fix: reduced aiming failures for triangular light sources
Made zero cone and ring radii non-fatal (degenerate -> ignore)
ANSIfication
Increased source realloc increment size
Improved error reporting for holey sources
Minor fixes to source occlusion cache
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
removed unnecessary test for last vertex == first vertex
moved sourcehit() from srcsupp.c back to source.c
fixed bug with virtual spotlight sources moved m_light() back to source.c
fixed bug in specular/ambient rays hitting back side of illums
fixed improper exclusion of SPECULAR rays in source calculation
added specular sampling
bug fixes in source sampling routines
made source array allocation incremental
fixed bug in checking of distant sources for non-intersecting ray
fixed double illum counting
added redirecting materials
fixed bug relating to return value of checkspot()
*** empty log message ***
fixed problems with virtual source pretesting
made sure center point returned by fgetdisk() was in plane
moved some routines here from virtuals.c
added test for zero area face in fgetdisk()
bug fixes and enhancements
