root/Development/ray/src/rt/srcsamp.c
Sat Sep 13 17:31:35 2003 UTC (22 years, 3 months ago) by greg
Minor fix in source sampling calculation
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.9: +3 -2 lines
Thu Jun 26 00:58:10 2003 UTC (22 years, 5 months ago) by schorsch
Tue Feb 25 02:47:23 2003 UTC (22 years, 9 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.6: +64 -4 lines
Wed Jul 20 12:48:44 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.5: +7 -6 lines
fixed bug for very small local sources
Mon Mar 8 12:37:39 1993 UTC (32 years, 9 months ago) by greg
Tue Sep 22 11:28:48 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.3: +4 -4 lines
bug fix for 16-bit integer architectures
Tue Jul 21 12:47:12 1992 UTC (33 years, 5 months ago) by greg
increased epsilon for behind source test
Mon Nov 25 09:52:49 1991 UTC (34 years, 1 month ago) by greg
Changes since 2.1: +4 -2 lines
fixed small bug yielding inappropriate samples for flat sources
Tue Nov 12 17:10:39 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.7 , to selected 2.4
Mon Oct 28 08:07:44 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.6 , to selected 2.4
fixed bug where nextssamp() included SSKIP sources
Wed Oct 23 13:43:52 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 2.4
Wed Oct 23 08:50:06 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.4: +16 -10 lines
Diff to previous 1.4 , to selected 2.4
added test for behind surface to flatpart()
Tue Oct 22 15:45:21 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +29 -33 lines
Diff to previous 1.3 , to selected 2.4
Tue Oct 22 11:23:55 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 2.4
bug fixes in source sampling routines
Mon Oct 21 14:27:36 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.1: +4 -4 lines
Diff to previous 1.1 , to selected 2.4
changed maximum sampling and strategy
Mon Oct 21 12:57:13 1991 UTC (34 years, 2 months ago) by greg
Diff to selected 2.4
