 |
543 |
544 |
#define distglow(m, r) (m->otype==MAT_GLOW && \ |
545 |
r->rot > m->oargs.farg[3]) |
546 |
547 |
/* badambient * |
548 |
549 |
* We must avoid including counting light sources in the ambient calculation, |
550 |
* since the direct component is handled separately. Therefore, any |
551 |
* ambient ray which hits an active light source must be discarded. |
552 |
553 |
554 |
#define badambient(m, r) ((r->crtype&(AMBIENT|SHADOW))==AMBIENT && \ |
555 |
!distglow(m, r)) |
556 |
557 |
/* overcount * |
558 |
559 |
* All overcounting possibilities are contained here. |
560 |
561 |
562 |
#define overcount(m, r) (badspecular(m,r) || wrongsource(m,r) || \ |
563 |
badambient(m,r)) |
564 |
565 |
/* passillum * |
566 |
567 |
* An illum passes to another material type when we didn't hit it |
568 |
* on purpose (as part of a direct calculation), or it is relaying |
569 |
* a virtual light source. |
570 |
571 |
572 |
#define passillum(m, r) (m->otype==MAT_ILLUM && \ |
573 |
(r->rsrc<0 || source[r->rsrc].so!=r->ro || \ |
574 |
source[r->rsrc].sflags&SVIRTUAL)) |
575 |
576 |
/* srcignore * |
577 |
578 |
* The -di flag renders light sources invisible, and here is the test. |
579 |
580 |
581 |
#define srcignore(m, r) (directinvis && !(r->crtype&SHADOW) && \ |
582 |
!distglow(m, r)) |
583 |
584 |
585 |
m_light(m, r) /* ray hit a light source */ |
586 |
587 |
register RAY *r; |
588 |
589 |
/* check for over-counting */ |
590 |
if (overcount(m, r)) |
591 |
return; |
592 |
/* check for passed illum */ |
593 |
if (passillum(m, r)) { |
594 |
if (m->oargs.nsargs < 1 || !strcmp(m->oargs.sarg[0], VOIDID)) |
595 |
raytrans(r); |
596 |
else |
597 |
rayshade(r, modifier(m->oargs.sarg[0])); |
598 |
return; |
599 |
600 |
/* otherwise treat as source */ |
601 |
/* check for behind */ |
602 |
if (r->rod < 0.0) |
603 |
return; |
604 |
/* check for invisibility */ |
605 |
if (srcignore(m, r)) |
606 |
return; |
607 |
/* get distribution pattern */ |
608 |
raytexture(r, m->omod); |
609 |
/* get source color */ |
610 |
setcolor(r->rcol, m->oargs.farg[0], |
611 |
m->oargs.farg[1], |
612 |
m->oargs.farg[2]); |
613 |
/* modify value */ |
614 |
multcolor(r->rcol, r->pcol); |
615 |
