Minor fix in source sampling calculation
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed bug for very small local sources
bug fix for 16-bit integer architectures
increased epsilon for behind source test
fixed small bug yielding inappropriate samples for flat sources
fixed bug where nextssamp() included SSKIP sources
added test for behind surface to flatpart()
bug fixes in source sampling routines
changed maximum sampling and strategy
