root/Development/ray/src/rt/srcsupp.c
Revision: 2.25
Committed: Wed Aug 7 18:33:33 2024 UTC (16 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.24: +2 -1 lines
fix(rpict,rtrace,rcontrib,rfluxmtx,rtpict): Bug in distant source sampling introduced in August 2022, reported by Mik DiPompeo of LightStanza
2 static const char RCSid[] = "$Id: srcsupp.c,v 2.24 2022/08/04 22:43:46 greg Exp $";
5 * Support routines for source objects and materials
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13
14 #include "otypes.h"
15
16 #include "source.h"
17
18 #include "cone.h"
19
20 #include "face.h"
21
22 #define SRCINC 32 /* realloc increment for array */
23
24 SRCREC *source = NULL; /* our list of sources */
25 int nsources = 0; /* the number of sources */
26
27 SRCFUNC sfun[NUMOTYPE]; /* source dispatch table */
28
29
30 void
31 initstypes(void) /* initialize source dispatch table */
32 {
33 extern VSMATERIAL mirror_vs, direct1_vs, direct2_vs;
34 static SOBJECT fsobj = {fsetsrc, flatpart, fgetplaneq, fgetmaxdisk};
35 static SOBJECT ssobj = {ssetsrc, nopart};
36 static SOBJECT sphsobj = {sphsetsrc, nopart};
37 static SOBJECT cylsobj = {cylsetsrc, cylpart};
38 static SOBJECT rsobj = {rsetsrc, flatpart, rgetplaneq, rgetmaxdisk};
39
40 sfun[MAT_MIRROR].mf = &mirror_vs;
41 sfun[MAT_DIRECT1].mf = &direct1_vs;
42 sfun[MAT_DIRECT2].mf = &direct2_vs;
43 sfun[OBJ_FACE].of = &fsobj;
44 sfun[OBJ_SOURCE].of = &ssobj;
45 sfun[OBJ_SPHERE].of = &sphsobj;
46 sfun[OBJ_CYLINDER].of = &cylsobj;
47 sfun[OBJ_RING].of = &rsobj;
48 }
49
50
51 int
52 newsource(void) /* allocate new source in our array */
53 {
54 if (nsources == 0)
55 source = (SRCREC *)malloc(SRCINC*sizeof(SRCREC));
56 else if (nsources%SRCINC == 0)
57 source = (SRCREC *)realloc((void *)source,
58 (unsigned)(nsources+SRCINC)*sizeof(SRCREC));
59 if (source == NULL)
60 return(-1);
61 source[nsources].sflags = 0;
62 source[nsources].nhits = 1;
63 source[nsources].ntests = 2; /* initial hit probability = 50% */
64 #if SHADCACHE
65 source[nsources].obscache = NULL;
66 #endif
67 return(nsources++);
68 }
69
70
71 void
72 setflatss( /* set sampling for a flat source */
73 SRCREC *src
74 )
75 {
76 double mult;
77 int i;
78
79 getperpendicular(src->ss[SU], src->snorm, rand_samp);
80 mult = .5 * sqrt( src->ss2 );
81 for (i = 0; i < 3; i++)
82 src->ss[SU][i] *= mult;
83 fcross(src->ss[SV], src->snorm, src->ss[SU]);
84 }
85
86
87 void
88 fsetsrc( /* set a face as a source */
89 SRCREC *src,
90 OBJREC *so
91 )
92 {
93 FACE *f;
94 int i, j;
95 double d;
96
97 src->sa.success = 2*AIMREQT-1; /* bitch on second failure */
98 src->so = so;
99 /* get the face */
100 f = getface(so);
101 if (f->area == 0.)
102 objerror(so, USER, "zero source area");
103 /* find the center */
104 for (j = 0; j < 3; j++) {
105 src->sloc[j] = 0.0;
106 for (i = 0; i < f->nv; i++)
107 src->sloc[j] += VERTEX(f,i)[j];
108 src->sloc[j] /= (double)f->nv;
109 }
110 if (!inface(src->sloc, f))
111 objerror(so, USER, "cannot hit source center");
112 src->sflags |= SFLAT;
113 VCOPY(src->snorm, f->norm);
114 src->ss2 = f->area;
115 /* find maximum radius */
116 src->srad = 0.;
117 for (i = 0; i < f->nv; i++) {
118 d = dist2(VERTEX(f,i), src->sloc);
119 if (d > src->srad)
120 src->srad = d;
121 }
122 src->srad = sqrt(src->srad);
123 /* compute size vectors */
124 if (f->nv == 4) { /* parallelogram case */
125 for (j = 0; j < 3; j++) {
126 src->ss[SU][j] = .5*(VERTEX(f,1)[j]-VERTEX(f,0)[j]);
127 src->ss[SV][j] = .5*(VERTEX(f,3)[j]-VERTEX(f,0)[j]);
128 }
129 } else if (f->nv == 3) { /* triangle case */
130 int near0 = 2;
131 double dmin = dist2line(src->sloc, VERTEX(f,2), VERTEX(f,0));
132 for (i = 0; i < 2; i++) {
133 double d2 = dist2line(src->sloc, VERTEX(f,i), VERTEX(f,i+1));
134 if (d2 >= dmin)
135 continue;
136 near0 = i;
137 dmin = d2; /* radius = min distance */
138 }
139 if (dmin < .08*f->area)
140 objerror(so, WARNING, "triangular source with poor aspect");
141 i = (near0 + 1) % 3;
142 for (j = 0; j < 3; j++)
143 src->ss[SU][j] = VERTEX(f,i)[j] - VERTEX(f,near0)[j];
144 normalize(src->ss[SU]);
145 dmin = sqrt(dmin);
146 for (j = 0; j < 3; j++)
147 src->ss[SU][j] *= dmin;
148 fcross(src->ss[SV], f->norm, src->ss[SU]);
149 } else
150 setflatss(src); /* hope for convex! */
151 }
152
153
154 void
155 ssetsrc( /* set a source as a source */
156 SRCREC *src,
157 OBJREC *so
158 )
159 {
160 double theta;
161
162 src->sa.success = 2*AIMREQT-1; /* bitch on second failure */
163 src->so = so;
164 if (so->oargs.nfargs != 4)
165 objerror(so, USER, "bad arguments");
166 src->sflags |= (SDISTANT|SCIR);
167 VCOPY(src->sloc, so->oargs.farg);
168 if (normalize(src->sloc) == 0.0)
169 objerror(so, USER, "zero direction");
170 theta = PI/180.0/2.0 * so->oargs.farg[3];
171 if (theta <= FTINY)
172 objerror(so, USER, "zero size");
173 src->ss2 = 2.0*PI * (1.0 - cos(theta));
174 /* the following is approximate */
175 src->srad = sqrt(src->ss2/PI);
176 VCOPY(src->snorm, src->sloc);
177 setflatss(src); /* hey, whatever works */
178 src->ss[SW][0] = src->ss[SW][1] = src->ss[SW][2] = 0.0;
179 }
180
181
182 void
183 sphsetsrc( /* set a sphere as a source */
184 SRCREC *src,
185 OBJREC *so
186 )
187 {
188 int i;
189
190 src->sa.success = 2*AIMREQT-1; /* bitch on second failure */
191 src->so = so;
192 if (so->oargs.nfargs != 4)
193 objerror(so, USER, "bad # arguments");
194 if (so->oargs.farg[3] <= FTINY)
195 objerror(so, USER, "illegal source radius");
196 src->sflags |= SCIR;
197 VCOPY(src->sloc, so->oargs.farg);
198 src->srad = so->oargs.farg[3];
199 src->ss2 = PI * src->srad * src->srad;
200 memset(src->ss, 0, sizeof(src->ss));
201 for (i = 0; i < 3; i++)
202 src->ss[i][i] = 0.7236 * so->oargs.farg[3];
203 }
204
205
206 void
207 rsetsrc( /* set a ring (disk) as a source */
208 SRCREC *src,
209 OBJREC *so
210 )
211 {
212 CONE *co;
213
214 src->sa.success = 2*AIMREQT-1; /* bitch on second failure */
215 src->so = so;
216 /* get the ring */
217 co = getcone(so, 0);
218 if (co == NULL)
219 objerror(so, USER, "illegal source");
220 if (CO_R1(co) <= FTINY)
221 objerror(so, USER, "illegal source radius");
222 VCOPY(src->sloc, CO_P0(co));
223 if (CO_R0(co) > 0.0)
224 objerror(so, USER, "cannot hit source center");
225 src->sflags |= (SFLAT|SCIR);
226 VCOPY(src->snorm, co->ad);
227 src->srad = CO_R1(co);
228 src->ss2 = PI * src->srad * src->srad;
229 setflatss(src);
230 }
231
232
233 void
234 cylsetsrc( /* set a cylinder as a source */
235 SRCREC *src,
236 OBJREC *so
237 )
238 {
239 CONE *co;
240 int i;
241
242 src->sa.success = 4*AIMREQT-1; /* bitch on fourth failure */
243 src->so = so;
244 /* get the cylinder */
245 co = getcone(so, 0);
246 if (co == NULL)
247 objerror(so, USER, "illegal source");
248 if (CO_R0(co) <= FTINY)
249 objerror(so, USER, "illegal source radius");
250 if (CO_R0(co) > .2*co->al) /* heuristic constraint */
251 objerror(so, WARNING, "source aspect too small");
252 src->sflags |= SCYL;
253 for (i = 0; i < 3; i++)
254 src->sloc[i] = .5 * (CO_P1(co)[i] + CO_P0(co)[i]);
255 src->srad = .5*co->al;
256 src->ss2 = 2.*CO_R0(co)*co->al;
257 /* set sampling vectors */
258 for (i = 0; i < 3; i++)
259 src->ss[SU][i] = .5 * co->al * co->ad[i];
260 getperpendicular(src->ss[SW], co->ad, rand_samp);
261 for (i = 0; i < 3; i++)
262 src->ss[SW][i] *= .8559 * CO_R0(co);
263 fcross(src->ss[SV], src->ss[SW], co->ad);
264 }
265
266
267 SPOT *
268 makespot( /* make a spotlight */
269 OBJREC *m
270 )
271 {
272 SPOT *ns;
273
274 if ((ns = (SPOT *)m->os) != NULL)
275 return(ns);
276 if ((ns = (SPOT *)malloc(sizeof(SPOT))) == NULL)
277 return(NULL);
278 if (m->oargs.farg[3] <= FTINY)
279 objerror(m, USER, "zero angle");
280 ns->siz = 2.0*PI * (1.0 - cos(PI/180.0/2.0 * m->oargs.farg[3]));
281 VCOPY(ns->aim, m->oargs.farg+4);
282 if ((ns->flen = normalize(ns->aim)) == 0.0)
283 objerror(m, USER, "zero focus vector");
284 m->os = (char *)ns;
285 return(ns);
286 }
287
288
289 int
290 spotout( /* check if we're outside spot region */
291 RAY *r,
292 SPOT *s
293 )
294 {
295 double d;
296 FVECT vd;
297
298 if (s == NULL)
299 return(0);
300 if (s->flen < -FTINY) { /* distant source */
301 vd[0] = s->aim[0] - r->rorg[0];
302 vd[1] = s->aim[1] - r->rorg[1];
303 vd[2] = s->aim[2] - r->rorg[2];
304 d = DOT(r->rdir,vd);
305 /* wrong side?
306 if (d <= FTINY)
307 return(1); */
308 d = DOT(vd,vd) - d*d;
309 if (PI*d > s->siz)
310 return(1); /* out */
311 return(0); /* OK */
312 }
313 /* local source */
314 if (s->siz < 2.0*PI * (1.0 + DOT(s->aim,r->rdir)))
315 return(1); /* out */
316 return(0); /* OK */
317 }
318
319
320 double
321 fgetmaxdisk( /* get center and squared radius of face */
322 FVECT ocent,
323 OBJREC *op
324 )
325 {
326 double maxrad2;
327 double d;
328 int i, j;
329 FACE *f;
330
331 f = getface(op);
332 if (f->area == 0.)
333 return(0.);
334 for (i = 0; i < 3; i++) {
335 ocent[i] = 0.;
336 for (j = 0; j < f->nv; j++)
337 ocent[i] += VERTEX(f,j)[i];
338 ocent[i] /= (double)f->nv;
339 }
340 d = DOT(ocent,f->norm);
341 for (i = 0; i < 3; i++)
342 ocent[i] += (f->offset - d)*f->norm[i];
343 maxrad2 = 0.;
344 for (j = 0; j < f->nv; j++) {
345 d = dist2(VERTEX(f,j), ocent);
346 if (d > maxrad2)
347 maxrad2 = d;
348 }
349 return(maxrad2);
350 }
351
352
353 double
354 rgetmaxdisk( /* get center and squared radius of ring */
355 FVECT ocent,
356 OBJREC *op
357 )
358 {
359 CONE *co;
360
361 co = getcone(op, 0);
362 if (co == NULL)
363 return(0.);
364 VCOPY(ocent, CO_P0(co));
365 return(CO_R1(co)*CO_R1(co));
366 }
367
368
369 double
370 fgetplaneq( /* get plane equation for face */
371 FVECT nvec,
372 OBJREC *op
373 )
374 {
375 FACE *fo;
376
377 fo = getface(op);
378 VCOPY(nvec, fo->norm);
379 return(fo->offset);
380 }
381
382
383 double
384 rgetplaneq( /* get plane equation for ring */
385 FVECT nvec,
386 OBJREC *op
387 )
388 {
389 CONE *co;
390
391 co = getcone(op, 0);
392 if (co == NULL) {
393 memset(nvec, 0, sizeof(FVECT));
394 return(0.);
395 }
396 VCOPY(nvec, co->ad);
397 return(DOT(nvec, CO_P0(co)));
398 }
399
400
401 int
402 commonspot( /* set sp1 to intersection of sp1 and sp2 */
403 SPOT *sp1,
404 SPOT *sp2,
405 FVECT org
406 )
407 {
408 FVECT cent;
409 double rad2, cos1, cos2;
410
411 cos1 = 1. - sp1->siz/(2.*PI);
412 cos2 = 1. - sp2->siz/(2.*PI);
413 if (sp2->siz >= 2.*PI-FTINY) /* BIG, just check overlap */
414 return(DOT(sp1->aim,sp2->aim) >= cos1*cos2 -
415 sqrt((1.-cos1*cos1)*(1.-cos2*cos2)));
416 /* compute and check disks */
417 rad2 = intercircle(cent, sp1->aim, sp2->aim,
418 1./(cos1*cos1) - 1., 1./(cos2*cos2) - 1.);
419 if (rad2 <= FTINY || normalize(cent) == 0.)
420 return(0);
421 VCOPY(sp1->aim, cent);
422 sp1->siz = 2.*PI*(1. - 1./sqrt(1.+rad2));
423 return(1);
424 }
425
426
427 int
428 commonbeam( /* set sp1 to intersection of sp1 and sp2 */
429 SPOT *sp1,
430 SPOT *sp2,
431 FVECT dir
432 )
433 {
434 FVECT cent, c1, c2;
435 double rad2, d;
436 /* move centers to common plane */
437 d = DOT(sp1->aim, dir);
438 VSUM(c1, sp1->aim, dir, -d);
439 d = DOT(sp2->aim, dir);
440 VSUM(c2, sp2->aim, dir, -d);
441 /* compute overlap */
442 rad2 = intercircle(cent, c1, c2, sp1->siz/PI, sp2->siz/PI);
443 if (rad2 <= FTINY)
444 return(0);
445 VCOPY(sp1->aim, cent);
446 sp1->siz = PI*rad2;
447 return(1);
448 }
449
450
451 int
452 checkspot( /* check spotlight for behind source */
453 SPOT *sp, /* spotlight */
454 FVECT nrm /* source surface normal */
455 )
456 {
457 double d, d1;
458
459 d = DOT(sp->aim, nrm);
460 if (d > FTINY) /* center in front? */
461 return(1);
462 /* else check horizon */
463 d1 = 1. - sp->siz/(2.*PI);
464 return(1.-FTINY-d*d < d1*d1);
465 }
466
467
468 double
469 spotdisk( /* intersect spot with object op */
470 FVECT oc,
471 OBJREC *op,
472 SPOT *sp,
473 FVECT pos
474 )
475 {
476 FVECT onorm;
477 double offs, d, dist;
478
479 offs = getplaneq(onorm, op);
480 d = -DOT(onorm, sp->aim);
481 if (d >= -FTINY && d <= FTINY)
482 return(0.);
483 dist = (DOT(pos, onorm) - offs)/d;
484 if (dist < 0.)
485 return(0.);
486 VSUM(oc, pos, sp->aim, dist);
487 return(sp->siz*dist*dist/PI/(d*d));
488 }
489
490
491 double
492 beamdisk( /* intersect beam with object op */
493 FVECT oc,
494 OBJREC *op,
495 SPOT *sp,
496 FVECT dir
497 )
498 {
499 FVECT onorm;
500 double offs, d, dist;
501
502 offs = getplaneq(onorm, op);
503 d = -DOT(onorm, dir);
504 if (d >= -FTINY && d <= FTINY)
505 return(0.);
506 dist = (DOT(sp->aim, onorm) - offs)/d;
507 VSUM(oc, sp->aim, dir, dist);
508 return(sp->siz/PI/(d*d));
509 }
510
511
512 double
513 intercircle( /* intersect two circles */
514 FVECT cc, /* midpoint (return value) */
515 FVECT c1, /* circle centers */
516 FVECT c2,
517 double r1s, /* radii squared */
518 double r2s
519 )
520 {
521 double a2, d2, l;
522 FVECT disp;
523
524 VSUB(disp, c2, c1);
525 d2 = DOT(disp,disp);
526 /* circle within overlap? */
527 if (r1s < r2s) {
528 if (r2s >= r1s + d2) {
529 VCOPY(cc, c1);
530 return(r1s);
531 }
532 } else {
533 if (r1s >= r2s + d2) {
534 VCOPY(cc, c2);
535 return(r2s);
536 }
537 }
538 a2 = .25*(2.*(r1s+r2s) - d2 - (r2s-r1s)*(r2s-r1s)/d2);
539 /* no overlap? */
540 if (a2 <= 0.)
541 return(0.);
542 /* overlap, compute center */
543 l = sqrt((r1s - a2)/d2);
544 VSUM(cc, c1, disp, l);
545 return(a2);
546 }
