--- ray/src/rt/srcsamp.c 1994/07/20 12:48:44 2.6 +++ ray/src/rt/srcsamp.c 2010/10/23 18:13:54 2.17 @@ -1,13 +1,14 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: srcsamp.c,v 2.17 2010/10/23 18:13:54 greg Exp $"; #endif - /* * Source sampling routines + * + * External symbols declared in source.h */ +#include "copyright.h" + #include "ray.h" #include "source.h" @@ -24,6 +25,7 @@ register RAY *r; /* origin is read, direction is set register SRCINDEX *si; /* source index (modified to current) */ { int cent[3], size[3], parr[2]; + SRCREC *srcp; FVECT vpos; double d; register int i; @@ -50,59 +52,85 @@ nextsample: if (!skipparts(cent, size, parr, si->spt)) error(CONSISTENCY, "bad source partition in nextssamp"); /* compute sample */ + srcp = source + si->sn; if (dstrsrc > FTINY) { /* jitter sample */ dimlist[ndims] = si->sn + 8831; dimlist[ndims+1] = si->sp + 3109; d = urand(ilhash(dimlist,ndims+2)+samplendx); - if (source[si->sn].sflags & SFLAT) { + if (srcp->sflags & SFLAT) { multisamp(vpos, 2, d); - vpos[2] = 0.5; + vpos[SW] = 0.5; } else multisamp(vpos, 3, d); for (i = 0; i < 3; i++) vpos[i] = dstrsrc * (1. - 2.*vpos[i]) * - (double)size[i]/MAXSPART; + (double)size[i]*(1.0/MAXSPART); } else vpos[0] = vpos[1] = vpos[2] = 0.0; - for (i = 0; i < 3; i++) - vpos[i] += (double)cent[i]/MAXSPART; + VSUM(vpos, vpos, cent, 1.0/MAXSPART); + /* avoid circular aiming failures */ + if ((srcp->sflags & SCIR) && (si->np > 1 || dstrsrc > 0.7)) { + FVECT trim; + if (srcp->sflags & (SFLAT|SDISTANT)) { + d = 1.12837917; /* correct setflatss() */ + trim[SU] = d*sqrt(1.0 - 0.5*vpos[SV]*vpos[SV]); + trim[SV] = d*sqrt(1.0 - 0.5*vpos[SU]*vpos[SU]); + trim[SW] = 0.0; + } else { + trim[SW] = trim[SU] = vpos[SU]*vpos[SU]; + d = vpos[SV]*vpos[SV]; + if (d > trim[SW]) trim[SW] = d; + trim[SU] += d; + d = vpos[SW]*vpos[SW]; + if (d > trim[SW]) trim[SW] = d; + trim[SU] += d; + if (trim[SU] > FTINY*FTINY) { + d = 1.0/0.7236; /* correct sphsetsrc() */ + trim[SW] = trim[SV] = trim[SU] = + d*sqrt(trim[SW]/trim[SU]); + } else + trim[SW] = trim[SV] = trim[SU] = 0.0; + } + for (i = 0; i < 3; i++) + vpos[i] *= trim[i]; + } /* compute direction */ for (i = 0; i < 3; i++) - r->rdir[i] = source[si->sn].sloc[i] + - vpos[SU]*source[si->sn].ss[SU][i] + - vpos[SV]*source[si->sn].ss[SV][i] + - vpos[SW]*source[si->sn].ss[SW][i]; + r->rdir[i] = srcp->sloc[i] + + vpos[SU]*srcp->ss[SU][i] + + vpos[SV]*srcp->ss[SV][i] + + vpos[SW]*srcp->ss[SW][i]; - if (!(source[si->sn].sflags & SDISTANT)) - for (i = 0; i < 3; i++) - r->rdir[i] -= r->rorg[i]; + if (!(srcp->sflags & SDISTANT)) + VSUB(r->rdir, r->rdir, r->rorg); /* compute distance */ if ((d = normalize(r->rdir)) == 0.0) goto nextsample; /* at source! */ /* compute sample size */ - if (source[si->sn].sflags & SFLAT) { + if (srcp->sflags & SFLAT) { si->dom = sflatform(si->sn, r->rdir); - si->dom *= size[SU]*size[SV]/(MAXSPART*(double)MAXSPART); - } else if (source[si->sn].sflags & SCYL) { + si->dom *= size[SU]*size[SV]*(1.0/MAXSPART/MAXSPART); + } else if (srcp->sflags & SCYL) { si->dom = scylform(si->sn, r->rdir); - si->dom *= size[SU]/(double)MAXSPART; + si->dom *= size[SU]*(1.0/MAXSPART); } else { - si->dom = size[SU]*size[SV]*(double)size[SW] / - (MAXSPART*MAXSPART*(double)MAXSPART) ; + si->dom = size[SU]*size[SV]*(double)size[SW] * + (1.0/MAXSPART/MAXSPART/MAXSPART) ; } - if (source[si->sn].sflags & SDISTANT) { - si->dom *= source[si->sn].ss2; + if (srcp->sflags & SDISTANT) { + si->dom *= srcp->ss2; return(FHUGE); } if (si->dom <= 1e-4) goto nextsample; /* behind source? */ - si->dom *= source[si->sn].ss2/(d*d); + si->dom *= srcp->ss2/(d*d); return(d); /* sample OK, return distance */ } +int skipparts(ct, sz, pp, pt) /* skip to requested partition */ int ct[3], sz[3]; /* center and size of partition (returned) */ register int pp[2]; /* current index, number to skip (modified) */ @@ -112,12 +140,13 @@ unsigned char *pt; /* partition array */ /* check this partition */ p = spart(pt, pp[0]); pp[0]++; - if (p == S0) /* leaf partition */ + if (p == S0) { /* leaf partition */ if (pp[1]) { pp[1]--; return(0); /* not there yet */ } else return(1); /* we've arrived */ + } /* else check lower */ sz[p] >>= 1; ct[p] -= sz[p]; @@ -134,6 +163,7 @@ unsigned char *pt; /* partition array */ } +void nopart(si, r) /* single source partition */ register SRCINDEX *si; RAY *r; @@ -144,6 +174,7 @@ RAY *r; } +void cylpart(si, r) /* partition a cylinder */ SRCINDEX *si; register RAY *r; @@ -220,11 +251,12 @@ double d2; } +void flatpart(si, r) /* partition a flat source */ register SRCINDEX *si; register RAY *r; { - register FLOAT *vp; + register RREAL *vp; FVECT v; double du2, dv2; int pi; @@ -235,7 +267,7 @@ register RAY *r; v[1] = r->rorg[1] - vp[1]; v[2] = r->rorg[2] - vp[2]; vp = source[si->sn].snorm; - if (DOT(v,vp) <= FTINY) { /* behind source */ + if (DOT(v,vp) <= 0.) { /* behind source */ si->np = 0; return; } @@ -308,7 +340,7 @@ scylform(sn, dir) /* compute cosine for cylinder's pr int sn; register FVECT dir; /* assume normalized */ { - register FLOAT *dv; + register RREAL *dv; double d; dv = source[sn].ss[SU];
