root/Development/ray/src/rt/srcsamp.c
Revision: 1.3
Committed: Tue Oct 22 11:23:55 1991 UTC (34 years ago) by greg
bug fixes in source sampling routines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Source sampling routines
9 */
10
11 #include "standard.h"
12
13 #include "object.h"
14
15 #include "source.h"
16
17 #include "random.h"
18
19
20 extern int dimlist[]; /* dimension list for distribution */
21 extern int ndims; /* number of dimensions so far */
22 extern int samplendx; /* index for this sample */
23
24
25 double
26 nextssamp(org, dir, si) /* compute sample for source, rtn. distance */
27 FVECT org, dir; /* origin is read only, direction is set */
28 register SRCINDEX *si; /* source index (modified to current) */
29 {
30 int cent[3], size[3], parr[2];
31 FVECT vpos;
32 double d;
33 register int i;
34 tryagain:
35 while (++si->sp >= si->np) { /* get next sample */
36 if (++si->sn >= nsources)
37 return(0.0); /* no more */
38 if (srcsizerat <= FTINY)
39 nopart(si, org);
40 else {
41 for (i = si->sn; source[i].sflags & SVIRTUAL;
42 i = source[i].sa.sv.sn)
43 ; /* partition source */
44 (*sfun[source[i].so->otype].of->partit)(si, org);
45 }
46 si->sp = -1;
47 }
48 /* get partition */
49 cent[0] = cent[1] = cent[2] = 0;
50 size[0] = size[1] = size[2] = MAXSPART;
51 parr[0] = 0; parr[1] = si->sp;
52 if (!skipparts(cent, size, parr, si->spt))
53 error(CONSISTENCY, "bad source partition in nextssamp");
54 /* compute sample */
55 if (dstrsrc > FTINY) { /* jitter sample */
56 dimlist[ndims] = si->sn + 8831;
57 dimlist[ndims+1] = si->sp + 3109;
58 d = urand(ilhash(dimlist,ndims+2)+samplendx);
59 if (source[si->sn].sflags & SFLAT) {
60 multisamp(vpos, 2, d);
61 vpos[2] = 0.5;
62 } else
63 multisamp(vpos, 3, d);
64 for (i = 0; i < 3; i++)
65 vpos[i] = dstrsrc * (1. - 2.*vpos[i]) *
66 (double)size[i]/MAXSPART;
67 } else
68 vpos[0] = vpos[1] = vpos[2] = 0.0;
69
70 for (i = 0; i < 3; i++)
71 vpos[i] += (double)cent[i]/MAXSPART;
72 /* compute direction */
73 for (i = 0; i < 3; i++)
74 dir[i] = source[si->sn].sloc[i] +
75 vpos[SU]*source[si->sn].ss[SU][i] +
76 vpos[SV]*source[si->sn].ss[SV][i] +
77 vpos[SW]*source[si->sn].ss[SW][i];
78
79 if (!(source[si->sn].sflags & SDISTANT))
80 for (i = 0; i < 3; i++)
81 dir[i] -= org[i];
82 /* compute distance */
83 if ((d = normalize(dir)) == 0.0)
84 goto tryagain; /* at source! */
85
86 /* compute sample size */
87 si->dom = source[si->sn].ss2;
88 if (source[si->sn].sflags & SFLAT) {
89 si->dom *= sflatform(si->sn, dir);
90 if (si->dom <= FTINY) { /* behind source */
91 si->np = 0;
92 goto tryagain;
93 }
94 si->dom *= (double)(size[SU]*size[SV])/(MAXSPART*MAXSPART);
95 } else if (source[si->sn].sflags & SCYL) {
96 si->dom *= scylform(si->sn, dir);
97 si->dom *= (double)size[SU]/MAXSPART;
98 } else {
99 si->dom *= (double)(size[SU]*size[SV]*size[SW]) /
100 (MAXSPART*MAXSPART*MAXSPART) ;
101 }
102 if (source[si->sn].sflags & SDISTANT)
103 return(FHUGE);
104 si->dom /= d*d;
105 return(d); /* sample OK, return distance */
106 }
107
108
109 skipparts(ct, sz, pp, pt) /* skip to requested partition */
110 int ct[3], sz[3]; /* center and size of partition (returned) */
111 register int pp[2]; /* current index, number to skip (modified) */
112 unsigned char *pt; /* partition array */
113 {
114 register int p;
115 /* check this partition */
116 p = spart(pt, pp[0]);
117 pp[0]++;
118 if (p == S0) /* leaf partition */
119 if (pp[1]) {
120 pp[1]--;
121 return(0); /* not there yet */
122 } else
123 return(1); /* we've arrived */
124 /* else check lower */
125 sz[p] >>= 1;
126 ct[p] -= sz[p];
127 if (skipparts(ct, sz, pp, pt))
128 return(1); /* return hit */
129 /* else check upper */
130 ct[p] += sz[p] << 1;
131 if (skipparts(ct, sz, pp, pt))
132 return(1); /* return hit */
133 /* else return to starting position */
134 ct[p] -= sz[p];
135 sz[p] <<= 1;
136 return(0); /* return miss */
137 }
138
139
140 nopart(si, ro) /* single source partition */
141 register SRCINDEX *si;
142 FVECT ro;
143 {
144 clrpart(si->spt);
145 setpart(si->spt, 0, S0);
146 si->np = 1;
147 }
148
149
150 cylpart(si, ro) /* partition a cylinder */
151 SRCINDEX *si;
152 FVECT ro;
153 {
154 double dist2, safedist2, dist2cent, rad2;
155 FVECT v;
156 register SRCREC *sp;
157 int pi;
158 /* first check point location */
159 clrpart(si->spt);
160 sp = &source[si->sn];
161 rad2 = 1.365 * DOT(sp->ss[SV],sp->ss[SV]);
162 v[0] = ro[0] - sp->sloc[0];
163 v[1] = ro[1] - sp->sloc[1];
164 v[2] = ro[2] - sp->sloc[2];
165 dist2 = DOT(v,sp->ss[SU]);
166 safedist2 = DOT(sp->ss[SU],sp->ss[SU]);
167 dist2 *= dist2 / safedist2;
168 dist2cent = DOT(v,v);
169 dist2 = dist2cent - dist2;
170 if (dist2 <= rad2) { /* point inside extended cylinder */
171 si->np = 0;
172 return;
173 }
174 safedist2 *= 4./(srcsizerat*srcsizerat);
175 if (dist2 <= 4.*rad2 || /* point too close to subdivide? */
176 dist2cent >= safedist2) {
177 setpart(si->spt, 0, S0);
178 si->np = 1;
179 return;
180 }
181 pi = 0;
182 si->np = cyl_partit(ro, si->spt, &pi, MAXSPART,
183 sp->sloc, sp->ss[SU], safedist2);
184 }
185
186
187 static int
188 cyl_partit(ro, pt, pi, mp, cent, axis, d2) /* slice a cylinder */
189 FVECT ro;
190 unsigned char *pt;
191 register int *pi;
192 int mp;
193 FVECT cent, axis;
194 double d2;
195 {
196 FVECT newct, newax;
197 int npl, npu;
198
199 if (mp < 2 || dist2(ro, cent) >= d2) { /* hit limit? */
200 setpart(pt, *pi, S0);
201 (*pi)++;
202 return(1);
203 }
204 /* subdivide */
205 setpart(pt, *pi, SU);
206 (*pi)++;
207 newax[0] = .5*axis[0];
208 newax[1] = .5*axis[1];
209 newax[2] = .5*axis[2];
210 d2 *= 0.25;
211 /* lower half */
212 newct[0] = cent[0] - newax[0];
213 newct[1] = cent[1] - newax[1];
214 newct[2] = cent[2] - newax[2];
215 npl = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2);
216 /* upper half */
217 newct[0] = cent[0] + newax[0];
218 newct[1] = cent[1] + newax[1];
219 newct[2] = cent[2] + newax[2];
220 npu = cyl_partit(ro, pt, pi, mp/2, newct, newax, d2);
221 /* return total */
222 return(npl + npu);
223 }
224
225
226 flatpart(si, ro) /* partition a flat source */
227 register SRCINDEX *si;
228 FVECT ro;
229 {
230 register double *vp;
231 double du2, dv2;
232 int pi;
233
234 vp = source[si->sn].ss[SU];
235 du2 = 4./(srcsizerat*srcsizerat) * DOT(vp,vp);
236 vp = source[si->sn].ss[SV];
237 dv2 = 4./(srcsizerat*srcsizerat) * DOT(vp,vp);
238 clrpart(si->spt);
239 pi = 0;
240 si->np = flt_partit(ro, si->spt, &pi, MAXSPART, source[si->sn].sloc,
241 source[si->sn].ss[SU], source[si->sn].ss[SV], du2, dv2);
242 }
243
244
245 static int
246 flt_partit(ro, pt, pi, mp, cent, u, v, du2, dv2) /* partition flatty */
247 FVECT ro;
248 unsigned char *pt;
249 register int *pi;
250 int mp;
251 FVECT cent, u, v;
252 double du2, dv2;
253 {
254 double d2;
255 FVECT newct, newax;
256 int npl, npu;
257
258 if (mp < 2 || ((d2 = dist2(ro, cent)) >= du2
259 && d2 >= dv2)) { /* hit limit? */
260 setpart(pt, *pi, S0);
261 (*pi)++;
262 return(1);
263 }
264 if (du2 > dv2) { /* subdivide in U */
265 setpart(pt, *pi, SU);
266 (*pi)++;
267 newax[0] = .5*u[0];
268 newax[1] = .5*u[1];
269 newax[2] = .5*u[2];
270 u = newax;
271 du2 *= 0.25;
272 } else { /* subdivide in V */
273 setpart(pt, *pi, SV);
274 (*pi)++;
275 newax[0] = .5*v[0];
276 newax[1] = .5*v[1];
277 newax[2] = .5*v[2];
278 v = newax;
279 dv2 *= 0.25;
280 }
281 /* lower half */
282 newct[0] = cent[0] - newax[0];
283 newct[1] = cent[1] - newax[1];
284 newct[2] = cent[2] - newax[2];
285 npl = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2);
286 /* upper half */
287 newct[0] = cent[0] + newax[0];
288 newct[1] = cent[1] + newax[1];
289 newct[2] = cent[2] + newax[2];
290 npu = flt_partit(ro, pt, pi, mp/2, newct, u, v, du2, dv2);
291 /* return total */
292 return(npl + npu);
293 }
294
295
296 double
297 scylform(sn, dir) /* compute cosine for cylinder's projection */
298 int sn;
299 register FVECT dir; /* assume normalized */
300 {
301 register double *dv;
302 double d;
303
304 dv = source[sn].ss[SU];
305 d = DOT(dir, dv);
306 d *= d / DOT(dv,dv);
307 return(sqrt(1. - d));
308 }
