root/radiance/ray/src/rt/srcsamp.c
Revision: 2.23
Committed: Fri Dec 13 00:50:55 2024 UTC (5 months, 2 weeks ago) by greg
Changes since 2.22: +1 -3 lines
perf: Removed debug statement
2 static const char RCSid[] = "$Id: srcsamp.c,v 2.22 2024/11/15 20:47:42 greg Exp $";
5 * Source sampling routines
6 *
7 * External symbols declared in source.h
8 */
9
10 #include "copyright.h"
11
12 #include "ray.h"
13
14 #include "source.h"
15
16 #include "random.h"
17
18 #ifdef SSKIPOPT
19 /* The following table is used for skipping sources */
20 static uby8 *srcskipflags = NULL; /* source inclusion lookup */
21 static int ssf_count = 0; /* number of flag entries */
22 static int ssf_max = 0; /* current array size */
23 static uby8 *ssf_noskip = NULL; /* set of zero flags */
24
25 uby8 *ssf_select = NULL; /* sources we may skip */
26
27 /* Find/allocate source skip flag entry (free all if NULL) */
28 int
29 sskip_rsi(uby8 *flags)
30 {
31 uby8 *flp;
32 int i;
33
34 if (flags == NULL) { /* means clear all */
35 efree(srcskipflags); srcskipflags = NULL;
36 ssf_count = ssf_max = 0;
37 sskip_free(ssf_noskip);
38 sskip_free(ssf_select);
39 return(0);
40 }
41 if (ssf_noskip == NULL) /* first call? */
42 ssf_noskip = sskip_new();
43
44 if (sskip_eq(flags, ssf_noskip))
45 return(-1); /* nothing to skip */
46 /* search recent entries */
47 flp = srcskipflags + ssf_count*SSKIPFLSIZ;
48 for (i = ssf_count; i-- > 0; )
49 if (sskip_eq(flp -= SSKIPFLSIZ, flags))
50 return(-2-i); /* found it! */
51 /* else tack on new entry */
52 if (ssf_count >= ssf_max) { /* need more space? */
53 ssf_max = ssf_count + (ssf_count>>2) + 64;
54 if (ssf_max <= ssf_count &&
55 (ssf_max = ssf_count+1024) <= ssf_count)
56 error(SYSTEM, "out of space in sskip_rsi()");
57
58 srcskipflags = (uby8 *)erealloc(srcskipflags,
59 ssf_max*SSKIPFLSIZ);
60 }
61 sskip_cpy(srcskipflags + ssf_count*SSKIPFLSIZ, flags);
62
63 return(-2 - ssf_count++); /* return index (< -1) */
64 }
65
66 /* Get skip flags associated with RAY rsrc index (or NULL) */
67 uby8 *
68 sskip_flags(int rsi)
69 {
70 if (rsi >= -1)
71 return(ssf_noskip);
72
73 if ((rsi = -2 - rsi) >= ssf_count)
74 error(CONSISTENCY, "bad index to sskip_flags()");
75
76 return(srcskipflags + rsi*SSKIPFLSIZ);
77 }
78
79 /* OR in a second set of flags into a first */
80 void
81 sskip_addflags(uby8 *dfl, const uby8 *sfl)
82 {
83 int nb = SSKIPFLSIZ;
84
85 while (nb--)
86 *dfl++ |= *sfl++;
87 }
88 #endif
89
90 int
91 srcskip( /* pre-emptive test for source to skip */
92 int sn,
93 RAY *r
94 )
95 {
96 SRCREC *sp = source + sn;
97
98 if (sp->sflags & SSKIP)
99 return(1);
100 #ifdef SSKIPOPT
101 if (r->rsrc < -1 && /* ray has custom skip flags? */
102 sskip_chk(sskip_flags(r->rsrc), sn))
103 return(1);
104 #endif
105 if ((sp->sflags & (SPROX|SDISTANT)) != SPROX)
106 return(0);
107
108 return(dist2(r->rorg, sp->sloc) >
109 (sp->sl.prox + sp->srad)*(sp->sl.prox + sp->srad));
110 }
111
112 double
113 nextssamp( /* compute sample for source, rtn. distance */
114 RAY *r, /* origin is read, direction is set */
115 SRCINDEX *si /* source index (modified to current) */
116 )
117 {
118 int cent[3], size[3], parr[2];
119 SRCREC *srcp;
120 double vpos[3];
121 double d;
122 int i;
123 nextsample:
124 while (++si->sp >= si->np) { /* get next sample */
125 if (++si->sn >= nsources)
126 return(0.0); /* no more */
127 if (srcskip(si->sn, r))
128 si->np = 0;
129 else if (srcsizerat <= FTINY)
130 nopart(si, r);
131 else {
132 for (i = si->sn; source[i].sflags & SVIRTUAL;
133 i = source[i].sa.sv.sn)
134 ; /* partition source */
135 (*sfun[source[i].so->otype].of->partit)(si, r);
136 }
137 si->sp = -1;
138 }
139 /* get partition */
140 cent[0] = cent[1] = cent[2] = 0;
141 size[0] = size[1] = size[2] = MAXSPART;
142 parr[0] = 0; parr[1] = si->sp;
143 if (!skipparts(cent, size, parr, si->spt))
144 error(CONSISTENCY, "bad source partition in nextssamp");
145 /* compute sample */
146 srcp = source + si->sn;
147 if (dstrsrc > FTINY) { /* jitter sample */
148 dimlist[ndims] = si->sn + 8831;
149 dimlist[ndims+1] = si->sp + 3109;
150 d = urand(ilhash(dimlist,ndims+2)+samplendx);
151 if (srcp->sflags & SFLAT) {
152 multisamp(vpos, 2, d);
153 vpos[SW] = 0.5;
154 } else
155 multisamp(vpos, 3, d);
156 for (i = 0; i < 3; i++)
157 vpos[i] = dstrsrc * (1. - 2.*vpos[i]) *
158 (double)size[i]*(1.0/MAXSPART);
159 } else
160 vpos[0] = vpos[1] = vpos[2] = 0.0;
161
162 VSUM(vpos, vpos, cent, 1.0/MAXSPART);
163 /* avoid circular aiming failures */
164 if ((srcp->sflags & SCIR) && (si->np > 1) | (dstrsrc > 0.7)) {
165 FVECT trim;
166 if (srcp->sflags & (SFLAT|SDISTANT)) {
167 d = 1.12837917; /* correct setflatss() */
168 trim[SU] = d*sqrt(1.0 - 0.5*vpos[SV]*vpos[SV]);
169 trim[SV] = d*sqrt(1.0 - 0.5*vpos[SU]*vpos[SU]);
170 trim[SW] = 0.0;
171 } else {
172 trim[SW] = trim[SU] = vpos[SU]*vpos[SU];
173 d = vpos[SV]*vpos[SV];
174 if (d > trim[SW]) trim[SW] = d;
175 trim[SU] += d;
176 d = vpos[SW]*vpos[SW];
177 if (d > trim[SW]) trim[SW] = d;
178 trim[SU] += d;
179 if (trim[SU] > FTINY*FTINY) {
180 d = 1.0/0.7236; /* correct sphsetsrc() */
181 trim[SW] = trim[SV] = trim[SU] =
182 d*sqrt(trim[SW]/trim[SU]);
183 } else
184 trim[SW] = trim[SV] = trim[SU] = 0.0;
185 }
186 for (i = 0; i < 3; i++)
187 vpos[i] *= trim[i];
188 }
189 /* compute direction */
190 for (i = 0; i < 3; i++)
191 r->rdir[i] = srcp->sloc[i] +
192 vpos[SU]*srcp->ss[SU][i] +
193 vpos[SV]*srcp->ss[SV][i] +
194 vpos[SW]*srcp->ss[SW][i];
195
196 if (!(srcp->sflags & SDISTANT))
197 VSUB(r->rdir, r->rdir, r->rorg);
198 /* compute distance */
199 if ((d = normalize(r->rdir)) == 0.0)
200 goto nextsample; /* at source! */
201
202 /* compute sample size */
203 if (srcp->sflags & SFLAT) {
204 si->dom = sflatform(si->sn, r->rdir);
205 si->dom *= size[SU]*size[SV]*(1.0/MAXSPART/MAXSPART);
206 } else if (srcp->sflags & SCYL) {
207 si->dom = scylform(si->sn, r->rdir);
208 si->dom *= size[SU]*(1.0/MAXSPART);
209 } else {
210 si->dom = size[SU]*size[SV]*(double)size[SW] *
211 (1.0/MAXSPART/MAXSPART/MAXSPART) ;
212 }
213 if (srcp->sflags & SDISTANT) {
214 si->dom *= srcp->ss2;
215 return(FHUGE);
216 }
217 if (si->dom <= 1e-4)
218 goto nextsample; /* behind source? */
219 si->dom *= srcp->ss2/(d*d);
220 return(d); /* sample OK, return distance */
221 }
222
223
224 int
225 skipparts( /* skip to requested partition */
226 int ct[3],
227 int sz[3], /* center and size of partition (returned) */
228 int pp[2], /* current index, number to skip (modified) */
229 unsigned char *pt /* partition array */
230 )
231 {
232 int p;
233 /* check this partition */
234 p = spart(pt, pp[0]);
235 pp[0]++;
236 if (p == S0) { /* leaf partition */
237 if (pp[1]) {
238 pp[1]--;
239 return(0); /* not there yet */
240 } else
241 return(1); /* we've arrived */
242 }
243 /* else check lower */
244 sz[p] >>= 1;
245 ct[p] -= sz[p];
246 if (skipparts(ct, sz, pp, pt))
247 return(1); /* return hit */
248 /* else check upper */
249 ct[p] += sz[p] << 1;
250 if (skipparts(ct, sz, pp, pt))
251 return(1); /* return hit */
252 /* else return to starting position */
253 ct[p] -= sz[p];
254 sz[p] <<= 1;
255 return(0); /* return miss */
256 }
257
258
259 void
260 nopart( /* single source partition */
261 SRCINDEX *si,
262 RAY *r
263 )
264 {
265 clrpart(si->spt);
266 setpart(si->spt, 0, S0);
267 si->np = 1;
268 }
269
270
271 static int
272 cyl_partit( /* slice a cylinder */
273 FVECT ro,
274 unsigned char *pt,
275 int *pi,
276 int mp,
277 FVECT cent,
278 FVECT axis,
279 double d2
280 )
281 {
282 FVECT newct, newax;
283 int npl, npu;
284
285 if (mp < 2 || dist2(ro, cent) >= d2) { /* hit limit? */
286 setpart(pt, *pi, S0);
287 (*pi)++;
288 return(1);
289 }
290 /* subdivide */
291 setpart(pt, *pi, SU);
292 (*pi)++;
293 newax[0] = .5*axis[0];
294 newax[1] = .5*axis[1];
295 newax[2] = .5*axis[2];
296 d2 *= 0.25;
297 /* lower half */
298 newct[0] = cent[0] - newax[0];
299 newct[1] = cent[1] - newax[1];
300 newct[2] = cent[2] - newax[2];
301 npl = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2);
302 /* upper half */
303 newct[0] = cent[0] + newax[0];
304 newct[1] = cent[1] + newax[1];
305 newct[2] = cent[2] + newax[2];
306 npu = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2);
307 /* return total */
308 return(npl + npu);
309 }
310
311
312 void
313 cylpart( /* partition a cylinder */
314 SRCINDEX *si,
315 RAY *r
316 )
317 {
318 double dist2, safedist2, dist2cent, rad2;
319 FVECT v;
320 SRCREC *sp;
321 int pi;
322 /* first check point location */
323 clrpart(si->spt);
324 sp = source + si->sn;
325 rad2 = 1.365 * DOT(sp->ss[SV],sp->ss[SV]);
326 v[0] = r->rorg[0] - sp->sloc[0];
327 v[1] = r->rorg[1] - sp->sloc[1];
328 v[2] = r->rorg[2] - sp->sloc[2];
329 dist2 = DOT(v,sp->ss[SU]);
330 safedist2 = DOT(sp->ss[SU],sp->ss[SU]);
331 dist2 *= dist2 / safedist2;
332 dist2cent = DOT(v,v);
333 dist2 = dist2cent - dist2;
334 if (dist2 <= rad2) { /* point inside extended cylinder */
335 si->np = 0;
336 return;
337 }
338 safedist2 *= 4.*r->rweight*r->rweight/(srcsizerat*srcsizerat);
339 if (dist2 <= 4.*rad2 || /* point too close to subdivide */
340 dist2cent >= safedist2) { /* or too far */
341 setpart(si->spt, 0, S0);
342 si->np = 1;
343 return;
344 }
345 pi = 0;
346 si->np = cyl_partit(r->rorg, si->spt, &pi, MAXSPART,
347 sp->sloc, sp->ss[SU], safedist2);
348 }
349
350
351 static int
352 flt_partit( /* partition flatty */
353 FVECT ro,
354 unsigned char *pt,
355 int *pi,
356 int mp,
357 FVECT cent,
358 FVECT u,
359 FVECT v,
360 double du2,
361 double dv2
362 )
363 {
364 double d2;
365 FVECT newct, newax;
366 int npl, npu;
367
368 if (mp < 2 || ((d2 = dist2(ro, cent)) >= du2
369 && d2 >= dv2)) { /* hit limit? */
370 setpart(pt, *pi, S0);
371 (*pi)++;
372 return(1);
373 }
374 if (du2 > dv2) { /* subdivide in U */
375 setpart(pt, *pi, SU);
376 (*pi)++;
377 newax[0] = .5*u[0];
378 newax[1] = .5*u[1];
379 newax[2] = .5*u[2];
380 u = newax;
381 du2 *= 0.25;
382 } else { /* subdivide in V */
383 setpart(pt, *pi, SV);
384 (*pi)++;
385 newax[0] = .5*v[0];
386 newax[1] = .5*v[1];
387 newax[2] = .5*v[2];
388 v = newax;
389 dv2 *= 0.25;
390 }
391 /* lower half */
392 newct[0] = cent[0] - newax[0];
393 newct[1] = cent[1] - newax[1];
394 newct[2] = cent[2] - newax[2];
395 npl = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2);
396 /* upper half */
397 newct[0] = cent[0] + newax[0];
398 newct[1] = cent[1] + newax[1];
399 newct[2] = cent[2] + newax[2];
400 npu = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2);
401 /* return total */
402 return(npl + npu);
403 }
404
405
406 void
407 flatpart( /* partition a flat source */
408 SRCINDEX *si,
409 RAY *r
410 )
411 {
412 RREAL *vp;
413 FVECT v;
414 double du2, dv2;
415 int pi;
416
417 clrpart(si->spt);
418 vp = source[si->sn].sloc;
419 v[0] = r->rorg[0] - vp[0];
420 v[1] = r->rorg[1] - vp[1];
421 v[2] = r->rorg[2] - vp[2];
422 vp = source[si->sn].snorm;
423 if (DOT(v,vp) <= 0.) { /* behind source */
424 si->np = 0;
425 return;
426 }
427 dv2 = 2.*r->rweight/srcsizerat;
428 dv2 *= dv2;
429 vp = source[si->sn].ss[SU];
430 du2 = dv2 * DOT(vp,vp);
431 vp = source[si->sn].ss[SV];
432 dv2 *= DOT(vp,vp);
433 pi = 0;
434 si->np = flt_partit(r->rorg, si->spt, &pi, MAXSPART,
435 source[si->sn].sloc,
436 source[si->sn].ss[SU], source[si->sn].ss[SV], du2, dv2);
437 }
438
439
440 double
441 scylform( /* compute cosine for cylinder's projection */
442 int sn,
443 FVECT dir /* assume normalized */
444 )
445 {
446 RREAL *dv;
447 double d;
448
449 dv = source[sn].ss[SU];
450 d = DOT(dir, dv);
451 d *= d / DOT(dv,dv);
452 return(sqrt(1. - d));
453 }
