root/radiance/ray/src/rt/srcsupp.c
Wed Aug 7 18:33:33 2024 UTC (8 months, 3 weeks ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24 , to selected 1.16
fix(rpict,rtrace,rcontrib,rfluxmtx,rtpict): Bug in distant source sampling introduced in August 2022, reported by Mik DiPompeo of LightStanza
Thu Aug 4 22:43:46 2022 UTC (2 years, 8 months ago) by greg
Changes since 2.23: +25 -7 lines
Diff to previous 2.23 , to selected 1.16
fix: reduced aiming failures for triangular light sources
Thu Apr 21 00:40:35 2016 UTC (9 years ago) by greg
Changes since 2.22: +12 -2 lines
Diff to previous 2.22 , to selected 1.16
Made zero cone and ring radii non-fatal (degenerate -> ignore)
Thu May 21 05:54:54 2015 UTC (9 years, 11 months ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21 , to selected 1.16
Thu Dec 4 05:26:28 2014 UTC (10 years, 5 months ago) by greg
Changes since 2.20: +4 -15 lines
Diff to previous 2.20 , to selected 1.16
Sun Jun 22 18:05:28 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.19: +95 -73 lines
Diff to previous 2.19 , to selected 1.16
ANSIfication
Tue Jun 17 18:57:41 2014 UTC (10 years, 10 months ago) by greg
Diff to previous 2.18 , to selected 1.16
Increased source realloc increment size
Mon Oct 25 22:57:45 2010 UTC (14 years, 6 months ago) by greg
Changes since 2.17: +7 -17 lines
Diff to previous 2.17 , to selected 1.16
Sat Dec 6 01:08:53 2008 UTC (16 years, 4 months ago) by greg
Changes since 2.16: +5 -4 lines
Diff to previous 2.16 , to selected 1.16
Mon Feb 26 21:16:02 2007 UTC (18 years, 2 months ago) by greg
Changes since 2.15: +12 -4 lines
Diff to previous 2.15 , to selected 1.16
Sun Oct 16 16:04:10 2005 UTC (19 years, 6 months ago) by greg
Changes since 2.14: +3 -3 lines
Diff to previous 2.14 , to selected 1.16
Improved error reporting for holey sources
Wed Dec 31 19:38:27 2003 UTC (21 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 1.16
Wed Dec 31 02:03:08 2003 UTC (21 years, 4 months ago) by greg
Diff to previous 2.12 , to selected 1.16
Minor fixes to source occlusion cache
Wed Dec 31 01:50:02 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.11: +5 -2 lines
Diff to previous 2.11 , to selected 1.16
Wed Apr 23 00:52:34 2003 UTC (22 years ago) by greg
Diff to previous 2.10 , to selected 1.16
Tue Feb 25 02:47:23 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 1.16
Changes since 2.8: +71 -8 lines
Diff to previous 2.8 , to selected 1.16
Tue Nov 7 12:40:30 1995 UTC (29 years, 6 months ago) by greg
Diff to previous 2.7 , to selected 1.16
Thu Aug 24 20:56:08 1995 UTC (29 years, 8 months ago) by greg
Diff to previous 2.6 , to selected 1.16
removed unnecessary test for last vertex == first vertex
Fri Aug 28 15:10:47 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.5: +0 -35 lines
Diff to previous 2.5 , to selected 1.16
moved sourcehit() from srcsupp.c back to source.c
Fri Aug 28 14:07:45 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.4: +33 -108 lines
Diff to previous 2.4 , to selected 1.16
fixed bug with virtual spotlight sources
moved m_light() back to source.c
Wed Feb 26 09:49:37 1992 UTC (33 years, 2 months ago) by greg
Diff to previous 2.3 , to selected 1.16
fixed bug in specular/ambient rays hitting back side of illums
Wed Jan 15 16:54:50 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.2: +7 -15 lines
Diff to previous 2.2 , to selected 1.16
fixed improper exclusion of SPECULAR rays in source calculation
Sat Jan 4 19:54:20 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.1: +19 -2 lines
Diff to previous 2.1 , to selected 1.16
added specular sampling
Tue Nov 12 17:10:22 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.16
Revision 1.16 - (view) (download) (annotate) - [selected]
Fri Nov 8 16:34:24 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.15: +52 -5 lines
Diff to previous 1.15
Tue Oct 22 11:23:47 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.14: +4 -3 lines
Diff to previous 1.14 , to selected 1.16
bug fixes in source sampling routines
Mon Oct 21 12:58:16 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.13: +95 -13 lines
Diff to previous 1.13 , to selected 1.16
Fri Sep 13 13:44:10 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.12: +5 -3 lines
Diff to previous 1.12 , to selected 1.16
made source array allocation incremental
Mon Aug 26 10:11:08 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.11 , to selected 1.16
fixed bug in checking of distant sources for non-intersecting ray
Wed Aug 14 08:19:20 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.10: +4 -3 lines
Diff to previous 1.10 , to selected 1.16
fixed double illum counting
Thu Jul 18 14:43:07 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.9: +20 -13 lines
Diff to previous 1.9 , to selected 1.16
Tue Jul 16 15:56:48 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.8: +3 -1 lines
Diff to previous 1.8 , to selected 1.16
added redirecting materials
Tue Jun 25 16:42:03 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.7 , to selected 1.16
fixed bug relating to return value of checkspot()
Tue Jun 25 15:34:17 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 1.16
*** empty log message ***
Tue Jun 25 13:11:55 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.5: +46 -0 lines
Diff to previous 1.5 , to selected 1.16
fixed problems with virtual source pretesting
Mon Jun 24 16:00:30 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.4: +9 -6 lines
Diff to previous 1.4 , to selected 1.16
made sure center point returned by fgetdisk() was in plane
Fri Jun 21 16:44:01 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.3: +99 -1 lines
Diff to previous 1.3 , to selected 1.16
moved some routines here from virtuals.c
Fri Jun 21 13:23:05 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 1.16
added test for zero area face in fgetdisk()
Thu Jun 20 16:36:46 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.1 , to selected 1.16
bug fixes and enhancements
Thu Jun 20 13:44:36 1991 UTC (33 years, 10 months ago) by greg
Diff to selected 1.16
