| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Support routines for source objects and materials
| 9 |
| 10 |
| 11 |
#include "ray.h"
| 12 |
| 13 |
#include "otypes.h"
| 14 |
| 15 |
#include "source.h"
| 16 |
| 17 |
#include "cone.h"
| 18 |
| 19 |
#include "face.h"
| 20 |
| 21 |
#define SRCINC 4 /* realloc increment for array */
| 22 |
| 23 |
SRCREC *source = NULL; /* our list of sources */
| 24 |
int nsources = 0; /* the number of sources */
| 25 |
| 26 |
SRCFUNC sfun[NUMOTYPE]; /* source dispatch table */
| 27 |
| 28 |
| 29 |
initstypes() /* initialize source dispatch table */
| 30 |
| 31 |
extern VSMATERIAL mirror_vs, direct1_vs, direct2_vs;
| 32 |
extern int fsetsrc(), ssetsrc(), sphsetsrc(), cylsetsrc(), rsetsrc();
| 33 |
extern int nopart(), flatpart(), cylpart();
| 34 |
extern double fgetplaneq(), rgetplaneq();
| 35 |
extern double fgetmaxdisk(), rgetmaxdisk();
| 36 |
static SOBJECT fsobj = {fsetsrc, flatpart, fgetplaneq, fgetmaxdisk};
| 37 |
static SOBJECT ssobj = {ssetsrc, nopart};
| 38 |
static SOBJECT sphsobj = {sphsetsrc, nopart};
| 39 |
static SOBJECT cylsobj = {cylsetsrc, cylpart};
| 40 |
static SOBJECT rsobj = {rsetsrc, flatpart, rgetplaneq, rgetmaxdisk};
| 41 |
| 42 |
sfun[MAT_MIRROR].mf = &mirror_vs;
| 43 |
sfun[MAT_DIRECT1].mf = &direct1_vs;
| 44 |
sfun[MAT_DIRECT2].mf = &direct2_vs;
| 45 |
sfun[OBJ_FACE].of = &fsobj;
| 46 |
sfun[OBJ_SOURCE].of = &ssobj;
| 47 |
sfun[OBJ_SPHERE].of = &sphsobj;
| 48 |
sfun[OBJ_CYLINDER].of = &cylsobj;
| 49 |
sfun[OBJ_RING].of = &rsobj;
| 50 |
| 51 |
| 52 |
| 53 |
int
| 54 |
newsource() /* allocate new source in our array */
| 55 |
| 56 |
if (nsources == 0)
| 57 |
source = (SRCREC *)malloc(SRCINC*sizeof(SRCREC));
| 58 |
else if (nsources%SRCINC == 0)
| 59 |
source = (SRCREC *)realloc((char *)source,
| 60 |
(unsigned)(nsources+SRCINC)*sizeof(SRCREC));
| 61 |
if (source == NULL)
| 62 |
return(-1);
| 63 |
source[nsources].sflags = 0;
| 64 |
source[nsources].nhits = 1;
| 65 |
source[nsources].ntests = 2; /* initial hit probability = 1/2 */
| 66 |
return(nsources++);
| 67 |
| 68 |
| 69 |
| 70 |
setflatss(src) /* set sampling for a flat source */
| 71 |
register SRCREC *src;
| 72 |
| 73 |
double mult;
| 74 |
register int i;
| 75 |
| 76 |
src->ss[SV][0] = src->ss[SV][1] = src->ss[SV][2] = 0.0;
| 77 |
for (i = 0; i < 3; i++)
| 78 |
if (src->snorm[i] < 0.6 && src->snorm[i] > -0.6)
| 79 |
break;
| 80 |
src->ss[SV][i] = 1.0;
| 81 |
fcross(src->ss[SU], src->ss[SV], src->snorm);
| 82 |
mult = .5 * sqrt( src->ss2 / DOT(src->ss[SU],src->ss[SU]) );
| 83 |
| 84 |
src->ss[SU][i] *= mult;
| 85 |
fcross(src->ss[SV], src->snorm, src->ss[SU]);
| 86 |
| 87 |
| 88 |
| 89 |
fsetsrc(src, so) /* set a face as a source */
| 90 |
| 91 |
OBJREC *so;
| 92 |
| 93 |
register FACE *f;
| 94 |
register int i, j;
| 95 |
double d;
| 96 |
| 97 |
src->sa.success = 2*AIMREQT-1; /* bitch on second failure */
| 98 |
src->so = so;
| 99 |
/* get the face */
| 100 |
f = getface(so);
| 101 |
/* find the center */
| 102 |
for (j = 0; j < 3; j++) {
| 103 |
src->sloc[j] = 0.0;
| 104 |
for (i = 0; i < f->nv; i++)
| 105 |
src->sloc[j] += VERTEX(f,i)[j];
| 106 |
src->sloc[j] /= (double)f->nv;
| 107 |
| 108 |
if (!inface(src->sloc, f))
| 109 |
objerror(so, USER, "cannot hit center");
| 110 |
src->sflags |= SFLAT;
| 111 |
VCOPY(src->snorm, f->norm);
| 112 |
src->ss2 = f->area;
| 113 |
/* find maximum radius */
| 114 |
src->srad = 0.;
| 115 |
for (i = 0; i < f->nv; i++) {
| 116 |
d = dist2(VERTEX(f,i), src->sloc);
| 117 |
if (d > src->srad)
| 118 |
src->srad = d;
| 119 |
| 120 |
src->srad = sqrt(src->srad);
| 121 |
/* compute size vectors */
| 122 |
if (f->nv == 4 || (f->nv == 5 && /* parallelogram case */
| 123 |
dist2(VERTEX(f,0),VERTEX(f,4)) <= FTINY*FTINY))
| 124 |
| 125 |
src->ss[SU][j] = .5*(VERTEX(f,1)[j]-VERTEX(f,0)[j]);
| 126 |
src->ss[SV][j] = .5*(VERTEX(f,3)[j]-VERTEX(f,0)[j]);
| 127 |
| 128 |
else
| 129 |
setflatss(src);
| 130 |
| 131 |
| 132 |
| 133 |
ssetsrc(src, so) /* set a source as a source */
| 134 |
| 135 |
register OBJREC *so;
| 136 |
| 137 |
double theta;
| 138 |
| 139 |
| 140 |
src->so = so;
| 141 |
if (so->oargs.nfargs != 4)
| 142 |
objerror(so, USER, "bad arguments");
| 143 |
src->sflags |= SDISTANT;
| 144 |
VCOPY(src->sloc, so->oargs.farg);
| 145 |
if (normalize(src->sloc) == 0.0)
| 146 |
objerror(so, USER, "zero direction");
| 147 |
theta = PI/180.0/2.0 * so->oargs.farg[3];
| 148 |
if (theta <= FTINY)
| 149 |
objerror(so, USER, "zero size");
| 150 |
src->ss2 = 2.0*PI * (1.0 - cos(theta));
| 151 |
/* the following is approximate */
| 152 |
src->srad = sqrt(src->ss2/PI);
| 153 |
VCOPY(src->snorm, src->sloc);
| 154 |
setflatss(src); /* hey, whatever works */
| 155 |
src->ss[SW][0] = src->ss[SW][1] = src->ss[SW][2] = 0.0;
| 156 |
| 157 |
| 158 |
| 159 |
sphsetsrc(src, so) /* set a sphere as a source */
| 160 |
| 161 |
| 162 |
| 163 |
register int i;
| 164 |
| 165 |
| 166 |
src->so = so;
| 167 |
| 168 |
objerror(so, USER, "bad # arguments");
| 169 |
if (so->oargs.farg[3] <= FTINY)
| 170 |
objerror(so, USER, "illegal radius");
| 171 |
| 172 |
src->srad = so->oargs.farg[3];
| 173 |
src->ss2 = PI * src->srad * src->srad;
| 174 |
| 175 |
src->ss[SU][i] = src->ss[SV][i] = src->ss[SW][i] = 0.0;
| 176 |
| 177 |
src->ss[i][i] = .7236 * so->oargs.farg[3];
| 178 |
| 179 |
| 180 |
| 181 |
rsetsrc(src, so) /* set a ring (disk) as a source */
| 182 |
| 183 |
OBJREC *so;
| 184 |
| 185 |
register CONE *co;
| 186 |
| 187 |
| 188 |
src->so = so;
| 189 |
/* get the ring */
| 190 |
co = getcone(so, 0);
| 191 |
VCOPY(src->sloc, CO_P0(co));
| 192 |
if (CO_R0(co) > 0.0)
| 193 |
| 194 |
| 195 |
VCOPY(src->snorm, co->ad);
| 196 |
src->srad = CO_R1(co);
| 197 |
| 198 |
setflatss(src);
| 199 |
| 200 |
| 201 |
| 202 |
cylsetsrc(src, so) /* set a cylinder as a source */
| 203 |
| 204 |
OBJREC *so;
| 205 |
| 206 |
register CONE *co;
| 207 |
register int i;
| 208 |
| 209 |
src->sa.success = 4*AIMREQT-1; /* bitch on fourth failure */
| 210 |
src->so = so;
| 211 |
/* get the cylinder */
| 212 |
| 213 |
if (CO_R0(co) > .2*co->al) /* heuristic constraint */
| 214 |
objerror(so, WARNING, "source aspect too small");
| 215 |
src->sflags |= SCYL;
| 216 |
| 217 |
src->sloc[i] = .5 * (CO_P1(co)[i] + CO_P0(co)[i]);
| 218 |
src->srad = .5*co->al;
| 219 |
src->ss2 = 2.*CO_R0(co)*co->al;
| 220 |
/* set sampling vectors */
| 221 |
| 222 |
src->ss[SU][i] = .5 * co->al * co->ad[i];
| 223 |
| 224 |
| 225 |
if (co->ad[i] < 0.6 && co->ad[i] > -0.6)
| 226 |
break;
| 227 |
| 228 |
fcross(src->ss[SW], src->ss[SV], co->ad);
| 229 |
normalize(src->ss[SW]);
| 230 |
| 231 |
src->ss[SW][i] *= .8559 * CO_R0(co);
| 232 |
fcross(src->ss[SV], src->ss[SW], co->ad);
| 233 |
| 234 |
| 235 |
| 236 |
SPOT *
| 237 |
makespot(m) /* make a spotlight */
| 238 |
register OBJREC *m;
| 239 |
| 240 |
register SPOT *ns;
| 241 |
| 242 |
if ((ns = (SPOT *)m->os) != NULL)
| 243 |
return(ns);
| 244 |
if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL)
| 245 |
return(NULL);
| 246 |
ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3]));
| 247 |
VCOPY(ns->aim, m->oargs.farg+4);
| 248 |
if ((ns->flen = normalize(ns->aim)) == 0.0)
| 249 |
objerror(m, USER, "zero focus vector");
| 250 |
m->os = (char *)ns;
| 251 |
return(ns);
| 252 |
| 253 |
| 254 |
| 255 |
spotout(r, s, dist) /* check if we're outside spot region */
| 256 |
register RAY *r;
| 257 |
register SPOT *s;
| 258 |
int dist;
| 259 |
| 260 |
double d;
| 261 |
FVECT vd;
| 262 |
| 263 |
if (s == NULL)
| 264 |
return(0);
| 265 |
if (dist) { /* distant source */
| 266 |
vd[0] = s->aim[0] - r->rorg[0];
| 267 |
vd[1] = s->aim[1] - r->rorg[1];
| 268 |
vd[2] = s->aim[2] - r->rorg[2];
| 269 |
d = DOT(r->rdir,vd);
| 270 |
/* wrong side?
| 271 |
if (d <= FTINY)
| 272 |
return(1); */
| 273 |
d = DOT(vd,vd) - d*d;
| 274 |
if (PI*d > s->siz)
| 275 |
return(1); /* out */
| 276 |
return(0); /* OK */
| 277 |
| 278 |
/* local source */
| 279 |
if (s->siz < 2.0*PI * (1.0 + DOT(s->aim,r->rdir)))
| 280 |
| 281 |
return(0); /* OK */
| 282 |
| 283 |
| 284 |
| 285 |
double
| 286 |
fgetmaxdisk(ocent, op) /* get center and squared radius of face */
| 287 |
FVECT ocent;
| 288 |
OBJREC *op;
| 289 |
| 290 |
double maxrad2;
| 291 |
double d;
| 292 |
register int i, j;
| 293 |
register FACE *f;
| 294 |
| 295 |
f = getface(op);
| 296 |
if (f->area == 0.)
| 297 |
return(0.);
| 298 |
for (i = 0; i < 3; i++) {
| 299 |
ocent[i] = 0.;
| 300 |
for (j = 0; j < f->nv; j++)
| 301 |
ocent[i] += VERTEX(f,j)[i];
| 302 |
ocent[i] /= (double)f->nv;
| 303 |
| 304 |
d = DOT(ocent,f->norm);
| 305 |
| 306 |
ocent[i] += (f->offset - d)*f->norm[i];
| 307 |
maxrad2 = 0.;
| 308 |
for (j = 0; j < f->nv; j++) {
| 309 |
d = dist2(VERTEX(f,j), ocent);
| 310 |
if (d > maxrad2)
| 311 |
maxrad2 = d;
| 312 |
| 313 |
return(maxrad2);
| 314 |
| 315 |
| 316 |
| 317 |
double
| 318 |
rgetmaxdisk(ocent, op) /* get center and squared radius of ring */
| 319 |
FVECT ocent;
| 320 |
OBJREC *op;
| 321 |
| 322 |
register CONE *co;
| 323 |
| 324 |
co = getcone(op, 0);
| 325 |
VCOPY(ocent, CO_P0(co));
| 326 |
return(CO_R1(co)*CO_R1(co));
| 327 |
| 328 |
| 329 |
| 330 |
double
| 331 |
fgetplaneq(nvec, op) /* get plane equation for face */
| 332 |
FVECT nvec;
| 333 |
OBJREC *op;
| 334 |
| 335 |
register FACE *fo;
| 336 |
| 337 |
fo = getface(op);
| 338 |
VCOPY(nvec, fo->norm);
| 339 |
return(fo->offset);
| 340 |
| 341 |
| 342 |
| 343 |
double
| 344 |
rgetplaneq(nvec, op) /* get plane equation for ring */
| 345 |
FVECT nvec;
| 346 |
OBJREC *op;
| 347 |
| 348 |
register CONE *co;
| 349 |
| 350 |
| 351 |
VCOPY(nvec, co->ad);
| 352 |
return(DOT(nvec, CO_P0(co)));
| 353 |
| 354 |
| 355 |
| 356 |
commonspot(sp1, sp2, org) /* set sp1 to intersection of sp1 and sp2 */
| 357 |
register SPOT *sp1, *sp2;
| 358 |
FVECT org;
| 359 |
| 360 |
FVECT cent;
| 361 |
double rad2, cos1, cos2;
| 362 |
| 363 |
cos1 = 1. - sp1->siz/(2.*PI);
| 364 |
cos2 = 1. - sp2->siz/(2.*PI);
| 365 |
if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */
| 366 |
return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 -
| 367 |
sqrt((1.-cos1*cos1)*(1.-cos2*cos2)));
| 368 |
/* compute and check disks */
| 369 |
rad2 = intercircle(cent, sp1->aim, sp2->aim,
| 370 |
1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.);
| 371 |
if (rad2 <= FTINY || normalize(cent) == 0.)
| 372 |
return(0);
| 373 |
VCOPY(sp1->aim, cent);
| 374 |
sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2));
| 375 |
return(1);
| 376 |
| 377 |
| 378 |
| 379 |
commonbeam(sp1, sp2, dir) /* set sp1 to intersection of sp1 and sp2 */
| 380 |
| 381 |
FVECT dir;
| 382 |
| 383 |
FVECT cent, c1, c2;
| 384 |
double rad2, d;
| 385 |
register int i;
| 386 |
/* move centers to common plane */
| 387 |
d = DOT(sp1->aim, dir);
| 388 |
| 389 |
c1[i] = sp1->aim[i] - d*dir[i];
| 390 |
d = DOT(sp2->aim, dir);
| 391 |
| 392 |
c2[i] = sp2->aim[i] - d*dir[i];
| 393 |
/* compute overlap */
| 394 |
rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI);
| 395 |
if (rad2 <= FTINY)
| 396 |
return(0);
| 397 |
| 398 |
sp1->siz = PI*rad2;
| 399 |
return(1);
| 400 |
| 401 |
| 402 |
| 403 |
checkspot(sp, nrm) /* check spotlight for behind source */
| 404 |
register SPOT *sp; /* spotlight */
| 405 |
FVECT nrm; /* source surface normal */
| 406 |
| 407 |
double d, d1;
| 408 |
| 409 |
d = DOT(sp->aim, nrm);
| 410 |
if (d > FTINY) /* center in front? */
| 411 |
return(1);
| 412 |
/* else check horizon */
| 413 |
d1 = 1. - sp->siz/(2.*PI);
| 414 |
return(1.-FTINY-d*d < d1*d1);
| 415 |
| 416 |
| 417 |
| 418 |
double
| 419 |
spotdisk(oc, op, sp, pos) /* intersect spot with object op */
| 420 |
FVECT oc;
| 421 |
OBJREC *op;
| 422 |
register SPOT *sp;
| 423 |
FVECT pos;
| 424 |
| 425 |
FVECT onorm;
| 426 |
double offs, d, dist;
| 427 |
register int i;
| 428 |
| 429 |
offs = getplaneq(onorm, op);
| 430 |
d = -DOT(onorm, sp->aim);
| 431 |
if (d >= -FTINY && d <= FTINY)
| 432 |
return(0.);
| 433 |
dist = (DOT(pos, onorm) - offs)/d;
| 434 |
if (dist < 0.)
| 435 |
return(0.);
| 436 |
| 437 |
oc[i] = pos[i] + dist*sp->aim[i];
| 438 |
return(sp->siz*dist*dist/PI/(d*d));
| 439 |
| 440 |
| 441 |
| 442 |
double
| 443 |
beamdisk(oc, op, sp, dir) /* intersect beam with object op */
| 444 |
FVECT oc;
| 445 |
OBJREC *op;
| 446 |
register SPOT *sp;
| 447 |
FVECT dir;
| 448 |
| 449 |
FVECT onorm;
| 450 |
| 451 |
register int i;
| 452 |
| 453 |
| 454 |
d = -DOT(onorm, dir);
| 455 |
| 456 |
return(0.);
| 457 |
dist = (DOT(sp->aim, onorm) - offs)/d;
| 458 |
| 459 |
oc[i] = sp->aim[i] + dist*dir[i];
| 460 |
return(sp->siz/PI/(d*d));
| 461 |
| 462 |
| 463 |
| 464 |
double
| 465 |
intercircle(cc, c1, c2, r1s, r2s) /* intersect two circles */
| 466 |
FVECT cc; /* midpoint (return value) */
| 467 |
FVECT c1, c2; /* circle centers */
| 468 |
double r1s, r2s; /* radii squared */
| 469 |
| 470 |
double a2, d2, l;
| 471 |
FVECT disp;
| 472 |
register int i;
| 473 |
| 474 |
| 475 |
disp[i] = c2[i] - c1[i];
| 476 |
d2 = DOT(disp,disp);
| 477 |
/* circle within overlap? */
| 478 |
if (r1s < r2s) {
| 479 |
if (r2s >= r1s + d2) {
| 480 |
VCOPY(cc, c1);
| 481 |
return(r1s);
| 482 |
| 483 |
} else {
| 484 |
if (r1s >= r2s + d2) {
| 485 |
VCOPY(cc, c2);
| 486 |
return(r2s);
| 487 |
| 488 |
| 489 |
a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2);
| 490 |
/* no overlap? */
| 491 |
if (a2 <= 0.)
| 492 |
return(0.);
| 493 |
/* overlap, compute center */
| 494 |
l = sqrt((r1s - a2)/d2);
| 495 |
| 496 |
cc[i] = c1[i] + l*disp[i];
| 497 |
return(a2);
| 498 |
