--- ray/src/rt/srcsamp.c 1991/10/22 11:23:55 1.3 +++ ray/src/rt/srcsamp.c 1991/10/23 08:50:06 1.5 @@ -8,40 +8,33 @@ static char SCCSid[] = "$SunId$ LBL"; * Source sampling routines */ -#include "standard.h" +#include "ray.h" -#include "object.h" - #include "source.h" #include "random.h" -extern int dimlist[]; /* dimension list for distribution */ -extern int ndims; /* number of dimensions so far */ -extern int samplendx; /* index for this sample */ - - double -nextssamp(org, dir, si) /* compute sample for source, rtn. distance */ -FVECT org, dir; /* origin is read only, direction is set */ +nextssamp(r, si) /* compute sample for source, rtn. distance */ +register RAY *r; /* origin is read, direction is set */ register SRCINDEX *si; /* source index (modified to current) */ { int cent[3], size[3], parr[2]; FVECT vpos; double d; register int i; -tryagain: + while (++si->sp >= si->np) { /* get next sample */ if (++si->sn >= nsources) return(0.0); /* no more */ if (srcsizerat <= FTINY) - nopart(si, org); + nopart(si, r); else { for (i = si->sn; source[i].sflags & SVIRTUAL; i = source[i].sa.sv.sn) ; /* partition source */ - (*sfun[source[i].so->otype].of->partit)(si, org); + (*sfun[source[i].so->otype].of->partit)(si, r); } si->sp = -1; } @@ -71,29 +64,25 @@ tryagain: vpos[i] += (double)cent[i]/MAXSPART; /* compute direction */ for (i = 0; i < 3; i++) - dir[i] = source[si->sn].sloc[i] + + r->rdir[i] = source[si->sn].sloc[i] + vpos[SU]*source[si->sn].ss[SU][i] + vpos[SV]*source[si->sn].ss[SV][i] + vpos[SW]*source[si->sn].ss[SW][i]; if (!(source[si->sn].sflags & SDISTANT)) for (i = 0; i < 3; i++) - dir[i] -= org[i]; + r->rdir[i] -= r->rorg[i]; /* compute distance */ - if ((d = normalize(dir)) == 0.0) - goto tryagain; /* at source! */ + if ((d = normalize(r->rdir)) == 0.0) + return(nextssamp(r, si)); /* at source! */ /* compute sample size */ si->dom = source[si->sn].ss2; if (source[si->sn].sflags & SFLAT) { - si->dom *= sflatform(si->sn, dir); - if (si->dom <= FTINY) { /* behind source */ - si->np = 0; - goto tryagain; - } + si->dom *= sflatform(si->sn, r->rdir); si->dom *= (double)(size[SU]*size[SV])/(MAXSPART*MAXSPART); } else if (source[si->sn].sflags & SCYL) { - si->dom *= scylform(si->sn, dir); + si->dom *= scylform(si->sn, r->rdir); si->dom *= (double)size[SU]/MAXSPART; } else { si->dom *= (double)(size[SU]*size[SV]*size[SW]) / @@ -137,9 +126,9 @@ unsigned char *pt; /* partition array */ } -nopart(si, ro) /* single source partition */ +nopart(si, r) /* single source partition */ register SRCINDEX *si; -FVECT ro; +RAY *r; { clrpart(si->spt); setpart(si->spt, 0, S0); @@ -147,9 +136,9 @@ FVECT ro; } -cylpart(si, ro) /* partition a cylinder */ +cylpart(si, r) /* partition a cylinder */ SRCINDEX *si; -FVECT ro; +register RAY *r; { double dist2, safedist2, dist2cent, rad2; FVECT v; @@ -157,11 +146,11 @@ FVECT ro; int pi; /* first check point location */ clrpart(si->spt); - sp = &source[si->sn]; + sp = source + si->sn; rad2 = 1.365 * DOT(sp->ss[SV],sp->ss[SV]); - v[0] = ro[0] - sp->sloc[0]; - v[1] = ro[1] - sp->sloc[1]; - v[2] = ro[2] - sp->sloc[2]; + v[0] = r->rorg[0] - sp->sloc[0]; + v[1] = r->rorg[1] - sp->sloc[1]; + v[2] = r->rorg[2] - sp->sloc[2]; dist2 = DOT(v,sp->ss[SU]); safedist2 = DOT(sp->ss[SU],sp->ss[SU]); dist2 *= dist2 / safedist2; @@ -171,15 +160,15 @@ FVECT ro; si->np = 0; return; } - safedist2 *= 4./(srcsizerat*srcsizerat); - if (dist2 <= 4.*rad2 || /* point too close to subdivide? */ - dist2cent >= safedist2) { + safedist2 *= 4.*r->rweight*r->rweight/(srcsizerat*srcsizerat); + if (dist2 <= 4.*rad2 || /* point too close to subdivide */ + dist2cent >= safedist2) { /* or too far */ setpart(si->spt, 0, S0); si->np = 1; return; } pi = 0; - si->np = cyl_partit(ro, si->spt, &pi, MAXSPART, + si->np = cyl_partit(r->rorg, si->spt, &pi, MAXSPART, sp->sloc, sp->ss[SU], safedist2); } @@ -223,21 +212,34 @@ double d2; } -flatpart(si, ro) /* partition a flat source */ +flatpart(si, r) /* partition a flat source */ register SRCINDEX *si; -FVECT ro; +register RAY *r; { register double *vp; + FVECT v; double du2, dv2; int pi; + clrpart(si->spt); + vp = source[si->sn].sloc; + v[0] = r->rorg[0] - vp[0]; + v[1] = r->rorg[1] - vp[1]; + v[2] = r->rorg[2] - vp[2]; + vp = source[si->sn].snorm; + if (DOT(v,vp) <= FTINY) { /* behind source */ + si->np = 0; + return; + } + dv2 = 2.*r->rweight/srcsizerat; + dv2 *= dv2; vp = source[si->sn].ss[SU]; - du2 = 4./(srcsizerat*srcsizerat) * DOT(vp,vp); + du2 = dv2 * DOT(vp,vp); vp = source[si->sn].ss[SV]; - dv2 = 4./(srcsizerat*srcsizerat) * DOT(vp,vp); - clrpart(si->spt); + dv2 *= DOT(vp,vp); pi = 0; - si->np = flt_partit(ro, si->spt, &pi, MAXSPART, source[si->sn].sloc, + si->np = flt_partit(r->rorg, si->spt, &pi, MAXSPART, + source[si->sn].sloc, source[si->sn].ss[SU], source[si->sn].ss[SV], du2, dv2); }
