1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: srcsamp.c,v 2.22 2024/11/15 20:47:42 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Source sampling routines |
6 |
7 |
* External symbols declared in source.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "ray.h" |
13 |
14 |
#include "source.h" |
15 |
16 |
#include "random.h" |
17 |
18 |
#ifdef SSKIPOPT |
19 |
/* The following table is used for skipping sources */ |
20 |
static uby8 *srcskipflags = NULL; /* source inclusion lookup */ |
21 |
static int ssf_count = 0; /* number of flag entries */ |
22 |
static int ssf_max = 0; /* current array size */ |
23 |
static uby8 *ssf_noskip = NULL; /* set of zero flags */ |
24 |
25 |
uby8 *ssf_select = NULL; /* sources we may skip */ |
26 |
27 |
/* Find/allocate source skip flag entry (free all if NULL) */ |
28 |
int |
29 |
sskip_rsi(uby8 *flags) |
30 |
31 |
uby8 *flp; |
32 |
int i; |
33 |
34 |
if (flags == NULL) { /* means clear all */ |
35 |
efree(srcskipflags); srcskipflags = NULL; |
36 |
ssf_count = ssf_max = 0; |
37 |
sskip_free(ssf_noskip); |
38 |
sskip_free(ssf_select); |
39 |
return(0); |
40 |
41 |
if (ssf_noskip == NULL) /* first call? */ |
42 |
ssf_noskip = sskip_new(); |
43 |
44 |
if (sskip_eq(flags, ssf_noskip)) |
45 |
return(-1); /* nothing to skip */ |
46 |
/* search recent entries */ |
47 |
flp = srcskipflags + ssf_count*SSKIPFLSIZ; |
48 |
for (i = ssf_count; i-- > 0; ) |
49 |
if (sskip_eq(flp -= SSKIPFLSIZ, flags)) |
50 |
return(-2-i); /* found it! */ |
51 |
/* else tack on new entry */ |
52 |
if (ssf_count >= ssf_max) { /* need more space? */ |
53 |
ssf_max = ssf_count + (ssf_count>>2) + 64; |
54 |
if (ssf_max <= ssf_count && |
55 |
(ssf_max = ssf_count+1024) <= ssf_count) |
56 |
error(SYSTEM, "out of space in sskip_rsi()"); |
57 |
58 |
srcskipflags = (uby8 *)erealloc(srcskipflags, |
59 |
ssf_max*SSKIPFLSIZ); |
60 |
61 |
sskip_cpy(srcskipflags + ssf_count*SSKIPFLSIZ, flags); |
62 |
63 |
return(-2 - ssf_count++); /* return index (< -1) */ |
64 |
65 |
66 |
/* Get skip flags associated with RAY rsrc index (or NULL) */ |
67 |
uby8 * |
68 |
sskip_flags(int rsi) |
69 |
70 |
if (rsi >= -1) |
71 |
return(ssf_noskip); |
72 |
73 |
if ((rsi = -2 - rsi) >= ssf_count) |
74 |
error(CONSISTENCY, "bad index to sskip_flags()"); |
75 |
76 |
return(srcskipflags + rsi*SSKIPFLSIZ); |
77 |
78 |
79 |
/* OR in a second set of flags into a first */ |
80 |
void |
81 |
sskip_addflags(uby8 *dfl, const uby8 *sfl) |
82 |
83 |
int nb = SSKIPFLSIZ; |
84 |
85 |
while (nb--) |
86 |
*dfl++ |= *sfl++; |
87 |
88 |
#endif |
89 |
90 |
int |
91 |
srcskip( /* pre-emptive test for source to skip */ |
92 |
int sn, |
93 |
RAY *r |
94 |
95 |
96 |
SRCREC *sp = source + sn; |
97 |
98 |
if (sp->sflags & SSKIP) |
99 |
return(1); |
100 |
#ifdef SSKIPOPT |
101 |
if (r->rsrc < -1 && /* ray has custom skip flags? */ |
102 |
sskip_chk(sskip_flags(r->rsrc), sn)) |
103 |
return(1); |
104 |
#endif |
105 |
if ((sp->sflags & (SPROX|SDISTANT)) != SPROX) |
106 |
return(0); |
107 |
108 |
return(dist2(r->rorg, sp->sloc) > |
109 |
(sp->sl.prox + sp->srad)*(sp->sl.prox + sp->srad)); |
110 |
111 |
112 |
double |
113 |
nextssamp( /* compute sample for source, rtn. distance */ |
114 |
RAY *r, /* origin is read, direction is set */ |
115 |
SRCINDEX *si /* source index (modified to current) */ |
116 |
117 |
118 |
int cent[3], size[3], parr[2]; |
119 |
SRCREC *srcp; |
120 |
double vpos[3]; |
121 |
double d; |
122 |
int i; |
123 |
nextsample: |
124 |
while (++si->sp >= si->np) { /* get next sample */ |
125 |
if (++si->sn >= nsources) |
126 |
return(0.0); /* no more */ |
127 |
if (srcskip(si->sn, r)) |
128 |
si->np = 0; |
129 |
else if (srcsizerat <= FTINY) |
130 |
nopart(si, r); |
131 |
else { |
132 |
for (i = si->sn; source[i].sflags & SVIRTUAL; |
133 |
i = source[i].sa.sv.sn) |
134 |
; /* partition source */ |
135 |
(*sfun[source[i].so->otype].of->partit)(si, r); |
136 |
137 |
si->sp = -1; |
138 |
139 |
/* get partition */ |
140 |
cent[0] = cent[1] = cent[2] = 0; |
141 |
size[0] = size[1] = size[2] = MAXSPART; |
142 |
parr[0] = 0; parr[1] = si->sp; |
143 |
if (!skipparts(cent, size, parr, si->spt)) |
144 |
error(CONSISTENCY, "bad source partition in nextssamp"); |
145 |
/* compute sample */ |
146 |
srcp = source + si->sn; |
147 |
if (dstrsrc > FTINY) { /* jitter sample */ |
148 |
dimlist[ndims] = si->sn + 8831; |
149 |
dimlist[ndims+1] = si->sp + 3109; |
150 |
d = urand(ilhash(dimlist,ndims+2)+samplendx); |
151 |
if (srcp->sflags & SFLAT) { |
152 |
multisamp(vpos, 2, d); |
153 |
vpos[SW] = 0.5; |
154 |
} else |
155 |
multisamp(vpos, 3, d); |
156 |
for (i = 0; i < 3; i++) |
157 |
vpos[i] = dstrsrc * (1. - 2.*vpos[i]) * |
158 |
(double)size[i]*(1.0/MAXSPART); |
159 |
} else |
160 |
vpos[0] = vpos[1] = vpos[2] = 0.0; |
161 |
162 |
VSUM(vpos, vpos, cent, 1.0/MAXSPART); |
163 |
/* avoid circular aiming failures */ |
164 |
if ((srcp->sflags & SCIR) && (si->np > 1) | (dstrsrc > 0.7)) { |
165 |
FVECT trim; |
166 |
if (srcp->sflags & (SFLAT|SDISTANT)) { |
167 |
d = 1.12837917; /* correct setflatss() */ |
168 |
trim[SU] = d*sqrt(1.0 - 0.5*vpos[SV]*vpos[SV]); |
169 |
trim[SV] = d*sqrt(1.0 - 0.5*vpos[SU]*vpos[SU]); |
170 |
trim[SW] = 0.0; |
171 |
} else { |
172 |
trim[SW] = trim[SU] = vpos[SU]*vpos[SU]; |
173 |
d = vpos[SV]*vpos[SV]; |
174 |
if (d > trim[SW]) trim[SW] = d; |
175 |
trim[SU] += d; |
176 |
d = vpos[SW]*vpos[SW]; |
177 |
178 |
trim[SU] += d; |
179 |
if (trim[SU] > FTINY*FTINY) { |
180 |
d = 1.0/0.7236; /* correct sphsetsrc() */ |
181 |
trim[SW] = trim[SV] = trim[SU] = |
182 |
d*sqrt(trim[SW]/trim[SU]); |
183 |
} else |
184 |
trim[SW] = trim[SV] = trim[SU] = 0.0; |
185 |
186 |
187 |
vpos[i] *= trim[i]; |
188 |
189 |
/* compute direction */ |
190 |
191 |
r->rdir[i] = srcp->sloc[i] + |
192 |
vpos[SU]*srcp->ss[SU][i] + |
193 |
vpos[SV]*srcp->ss[SV][i] + |
194 |
vpos[SW]*srcp->ss[SW][i]; |
195 |
196 |
if (!(srcp->sflags & SDISTANT)) |
197 |
VSUB(r->rdir, r->rdir, r->rorg); |
198 |
/* compute distance */ |
199 |
if ((d = normalize(r->rdir)) == 0.0) |
200 |
goto nextsample; /* at source! */ |
201 |
202 |
/* compute sample size */ |
203 |
204 |
si->dom = sflatform(si->sn, r->rdir); |
205 |
si->dom *= size[SU]*size[SV]*(1.0/MAXSPART/MAXSPART); |
206 |
} else if (srcp->sflags & SCYL) { |
207 |
si->dom = scylform(si->sn, r->rdir); |
208 |
si->dom *= size[SU]*(1.0/MAXSPART); |
209 |
} else { |
210 |
si->dom = size[SU]*size[SV]*(double)size[SW] * |
211 |
(1.0/MAXSPART/MAXSPART/MAXSPART) ; |
212 |
213 |
if (srcp->sflags & SDISTANT) { |
214 |
si->dom *= srcp->ss2; |
215 |
return(FHUGE); |
216 |
217 |
if (si->dom <= 1e-4) |
218 |
goto nextsample; /* behind source? */ |
219 |
si->dom *= srcp->ss2/(d*d); |
220 |
return(d); /* sample OK, return distance */ |
221 |
222 |
223 |
224 |
int |
225 |
skipparts( /* skip to requested partition */ |
226 |
int ct[3], |
227 |
int sz[3], /* center and size of partition (returned) */ |
228 |
int pp[2], /* current index, number to skip (modified) */ |
229 |
unsigned char *pt /* partition array */ |
230 |
231 |
232 |
int p; |
233 |
/* check this partition */ |
234 |
p = spart(pt, pp[0]); |
235 |
pp[0]++; |
236 |
if (p == S0) { /* leaf partition */ |
237 |
if (pp[1]) { |
238 |
pp[1]--; |
239 |
return(0); /* not there yet */ |
240 |
} else |
241 |
return(1); /* we've arrived */ |
242 |
243 |
/* else check lower */ |
244 |
sz[p] >>= 1; |
245 |
ct[p] -= sz[p]; |
246 |
if (skipparts(ct, sz, pp, pt)) |
247 |
return(1); /* return hit */ |
248 |
/* else check upper */ |
249 |
ct[p] += sz[p] << 1; |
250 |
251 |
252 |
/* else return to starting position */ |
253 |
ct[p] -= sz[p]; |
254 |
sz[p] <<= 1; |
255 |
return(0); /* return miss */ |
256 |
257 |
258 |
259 |
void |
260 |
nopart( /* single source partition */ |
261 |
SRCINDEX *si, |
262 |
RAY *r |
263 |
264 |
265 |
clrpart(si->spt); |
266 |
setpart(si->spt, 0, S0); |
267 |
si->np = 1; |
268 |
269 |
270 |
271 |
static int |
272 |
cyl_partit( /* slice a cylinder */ |
273 |
FVECT ro, |
274 |
unsigned char *pt, |
275 |
int *pi, |
276 |
int mp, |
277 |
FVECT cent, |
278 |
FVECT axis, |
279 |
double d2 |
280 |
281 |
282 |
FVECT newct, newax; |
283 |
int npl, npu; |
284 |
285 |
if (mp < 2 || dist2(ro, cent) >= d2) { /* hit limit? */ |
286 |
setpart(pt, *pi, S0); |
287 |
(*pi)++; |
288 |
return(1); |
289 |
290 |
/* subdivide */ |
291 |
setpart(pt, *pi, SU); |
292 |
(*pi)++; |
293 |
newax[0] = .5*axis[0]; |
294 |
newax[1] = .5*axis[1]; |
295 |
newax[2] = .5*axis[2]; |
296 |
d2 *= 0.25; |
297 |
/* lower half */ |
298 |
newct[0] = cent[0] - newax[0]; |
299 |
newct[1] = cent[1] - newax[1]; |
300 |
newct[2] = cent[2] - newax[2]; |
301 |
npl = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2); |
302 |
/* upper half */ |
303 |
newct[0] = cent[0] + newax[0]; |
304 |
newct[1] = cent[1] + newax[1]; |
305 |
newct[2] = cent[2] + newax[2]; |
306 |
npu = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2); |
307 |
/* return total */ |
308 |
return(npl + npu); |
309 |
310 |
311 |
312 |
void |
313 |
cylpart( /* partition a cylinder */ |
314 |
SRCINDEX *si, |
315 |
RAY *r |
316 |
317 |
318 |
double dist2, safedist2, dist2cent, rad2; |
319 |
FVECT v; |
320 |
SRCREC *sp; |
321 |
int pi; |
322 |
/* first check point location */ |
323 |
clrpart(si->spt); |
324 |
sp = source + si->sn; |
325 |
rad2 = 1.365 * DOT(sp->ss[SV],sp->ss[SV]); |
326 |
v[0] = r->rorg[0] - sp->sloc[0]; |
327 |
v[1] = r->rorg[1] - sp->sloc[1]; |
328 |
v[2] = r->rorg[2] - sp->sloc[2]; |
329 |
dist2 = DOT(v,sp->ss[SU]); |
330 |
safedist2 = DOT(sp->ss[SU],sp->ss[SU]); |
331 |
dist2 *= dist2 / safedist2; |
332 |
dist2cent = DOT(v,v); |
333 |
dist2 = dist2cent - dist2; |
334 |
if (dist2 <= rad2) { /* point inside extended cylinder */ |
335 |
si->np = 0; |
336 |
return; |
337 |
338 |
safedist2 *= 4.*r->rweight*r->rweight/(srcsizerat*srcsizerat); |
339 |
if (dist2 <= 4.*rad2 || /* point too close to subdivide */ |
340 |
dist2cent >= safedist2) { /* or too far */ |
341 |
342 |
si->np = 1; |
343 |
return; |
344 |
345 |
pi = 0; |
346 |
si->np = cyl_partit(r->rorg, si->spt, &pi, MAXSPART, |
347 |
sp->sloc, sp->ss[SU], safedist2); |
348 |
349 |
350 |
351 |
static int |
352 |
flt_partit( /* partition flatty */ |
353 |
FVECT ro, |
354 |
355 |
int *pi, |
356 |
int mp, |
357 |
FVECT cent, |
358 |
FVECT u, |
359 |
FVECT v, |
360 |
double du2, |
361 |
double dv2 |
362 |
363 |
364 |
double d2; |
365 |
366 |
int npl, npu; |
367 |
368 |
if (mp < 2 || ((d2 = dist2(ro, cent)) >= du2 |
369 |
&& d2 >= dv2)) { /* hit limit? */ |
370 |
371 |
(*pi)++; |
372 |
return(1); |
373 |
374 |
if (du2 > dv2) { /* subdivide in U */ |
375 |
376 |
(*pi)++; |
377 |
newax[0] = .5*u[0]; |
378 |
newax[1] = .5*u[1]; |
379 |
newax[2] = .5*u[2]; |
380 |
u = newax; |
381 |
du2 *= 0.25; |
382 |
} else { /* subdivide in V */ |
383 |
setpart(pt, *pi, SV); |
384 |
(*pi)++; |
385 |
newax[0] = .5*v[0]; |
386 |
newax[1] = .5*v[1]; |
387 |
newax[2] = .5*v[2]; |
388 |
v = newax; |
389 |
dv2 *= 0.25; |
390 |
391 |
/* lower half */ |
392 |
393 |
394 |
395 |
npl = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2); |
396 |
/* upper half */ |
397 |
398 |
399 |
400 |
npu = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2); |
401 |
402 |
403 |
404 |
405 |
406 |
void |
407 |
flatpart( /* partition a flat source */ |
408 |
SRCINDEX *si, |
409 |
RAY *r |
410 |
411 |
412 |
RREAL *vp; |
413 |
FVECT v; |
414 |
double du2, dv2; |
415 |
int pi; |
416 |
417 |
clrpart(si->spt); |
418 |
vp = source[si->sn].sloc; |
419 |
v[0] = r->rorg[0] - vp[0]; |
420 |
v[1] = r->rorg[1] - vp[1]; |
421 |
v[2] = r->rorg[2] - vp[2]; |
422 |
vp = source[si->sn].snorm; |
423 |
if (DOT(v,vp) <= 0.) { /* behind source */ |
424 |
si->np = 0; |
425 |
return; |
426 |
427 |
dv2 = 2.*r->rweight/srcsizerat; |
428 |
dv2 *= dv2; |
429 |
vp = source[si->sn].ss[SU]; |
430 |
du2 = dv2 * DOT(vp,vp); |
431 |
vp = source[si->sn].ss[SV]; |
432 |
dv2 *= DOT(vp,vp); |
433 |
pi = 0; |
434 |
si->np = flt_partit(r->rorg, si->spt, &pi, MAXSPART, |
435 |
source[si->sn].sloc, |
436 |
source[si->sn].ss[SU], source[si->sn].ss[SV], du2, dv2); |
437 |
438 |
439 |
440 |
double |
441 |
scylform( /* compute cosine for cylinder's projection */ |
442 |
int sn, |
443 |
FVECT dir /* assume normalized */ |
444 |
445 |
446 |
RREAL *dv; |
447 |
double d; |
448 |
449 |
dv = source[sn].ss[SU]; |
450 |
d = DOT(dir, dv); |
451 |
d *= d / DOT(dv,dv); |
452 |
return(sqrt(1. - d)); |
453 |
