--- ray/src/rt/srcobstr.c 2004/09/08 01:48:50 2.6 +++ ray/src/rt/srcobstr.c 2004/09/10 16:05:07 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: srcobstr.c,v 2.6 2004/09/08 01:48:50 greg Exp $"; +static const char RCSid[] = "$Id: srcobstr.c,v 2.9 2004/09/10 16:05:07 greg Exp $"; #endif /* * Source occlusion caching routines @@ -19,7 +19,7 @@ static const char RCSid[] = "$Id: srcobstr.c,v 2.6 200 #if SHADCACHE /* preemptive shadow checking */ -static void /* cast source ray to first blocker */ +static int /* cast source ray to first blocker */ castshadow(int sn, FVECT rorg, FVECT rdir) { RAY rt; @@ -28,23 +28,29 @@ castshadow(int sn, FVECT rorg, FVECT rdir) VCOPY(rt.rdir, rdir); rt.rmax = 0; rayorigin(&rt, NULL, PRIMARY, 1.0); - if (!localhit(&rt, &thescene)) - return; - /* pretend we were aimed at source */ - rt.crtype |= rt.rtype = SHADOW; - rt.rdir[0] = -rt.rdir[0]; - rt.rdir[1] = -rt.rdir[1]; - rt.rdir[2] = -rt.rdir[2]; - rt.rod = -rt.rod; - VSUB(rt.rorg, rt.rop, rt.rdir); - rt.rot = 1.; - rt.rsrc = sn; + /* check for intersection */ + while (localhit(&rt, &thescene)) { + RAY rt1 = rt; /* pretend we were aimed at source */ + rt1.crtype |= rt1.rtype = SHADOW; + rt1.rdir[0] = -rt.rdir[0]; + rt1.rdir[1] = -rt.rdir[1]; + rt1.rdir[2] = -rt.rdir[2]; + rt1.rod = -rt.rod; + VSUB(rt1.rorg, rt.rop, rt.rdir); + rt1.rot = 1.; + rt1.rsrc = sn; /* record blocker */ - srcblocker(&rt); + if (srcblocker(&rt1)) + return(1); + /* move past failed blocker */ + VSUM(rt.rorg, rt.rop, rt.rdir, FTINY); + rayclear(&rt); /* & try again... */ + } + return(0); /* found no blockers */ } -static void /* initialize occlusion cache */ +void /* initialize occlusion cache */ initobscache(int sn) { register SRCREC *srcp = &source[sn]; @@ -54,6 +60,8 @@ initobscache(int sn) int i, j, k; int ax, ax1, ax2; + if (srcp->sflags & (SSKIP|SPROX|SSPOT|SVIRTUAL)) + return; /* don't cache these */ if (srcp->sflags & SDISTANT) cachelen = 4*SHADCACHE*SHADCACHE; else if (srcp->sflags & SFLAT) @@ -61,8 +69,6 @@ initobscache(int sn) else /* spherical distribution */ cachelen = SHADCACHE*SHADCACHE*6; /* allocate cache */ - DCHECK(srcp->obscache != NULL, - CONSISTENCY, "initobscache() called twice"); srcp->obscache = (OBSCACHE *)malloc(sizeof(OBSCACHE) + sizeof(OBJECT)*(cachelen-1)); if (srcp->obscache == NULL) @@ -276,20 +282,21 @@ freeobscache(SRCREC *srcp) } -void /* record a source blocker */ +int /* record a source blocker */ srcblocker(register RAY *r) { OBJREC *m; if (r->robj == OVOID || objptr(r->robj) != r->ro || isvolume(r->ro->otype)) - return; /* don't record complex blockers */ + return(0); /* don't record complex blockers */ m = findmaterial(r->ro); if (m == NULL) - return; /* no material?! */ + return(0); /* no material?! */ if (!isopaque(m->otype)) - return; /* material not a reliable blocker */ + return(0); /* material not a reliable blocker */ *srcobstructp(r) = r->robj; /* else record obstructor */ + return(1); } @@ -302,7 +309,14 @@ srcblocked(RAY *r) if (obs == OVOID) return(0); op = objptr(obs); /* check for intersection */ - return((*ofun[op->otype].funp)(op, r)); + if (!(*ofun[op->otype].funp)(op, r)) + return(0); + op = source[r->rsrc].so; /* check source really obstructed */ + if ((*ofun[op->otype].funp)(op, r)) { + rayclear(r); /* actually, source in front! */ + return(0); + } + return(1); /* source truly blocked */ }
