--- ray/src/rt/srcsamp.c 2003/02/25 02:47:23 2.8 +++ ray/src/rt/srcsamp.c 2008/12/10 07:07:07 2.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: srcsamp.c,v 2.8 2003/02/25 02:47:23 greg Exp $"; +static const char RCSid[] = "$Id: srcsamp.c,v 2.14 2008/12/10 07:07:07 greg Exp $"; #endif /* * Source sampling routines @@ -57,7 +57,7 @@ nextsample: d = urand(ilhash(dimlist,ndims+2)+samplendx); if (source[si->sn].sflags & SFLAT) { multisamp(vpos, 2, d); - vpos[2] = 0.5; + vpos[SW] = 0.5; } else multisamp(vpos, 3, d); for (i = 0; i < 3; i++) @@ -68,6 +68,29 @@ nextsample: for (i = 0; i < 3; i++) vpos[i] += (double)cent[i]/MAXSPART; + /* avoid circular aiming failures */ + if ((source[si->sn].sflags & SCIR) && (si->np > 1 || dstrsrc > 0.7)) { + FVECT trim; + if (source[si->sn].sflags & (SFLAT|SDISTANT)) { + d = 1.12837917; /* correct setflatss() */ + trim[SU] = d*sqrt(1.0 - 0.5*vpos[SV]*vpos[SV]); + trim[SV] = d*sqrt(1.0 - 0.5*vpos[SU]*vpos[SU]); + trim[SW] = 0.0; + } else { + trim[SW] = trim[SU] = vpos[SU]*vpos[SU]; + d = vpos[SV]*vpos[SV]; + if (d > trim[SW]) trim[SW] = d; + trim[SU] += d; + d = vpos[SW]*vpos[SW]; + if (d > trim[SW]) trim[SW] = d; + trim[SU] += d; + d = 1.0/0.7236; /* correct sphsetsrc() */ + trim[SW] = trim[SV] = trim[SU] = + d*sqrt(trim[SW]/trim[SU]); + } + for (i = 0; i < 3; i++) + vpos[i] *= trim[i]; + } /* compute direction */ for (i = 0; i < 3; i++) r->rdir[i] = source[si->sn].sloc[i] + @@ -114,12 +137,13 @@ unsigned char *pt; /* partition array */ /* check this partition */ p = spart(pt, pp[0]); pp[0]++; - if (p == S0) /* leaf partition */ + if (p == S0) { /* leaf partition */ if (pp[1]) { pp[1]--; return(0); /* not there yet */ } else return(1); /* we've arrived */ + } /* else check lower */ sz[p] >>= 1; ct[p] -= sz[p]; @@ -229,7 +253,7 @@ flatpart(si, r) /* partition a flat source */ register SRCINDEX *si; register RAY *r; { - register FLOAT *vp; + register RREAL *vp; FVECT v; double du2, dv2; int pi; @@ -240,7 +264,7 @@ register RAY *r; v[1] = r->rorg[1] - vp[1]; v[2] = r->rorg[2] - vp[2]; vp = source[si->sn].snorm; - if (DOT(v,vp) <= FTINY) { /* behind source */ + if (DOT(v,vp) <= 0.) { /* behind source */ si->np = 0; return; } @@ -313,7 +337,7 @@ scylform(sn, dir) /* compute cosine for cylinder's pr int sn; register FVECT dir; /* assume normalized */ { - register FLOAT *dv; + register RREAL *dv; double d; dv = source[sn].ss[SU];
