1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: srcsamp.c,v 2.13 2008/12/07 19:25:23 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Source sampling routines |
6 |
7 |
* External symbols declared in source.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "ray.h" |
13 |
14 |
#include "source.h" |
15 |
16 |
#include "random.h" |
17 |
18 |
19 |
static int cyl_partit(), flt_partit(); |
20 |
21 |
22 |
double |
23 |
nextssamp(r, si) /* compute sample for source, rtn. distance */ |
24 |
register RAY *r; /* origin is read, direction is set */ |
25 |
register SRCINDEX *si; /* source index (modified to current) */ |
26 |
27 |
int cent[3], size[3], parr[2]; |
28 |
FVECT vpos; |
29 |
double d; |
30 |
register int i; |
31 |
nextsample: |
32 |
while (++si->sp >= si->np) { /* get next sample */ |
33 |
if (++si->sn >= nsources) |
34 |
return(0.0); /* no more */ |
35 |
if (source[si->sn].sflags & SSKIP) |
36 |
si->np = 0; |
37 |
else if (srcsizerat <= FTINY) |
38 |
nopart(si, r); |
39 |
else { |
40 |
for (i = si->sn; source[i].sflags & SVIRTUAL; |
41 |
i = source[i].sa.sv.sn) |
42 |
; /* partition source */ |
43 |
(*sfun[source[i].so->otype].of->partit)(si, r); |
44 |
45 |
si->sp = -1; |
46 |
47 |
/* get partition */ |
48 |
cent[0] = cent[1] = cent[2] = 0; |
49 |
size[0] = size[1] = size[2] = MAXSPART; |
50 |
parr[0] = 0; parr[1] = si->sp; |
51 |
if (!skipparts(cent, size, parr, si->spt)) |
52 |
error(CONSISTENCY, "bad source partition in nextssamp"); |
53 |
/* compute sample */ |
54 |
if (dstrsrc > FTINY) { /* jitter sample */ |
55 |
dimlist[ndims] = si->sn + 8831; |
56 |
dimlist[ndims+1] = si->sp + 3109; |
57 |
d = urand(ilhash(dimlist,ndims+2)+samplendx); |
58 |
if (source[si->sn].sflags & SFLAT) { |
59 |
multisamp(vpos, 2, d); |
60 |
vpos[SW] = 0.5; |
61 |
} else |
62 |
multisamp(vpos, 3, d); |
63 |
for (i = 0; i < 3; i++) |
64 |
vpos[i] = dstrsrc * (1. - 2.*vpos[i]) * |
65 |
(double)size[i]/MAXSPART; |
66 |
} else |
67 |
vpos[0] = vpos[1] = vpos[2] = 0.0; |
68 |
69 |
70 |
vpos[i] += (double)cent[i]/MAXSPART; |
71 |
/* avoid circular aiming failures */ |
72 |
if ((source[si->sn].sflags & SCIR) && (si->np > 1 || dstrsrc > 0.7)) { |
73 |
FVECT trim; |
74 |
if (source[si->sn].sflags & (SFLAT|SDISTANT)) { |
75 |
d = 1.12837917; /* correct setflatss() */ |
76 |
trim[SU] = d*sqrt(1.0 - 0.5*vpos[SV]*vpos[SV]); |
77 |
trim[SV] = d*sqrt(1.0 - 0.5*vpos[SU]*vpos[SU]); |
78 |
trim[SW] = 0.0; |
79 |
} else { |
80 |
trim[SW] = trim[SU] = vpos[SU]*vpos[SU]; |
81 |
d = vpos[SV]*vpos[SV]; |
82 |
if (d > trim[SW]) trim[SW] = d; |
83 |
trim[SU] += d; |
84 |
d = vpos[SW]*vpos[SW]; |
85 |
86 |
trim[SU] += d; |
87 |
d = 1.0/0.7236; /* correct sphsetsrc() */ |
88 |
trim[SW] = trim[SV] = trim[SU] = |
89 |
d*sqrt(trim[SW]/trim[SU]); |
90 |
91 |
92 |
vpos[i] *= trim[i]; |
93 |
94 |
/* compute direction */ |
95 |
96 |
r->rdir[i] = source[si->sn].sloc[i] + |
97 |
vpos[SU]*source[si->sn].ss[SU][i] + |
98 |
vpos[SV]*source[si->sn].ss[SV][i] + |
99 |
vpos[SW]*source[si->sn].ss[SW][i]; |
100 |
101 |
if (!(source[si->sn].sflags & SDISTANT)) |
102 |
103 |
r->rdir[i] -= r->rorg[i]; |
104 |
/* compute distance */ |
105 |
if ((d = normalize(r->rdir)) == 0.0) |
106 |
goto nextsample; /* at source! */ |
107 |
108 |
/* compute sample size */ |
109 |
110 |
si->dom = sflatform(si->sn, r->rdir); |
111 |
si->dom *= size[SU]*size[SV]/(MAXSPART*(double)MAXSPART); |
112 |
} else if (source[si->sn].sflags & SCYL) { |
113 |
si->dom = scylform(si->sn, r->rdir); |
114 |
si->dom *= size[SU]/(double)MAXSPART; |
115 |
} else { |
116 |
si->dom = size[SU]*size[SV]*(double)size[SW] / |
117 |
(MAXSPART*MAXSPART*(double)MAXSPART) ; |
118 |
119 |
if (source[si->sn].sflags & SDISTANT) { |
120 |
si->dom *= source[si->sn].ss2; |
121 |
return(FHUGE); |
122 |
123 |
if (si->dom <= 1e-4) |
124 |
goto nextsample; /* behind source? */ |
125 |
si->dom *= source[si->sn].ss2/(d*d); |
126 |
return(d); /* sample OK, return distance */ |
127 |
128 |
129 |
130 |
int |
131 |
skipparts(ct, sz, pp, pt) /* skip to requested partition */ |
132 |
int ct[3], sz[3]; /* center and size of partition (returned) */ |
133 |
register int pp[2]; /* current index, number to skip (modified) */ |
134 |
unsigned char *pt; /* partition array */ |
135 |
136 |
register int p; |
137 |
/* check this partition */ |
138 |
p = spart(pt, pp[0]); |
139 |
pp[0]++; |
140 |
if (p == S0) { /* leaf partition */ |
141 |
if (pp[1]) { |
142 |
pp[1]--; |
143 |
return(0); /* not there yet */ |
144 |
} else |
145 |
return(1); /* we've arrived */ |
146 |
147 |
/* else check lower */ |
148 |
sz[p] >>= 1; |
149 |
ct[p] -= sz[p]; |
150 |
if (skipparts(ct, sz, pp, pt)) |
151 |
return(1); /* return hit */ |
152 |
/* else check upper */ |
153 |
ct[p] += sz[p] << 1; |
154 |
155 |
156 |
/* else return to starting position */ |
157 |
ct[p] -= sz[p]; |
158 |
sz[p] <<= 1; |
159 |
return(0); /* return miss */ |
160 |
161 |
162 |
163 |
void |
164 |
nopart(si, r) /* single source partition */ |
165 |
register SRCINDEX *si; |
166 |
RAY *r; |
167 |
168 |
clrpart(si->spt); |
169 |
setpart(si->spt, 0, S0); |
170 |
si->np = 1; |
171 |
172 |
173 |
174 |
void |
175 |
cylpart(si, r) /* partition a cylinder */ |
176 |
SRCINDEX *si; |
177 |
register RAY *r; |
178 |
179 |
double dist2, safedist2, dist2cent, rad2; |
180 |
FVECT v; |
181 |
register SRCREC *sp; |
182 |
int pi; |
183 |
/* first check point location */ |
184 |
clrpart(si->spt); |
185 |
sp = source + si->sn; |
186 |
rad2 = 1.365 * DOT(sp->ss[SV],sp->ss[SV]); |
187 |
v[0] = r->rorg[0] - sp->sloc[0]; |
188 |
v[1] = r->rorg[1] - sp->sloc[1]; |
189 |
v[2] = r->rorg[2] - sp->sloc[2]; |
190 |
dist2 = DOT(v,sp->ss[SU]); |
191 |
safedist2 = DOT(sp->ss[SU],sp->ss[SU]); |
192 |
dist2 *= dist2 / safedist2; |
193 |
dist2cent = DOT(v,v); |
194 |
dist2 = dist2cent - dist2; |
195 |
if (dist2 <= rad2) { /* point inside extended cylinder */ |
196 |
si->np = 0; |
197 |
return; |
198 |
199 |
safedist2 *= 4.*r->rweight*r->rweight/(srcsizerat*srcsizerat); |
200 |
if (dist2 <= 4.*rad2 || /* point too close to subdivide */ |
201 |
dist2cent >= safedist2) { /* or too far */ |
202 |
203 |
si->np = 1; |
204 |
return; |
205 |
206 |
pi = 0; |
207 |
si->np = cyl_partit(r->rorg, si->spt, &pi, MAXSPART, |
208 |
sp->sloc, sp->ss[SU], safedist2); |
209 |
210 |
211 |
212 |
static int |
213 |
cyl_partit(ro, pt, pi, mp, cent, axis, d2) /* slice a cylinder */ |
214 |
FVECT ro; |
215 |
unsigned char *pt; |
216 |
register int *pi; |
217 |
int mp; |
218 |
FVECT cent, axis; |
219 |
double d2; |
220 |
221 |
FVECT newct, newax; |
222 |
int npl, npu; |
223 |
224 |
if (mp < 2 || dist2(ro, cent) >= d2) { /* hit limit? */ |
225 |
setpart(pt, *pi, S0); |
226 |
(*pi)++; |
227 |
return(1); |
228 |
229 |
/* subdivide */ |
230 |
setpart(pt, *pi, SU); |
231 |
(*pi)++; |
232 |
newax[0] = .5*axis[0]; |
233 |
newax[1] = .5*axis[1]; |
234 |
newax[2] = .5*axis[2]; |
235 |
d2 *= 0.25; |
236 |
/* lower half */ |
237 |
newct[0] = cent[0] - newax[0]; |
238 |
newct[1] = cent[1] - newax[1]; |
239 |
newct[2] = cent[2] - newax[2]; |
240 |
npl = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2); |
241 |
/* upper half */ |
242 |
newct[0] = cent[0] + newax[0]; |
243 |
newct[1] = cent[1] + newax[1]; |
244 |
newct[2] = cent[2] + newax[2]; |
245 |
npu = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2); |
246 |
/* return total */ |
247 |
return(npl + npu); |
248 |
249 |
250 |
251 |
void |
252 |
flatpart(si, r) /* partition a flat source */ |
253 |
254 |
register RAY *r; |
255 |
256 |
register RREAL *vp; |
257 |
FVECT v; |
258 |
double du2, dv2; |
259 |
int pi; |
260 |
261 |
clrpart(si->spt); |
262 |
vp = source[si->sn].sloc; |
263 |
v[0] = r->rorg[0] - vp[0]; |
264 |
v[1] = r->rorg[1] - vp[1]; |
265 |
v[2] = r->rorg[2] - vp[2]; |
266 |
vp = source[si->sn].snorm; |
267 |
if (DOT(v,vp) <= 0.) { /* behind source */ |
268 |
si->np = 0; |
269 |
return; |
270 |
271 |
dv2 = 2.*r->rweight/srcsizerat; |
272 |
dv2 *= dv2; |
273 |
vp = source[si->sn].ss[SU]; |
274 |
du2 = dv2 * DOT(vp,vp); |
275 |
vp = source[si->sn].ss[SV]; |
276 |
dv2 *= DOT(vp,vp); |
277 |
pi = 0; |
278 |
si->np = flt_partit(r->rorg, si->spt, &pi, MAXSPART, |
279 |
source[si->sn].sloc, |
280 |
source[si->sn].ss[SU], source[si->sn].ss[SV], du2, dv2); |
281 |
282 |
283 |
284 |
static int |
285 |
flt_partit(ro, pt, pi, mp, cent, u, v, du2, dv2) /* partition flatty */ |
286 |
FVECT ro; |
287 |
288 |
register int *pi; |
289 |
int mp; |
290 |
FVECT cent, u, v; |
291 |
double du2, dv2; |
292 |
293 |
double d2; |
294 |
295 |
int npl, npu; |
296 |
297 |
if (mp < 2 || ((d2 = dist2(ro, cent)) >= du2 |
298 |
&& d2 >= dv2)) { /* hit limit? */ |
299 |
300 |
(*pi)++; |
301 |
return(1); |
302 |
303 |
if (du2 > dv2) { /* subdivide in U */ |
304 |
305 |
(*pi)++; |
306 |
newax[0] = .5*u[0]; |
307 |
newax[1] = .5*u[1]; |
308 |
newax[2] = .5*u[2]; |
309 |
u = newax; |
310 |
du2 *= 0.25; |
311 |
} else { /* subdivide in V */ |
312 |
setpart(pt, *pi, SV); |
313 |
(*pi)++; |
314 |
newax[0] = .5*v[0]; |
315 |
newax[1] = .5*v[1]; |
316 |
newax[2] = .5*v[2]; |
317 |
v = newax; |
318 |
dv2 *= 0.25; |
319 |
320 |
/* lower half */ |
321 |
322 |
323 |
324 |
npl = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2); |
325 |
/* upper half */ |
326 |
327 |
328 |
329 |
npu = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2); |
330 |
331 |
332 |
333 |
334 |
335 |
double |
336 |
scylform(sn, dir) /* compute cosine for cylinder's projection */ |
337 |
int sn; |
338 |
register FVECT dir; /* assume normalized */ |
339 |
340 |
register RREAL *dv; |
341 |
double d; |
342 |
343 |
dv = source[sn].ss[SU]; |
344 |
d = DOT(dir, dv); |
345 |
d *= d / DOT(dv,dv); |
346 |
return(sqrt(1. - d)); |
347 |
