root/Development/ray/src/rt/srcsamp.c
Tue Jul 15 23:44:53 2014 UTC (11 years, 5 months ago) by greg
Diff to previous 2.18 , to selected 2.6
Fixed potential type conflict
Wed Dec 28 18:39:36 2011 UTC (14 years ago) by greg
Changes since 2.17: +118 -92 lines
Diff to previous 2.17 , to selected 2.6
Added pre-emptive check for distant glow sources
Sat Oct 23 18:13:54 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.16: +8 -10 lines
Diff to previous 2.16 , to selected 2.6
Made a few obvious optimizations
Sat Jun 6 02:11:44 2009 UTC (16 years, 7 months ago) by greg
Changes since 2.15: +16 -14 lines
Fixed erroneous "aiming failure" with certain mirrored virtual sources
Wed Dec 10 17:33:23 2008 UTC (17 years ago) by greg
Changes since 2.14: +7 -4 lines
Added test for divide-by-zero
Wed Dec 10 07:07:07 2008 UTC (17 years ago) by greg
Changes since 2.13: +1 -2 lines
Removed redundant variable definition
Sun Dec 7 19:25:23 2008 UTC (17 years ago) by greg
Made new sampling code conditional for speed in -dj 0 case
Sat Dec 6 01:08:53 2008 UTC (17 years, 1 month ago) by greg
Changes since 2.11: +26 -2 lines
Sat Sep 13 17:31:35 2003 UTC (22 years, 3 months ago) by greg
Minor fix in source sampling calculation
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.9: +3 -2 lines
Thu Jun 26 00:58:10 2003 UTC (22 years, 6 months ago) by schorsch
Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.6: +64 -4 lines
Wed Jul 20 12:48:44 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.5: +7 -6 lines
fixed bug for very small local sources
Mon Mar 8 12:37:39 1993 UTC (32 years, 10 months ago) by greg
Tue Sep 22 11:28:48 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.3: +4 -4 lines
bug fix for 16-bit integer architectures
Tue Jul 21 12:47:12 1992 UTC (33 years, 5 months ago) by greg
increased epsilon for behind source test
Mon Nov 25 09:52:49 1991 UTC (34 years, 1 month ago) by greg
Changes since 2.1: +4 -2 lines
fixed small bug yielding inappropriate samples for flat sources
Tue Nov 12 17:10:39 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.7 , to selected 2.6
Mon Oct 28 08:07:44 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.6 , to selected 2.6
fixed bug where nextssamp() included SSKIP sources
Wed Oct 23 13:43:52 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 2.6
Wed Oct 23 08:50:06 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.4: +16 -10 lines
Diff to previous 1.4 , to selected 2.6
added test for behind surface to flatpart()
Tue Oct 22 15:45:21 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +29 -33 lines
Diff to previous 1.3 , to selected 2.6
Tue Oct 22 11:23:55 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 2.6
bug fixes in source sampling routines
Mon Oct 21 14:27:36 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1 , to selected 2.6
changed maximum sampling and strategy
Mon Oct 21 12:57:13 1991 UTC (34 years, 2 months ago) by greg
Diff to selected 2.6
