root/radiance/ray/src/rt/srcobstr.c
Fri Apr 5 01:10:26 2024 UTC (6 weeks, 3 days ago) by greg
Diff to previous 2.19 , to selected 2.17
fix: Improved tracking of reflected vs. transmitted rays for antimatter
Wed Feb 22 03:16:20 2017 UTC (7 years, 2 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 2.18: +10 -3 lines
Diff to previous 2.18 , to selected 2.17
Added MAX2SHADE macro to limit precheck time for source obstructions.
Thu May 28 09:13:19 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.17: +9 -9 lines
Diff to previous 2.17
Fixed bug in source obstructor cache for antimatter
Revision 2.17 - (view) (download) (annotate) - [selected]
Wed Aug 7 05:10:09 2013 UTC (10 years, 9 months ago) by greg
Diff to previous 2.16
Mon Feb 14 20:13:38 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.15: +7 -1 lines
Diff to previous 2.15 , to selected 2.17
Added clearing of clipped object (antimatter) when sources freed
Sat Dec 12 00:03:42 2009 UTC (14 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.17
Mon Oct 8 18:07:57 2007 UTC (16 years, 7 months ago) by greg
Diff to previous 2.13 , to selected 2.17
Wed Jul 25 04:12:36 2007 UTC (16 years, 10 months ago) by greg
Changes since 2.12: +39 -1 lines
Diff to previous 2.12 , to selected 2.17
Tue Apr 19 01:15:07 2005 UTC (19 years, 1 month ago) by greg
Diff to previous 2.11 , to selected 2.17
Mon Oct 25 17:07:35 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.10 , to selected 2.17
Fixed Mark Stock's abort error caused by source & mist combination
Fri Sep 10 17:08:36 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.9: +9 -8 lines
Diff to previous 2.9 , to selected 2.17
Fixed bug in last fix -- distant sources weren't working
Fri Sep 10 16:05:07 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.8: +9 -2 lines
Diff to previous 2.8 , to selected 2.17
Wed Sep 8 17:10:16 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.7 , to selected 2.17
Wed Sep 8 06:07:52 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.6: +25 -18 lines
Diff to previous 2.6 , to selected 2.17
Made source obstructor cache initialization more robust
Wed Sep 8 01:48:50 2004 UTC (19 years, 8 months ago) by greg
Changes since 2.5: +12 -6 lines
Diff to previous 2.5 , to selected 2.17
Added local caching of obstruction index
Tue Jun 22 13:40:54 2004 UTC (19 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 2.17
Added isopaque() macro to otspecial.h
Diff to previous 2.3 , to selected 2.17
Fri Jan 9 05:37:12 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.2: +9 -4 lines
Diff to previous 2.2 , to selected 2.17
Bug fix in source substructuring test and added debug bounds checking
Diff to previous 2.1 , to selected 2.17
Wed Dec 31 19:38:27 2003 UTC (20 years, 4 months ago) by greg
Diff to selected 2.17
