root/radiance/ray/src/rt/srcsamp.c
Sat Jan 18 03:49:00 2025 UTC (4 months, 1 week ago) by greg
Changes since 2.24: +1 -77 lines
Diff to previous 2.24 , to selected 1.6
refactor: Removed experimental SRCSKIPOPT code
Wed Dec 25 17:40:27 2024 UTC (5 months ago) by greg
Changes since 2.23: +7 -8 lines
Diff to previous 2.23 , to selected 1.6
fix: Corrections to source skip test, mostly for SSKIPOPT option
Fri Dec 13 00:50:55 2024 UTC (5 months, 2 weeks ago) by greg
Changes since 2.22: +1 -3 lines
Diff to previous 2.22 , to selected 1.6
perf: Removed debug statement
Fri Nov 15 20:47:42 2024 UTC (6 months, 2 weeks ago) by greg
Changes since 2.21: +79 -2 lines
Diff to previous 2.21 , to selected 1.6
Sat Nov 9 15:21:32 2024 UTC (6 months, 2 weeks ago) by greg
Changes since 2.20: +10 -8 lines
Diff to previous 2.20 , to selected 1.6
perf: Improved source scatter sampling
Tue Jun 11 17:00:59 2019 UTC (5 years, 11 months ago) by greg
CVS Tags: rad5R3, rad5R4
Diff to previous 2.19 , to selected 1.6
Minor optimization should not affect behavior
Tue Jul 15 23:44:53 2014 UTC (10 years, 10 months ago) by greg
Diff to previous 2.18 , to selected 1.6
Fixed potential type conflict
Wed Dec 28 18:39:36 2011 UTC (13 years, 5 months ago) by greg
Changes since 2.17: +118 -92 lines
Diff to previous 2.17 , to selected 1.6
Added pre-emptive check for distant glow sources
Sat Oct 23 18:13:54 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.16: +8 -10 lines
Diff to previous 2.16 , to selected 1.6
Made a few obvious optimizations
Sat Jun 6 02:11:44 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.15: +16 -14 lines
Diff to previous 2.15 , to selected 1.6
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Wed Dec 10 17:33:23 2008 UTC (16 years, 5 months ago) by greg
Changes since 2.14: +7 -4 lines
Diff to previous 2.14 , to selected 1.6
Added test for divide-by-zero
Wed Dec 10 07:07:07 2008 UTC (16 years, 5 months ago) by greg
Changes since 2.13: +1 -2 lines
Diff to previous 2.13 , to selected 1.6
Removed redundant variable definition
Sun Dec 7 19:25:23 2008 UTC (16 years, 5 months ago) by greg
Diff to previous 2.12 , to selected 1.6
Made new sampling code conditional for speed in -dj 0 case
Sat Dec 6 01:08:53 2008 UTC (16 years, 5 months ago) by greg
Changes since 2.11: +26 -2 lines
Diff to previous 2.11 , to selected 1.6
Sat Sep 13 17:31:35 2003 UTC (21 years, 8 months ago) by greg
Diff to previous 2.10 , to selected 1.6
Minor fix in source sampling calculation
Mon Jul 21 22:30:19 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.9: +3 -2 lines
Diff to previous 2.9 , to selected 1.6
Thu Jun 26 00:58:10 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.8 , to selected 1.6
Tue Feb 25 02:47:23 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 1.6
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.6: +64 -4 lines
Diff to previous 2.6 , to selected 1.6
Wed Jul 20 12:48:44 1994 UTC (30 years, 10 months ago) by greg
Changes since 2.5: +7 -6 lines
Diff to previous 2.5 , to selected 1.6
fixed bug for very small local sources
Mon Mar 8 12:37:39 1993 UTC (32 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.6
Tue Sep 22 11:28:48 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.3: +4 -4 lines
Diff to previous 2.3 , to selected 1.6
bug fix for 16-bit integer architectures
Tue Jul 21 12:47:12 1992 UTC (32 years, 10 months ago) by greg
Diff to previous 2.2 , to selected 1.6
increased epsilon for behind source test
Mon Nov 25 09:52:49 1991 UTC (33 years, 6 months ago) by greg
Changes since 2.1: +4 -2 lines
Diff to previous 2.1 , to selected 1.6
fixed small bug yielding inappropriate samples for flat sources
Tue Nov 12 17:10:39 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.7 , to selected 1.6
Mon Oct 28 08:07:44 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.6
fixed bug where nextssamp() included SSKIP sources
Revision 1.6 - (view) (download) (annotate) - [selected]
Wed Oct 23 13:43:52 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.5
Wed Oct 23 08:50:06 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.4: +16 -10 lines
Diff to previous 1.4 , to selected 1.6
added test for behind surface to flatpart()
Tue Oct 22 15:45:21 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.3: +29 -33 lines
Diff to previous 1.3 , to selected 1.6
Tue Oct 22 11:23:55 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 1.6
bug fixes in source sampling routines
Mon Oct 21 14:27:36 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1 , to selected 1.6
changed maximum sampling and strategy
Mon Oct 21 12:57:13 1991 UTC (33 years, 7 months ago) by greg
Diff to selected 1.6
