root/radiance/ray/src/rt/srcdraw.c
Revision: 2.3
Committed: Sat Jun 8 21:16:04 1996 UTC (29 years ago) by greg
Changes since 2.2: +102 -43 lines
made bitty source drawing more efficient
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Draw small sources into image in case we missed them.
9 */
10
11 #include "ray.h"
12
13 #include "view.h"
14
15 #include "source.h"
16
17
18 #define CLIP_ABOVE 1
19 #define CLIP_BELOW 2
20 #define CLIP_RIGHT 3
21 #define CLIP_LEFT 4
22
23 #define MAXVERT 10
24
25 typedef struct splist {
26 struct splist *next; /* next source in list */
27 int sn; /* source number */
28 short nv; /* number of vertices */
29 FLOAT vl[3][2]; /* vertex array (last) */
30 } SPLIST; /* source polygon list */
31
32 extern VIEW ourview; /* our view parameters */
33 extern int hres, vres; /* our image resolution */
34 static SPLIST *sphead = NULL; /* our list of source polys */
35
36
37 static int
38 inregion(p, cv, crit) /* check if vertex is in region */
39 FLOAT p[2];
40 double cv;
41 int crit;
42 {
43 switch (crit) {
44 case CLIP_ABOVE:
45 return(p[1] < cv);
46 case CLIP_BELOW:
47 return(p[1] >= cv);
48 case CLIP_RIGHT:
49 return(p[0] < cv);
50 case CLIP_LEFT:
51 return(p[0] >= cv);
52 }
53 return(-1);
54 }
55
56
57 static
58 clipregion(a, b, cv, crit, r) /* find intersection with boundary */
59 register FLOAT a[2], b[2];
60 double cv;
61 int crit;
62 FLOAT r[2]; /* return value */
63 {
64 switch (crit) {
65 case CLIP_ABOVE:
66 case CLIP_BELOW:
67 r[1] = cv;
68 r[0] = a[0] + (cv-a[1])/(b[1]-a[1])*(b[0]-a[0]);
69 return;
70 case CLIP_RIGHT:
71 case CLIP_LEFT:
72 r[0] = cv;
73 r[1] = a[1] + (cv-a[0])/(b[0]-a[0])*(b[1]-a[1]);
74 return;
75 }
76 }
77
78
79 static int
80 hp_clip_poly(vl, nv, cv, crit, vlo) /* clip polygon to half-plane */
81 FLOAT vl[][2];
82 int nv;
83 double cv;
84 int crit;
85 FLOAT vlo[][2]; /* return value */
86 {
87 FLOAT *s, *p;
88 register int j, nvo;
89
90 s = vl[nv-1];
91 nvo = 0;
92 for (j = 0; j < nv; j++) {
93 p = vl[j];
94 if (inregion(p, cv, crit)) {
95 if (!inregion(s, cv, crit))
96 clipregion(s, p, cv, crit, vlo[nvo++]);
97 vlo[nvo][0] = p[0]; vlo[nvo++][1] = p[1];
98 } else if (inregion(s, cv, crit))
99 clipregion(s, p, cv, crit, vlo[nvo++]);
100 s = p;
101 }
102 return(nvo);
103 }
104
105
106 static int
107 box_clip_poly(vl, nv, xl, xr, yb, ya, vlo) /* clip polygon to box */
108 FLOAT vl[MAXVERT][2];
109 int nv;
110 double xl, xr, yb, ya;
111 FLOAT vlo[MAXVERT][2]; /* return value */
112 {
113 FLOAT vlt[MAXVERT][2];
114 int nvt, nvo;
115
116 nvt = hp_clip_poly(vl, nv, yb, CLIP_BELOW, vlt);
117 nvo = hp_clip_poly(vlt, nvt, ya, CLIP_ABOVE, vlo);
118 nvt = hp_clip_poly(vlo, nvo, xl, CLIP_LEFT, vlt);
119 nvo = hp_clip_poly(vlt, nvt, xr, CLIP_RIGHT, vlo);
120
121 return(nvo);
122 }
123
124
125 static double
126 minw2(vl, nv, ar2) /* compute square of minimum width */
127 FLOAT vl[][2];
128 int nv;
129 double ar2;
130 {
131 double d2, w2, w2min, w2max;
132 register FLOAT *p0, *p1, *p2;
133 int i, j;
134 /* find minimum for all widths */
135 w2min = FHUGE;
136 p0 = vl[nv-1];
137 for (i = 0; i < nv; i++) { /* for each edge */
138 p1 = vl[i];
139 d2 = (p1[0]-p0[0])*(p1[0]-p0[0]) +
140 (p1[1]-p0[1])*(p1[1]-p0[1])*ar2;
141 w2max = 0.; /* find maximum for this side */
142 for (j = 1; j < nv-1; j++) {
143 p2 = vl[(i+j)%nv];
144 w2 = (p1[0]-p0[0])*(p2[1]-p0[1]) -
145 (p1[1]-p0[1])*(p2[0]-p0[0]);
146 w2 = w2*w2*ar2/d2; /* triangle height squared */
147 if (w2 > w2max)
148 w2max = w2;
149 }
150 if (w2max < w2min) /* global min. based on local max.'s */
151 w2min = w2max;
152 p0 = p1;
153 }
154 return(w2min);
155 }
156
157
158 static
159 convex_center(vl, nv, cv) /* compute center of convex polygon */
160 register FLOAT vl[][2];
161 int nv;
162 FLOAT cv[2]; /* return value */
163 {
164 register int i;
165 /* simple average (suboptimal) */
166 cv[0] = cv[1] = 0.;
167 for (i = 0; i < nv; i++) {
168 cv[0] += vl[i][0];
169 cv[1] += vl[i][1];
170 }
171 cv[0] /= (double)nv;
172 cv[1] /= (double)nv;
173 }
174
175
176 static double
177 poly_area(vl, nv) /* compute area of polygon */
178 register FLOAT vl[][2];
179 int nv;
180 {
181 double a;
182 FLOAT v0[2], v1[2];
183 register int i;
184
185 a = 0.;
186 v0[0] = vl[1][0] - vl[0][0];
187 v0[1] = vl[1][1] - vl[0][1];
188 for (i = 2; i < nv; i++) {
189 v1[0] = vl[i][0] - vl[0][0];
190 v1[1] = vl[i][1] - vl[0][1];
191 a += v0[0]*v1[1] - v0[1]*v1[0];
192 v0[0] = v1[0]; v0[1] = v1[1];
193 }
194 return(a * (a >= 0. ? .5 : -.5));
195 }
196
197
198 static int
199 convex_hull(vl, nv, vlo) /* compute polygon's convex hull */
200 FLOAT vl[][2];
201 int nv;
202 FLOAT vlo[][2]; /* return value */
203 {
204 int nvo, nvt;
205 FLOAT vlt[MAXVERT][2];
206 double voa, vta;
207 register int i, j;
208 /* start with original polygon */
209 for (i = nvo = nv; i--; ) {
210 vlo[i][0] = vl[i][0]; vlo[i][1] = vl[i][1];
211 }
212 voa = poly_area(vlo, nvo); /* compute its area */
213 for (i = 0; i < nvo; i++) { /* for each output vertex */
214 for (j = 0; j < i; j++) {
215 vlt[j][0] = vlo[j][0]; vlt[j][1] = vlo[j][1];
216 }
217 nvt = nvo - 1; /* make poly w/o vertex */
218 for (j = i; j < nvt; j++) {
219 vlt[j][0] = vlo[j+1][0]; vlt[j][1] = vlo[j+1][1];
220 }
221 vta = poly_area(vlt, nvt);
222 if (vta >= voa) { /* is simpler poly bigger? */
223 voa = vta; /* then use it */
224 for (j = nvo = nvt; j--; ) {
225 vlo[j][0] = vlt[j][0]; vlo[j][1] = vlt[j][1];
226 }
227 i--; /* next adjust */
228 }
229 }
230 return(nvo);
231 }
232
233
234 static
235 spinsert(sn, vl, nv) /* insert new source polygon */
236 int sn;
237 FLOAT vl[][2];
238 int nv;
239 {
240 register SPLIST *spn;
241 register int i;
242
243 if (nv < 3)
244 return;
245 if (nv > 3)
246 spn = (SPLIST *)malloc(sizeof(SPLIST)+sizeof(FLOAT)*2*(nv-3));
247 else
248 spn = (SPLIST *)malloc(sizeof(SPLIST));
249 if (spn == NULL)
250 error(SYSTEM, "out of memory in spinsert");
251 spn->sn = sn;
252 for (i = spn->nv = nv; i--; ) {
253 spn->vl[i][0] = vl[i][0]; spn->vl[i][1] = vl[i][1];
254 }
255 spn->next = sphead; /* push onto global list */
256 sphead = spn;
257 }
258
259
260 int
261 sourcepoly(sn, sp) /* compute image polygon for source */
262 int sn;
263 FLOAT sp[MAXVERT][2];
264 {
265 static char cubeord[8][6] = {{1,3,2,6,4,5},{0,4,5,7,3,2},
266 {0,1,3,7,6,4},{0,1,5,7,6,2},
267 {0,2,6,7,5,1},{0,4,6,7,3,1},
268 {0,2,3,7,5,4},{1,5,4,6,2,3}};
269 register SRCREC *s = source + sn;
270 FVECT ap, ip;
271 FLOAT pt[6][2];
272 int dir;
273 register int i, j;
274
275 if (s->sflags & (SDISTANT|SFLAT)) {
276 if (s->sflags & SDISTANT && ourview.type == VT_PAR)
277 return(0); /* all or nothing case */
278 if (s->sflags & SFLAT) {
279 for (i = 0; i < 3; i++)
280 ap[i] = s->sloc[i] - ourview.vp[i];
281 if (DOT(ap, s->snorm) >= 0.)
282 return(0); /* source faces away */
283 }
284 for (j = 0; j < 4; j++) { /* four corners */
285 for (i = 0; i < 3; i++) {
286 ap[i] = s->sloc[i];
287 if (j==1|j==2) ap[i] += s->ss[SU][i];
288 else ap[i] -= s->ss[SU][i];
289 if (j==2|j==3) ap[i] += s->ss[SV][i];
290 else ap[i] -= s->ss[SV][i];
291 if (s->sflags & SDISTANT) {
292 ap[i] *= 1. + ourview.vfore;
293 ap[i] += ourview.vp[i];
294 }
295 }
296 viewloc(ip, &ourview, ap); /* find image point */
297 if (ip[2] <= 0.)
298 return(0); /* in front of view */
299 sp[j][0] = ip[0]; sp[j][1] = ip[1];
300 }
301 return(4);
302 }
303 /* identify furthest corner */
304 for (i = 0; i < 3; i++)
305 ap[i] = s->sloc[i] - ourview.vp[i];
306 dir = (DOT(ap,s->ss[SU])>0.) |
307 (DOT(ap,s->ss[SV])>0.)<<1 |
308 (DOT(ap,s->ss[SW])>0.)<<2 ;
309 /* order vertices based on this */
310 for (j = 0; j < 6; j++) {
311 for (i = 0; i < 3; i++) {
312 ap[i] = s->sloc[i];
313 if (cubeord[dir][j] & 1) ap[i] += s->ss[SU][i];
314 else ap[i] -= s->ss[SU][i];
315 if (cubeord[dir][j] & 2) ap[i] += s->ss[SV][i];
316 else ap[i] -= s->ss[SV][i];
317 if (cubeord[dir][j] & 4) ap[i] += s->ss[SW][i];
318 else ap[i] -= s->ss[SW][i];
319 }
320 viewloc(ip, &ourview, ap); /* find image point */
321 if (ip[2] <= 0.)
322 return(0); /* in front of view */
323 pt[j][0] = ip[0]; pt[j][1] = ip[1];
324 }
325 return(convex_hull(pt, 6, sp)); /* make sure it's convex */
326 }
327
328
329 /* initialize by finding sources smaller than rad */
330 init_drawsources(rad)
331 int rad; /* source sample size */
332 {
333 FLOAT spoly[MAXVERT][2];
334 int nsv;
335 register SPLIST *sp;
336 register int i;
337 /* free old source list if one */
338 for (sp = sphead; sp != NULL; sp = sphead) {
339 sphead = sp->next;
340 free((char *)sp);
341 }
342 /* loop through all sources */
343 for (i = nsources; i--; ) {
344 /* compute image polygon for source */
345 if (!(nsv = sourcepoly(i, spoly)))
346 continue;
347 /* clip to image boundaries */
348 if (!(nsv = box_clip_poly(spoly, nsv, 0., 1., 0., 1., spoly)))
349 continue;
350 /* big enough for standard sampling? */
351 if (minw2(spoly, nsv, ourview.vn2/ourview.hn2) >
352 (double)rad*rad/hres/hres)
353 continue;
354 /* OK, add to our list */
355 spinsert(i, spoly, nsv);
356 }
357 }
358
359 /* add sources smaller than rad to computed subimage */
360 drawsources(pic, zbf, x0, xsiz, y0, ysiz)
361 COLOR *pic[]; /* subimage pixel value array */
362 float *zbf[]; /* subimage distance array (opt.) */
363 int x0, xsiz, y0, ysiz; /* origin and size of subimage */
364 {
365 FLOAT spoly[MAXVERT][2], ppoly[MAXVERT][2];
366 int nsv, npv;
367 int xmin, xmax, ymin, ymax, x, y;
368 FLOAT cxy[2];
369 double pa;
370 RAY sr;
371 register SPLIST *sp;
372 register int i;
373 /* check each source in our list */
374 for (sp = sphead; sp != NULL; sp = sp->next) {
375 /* clip source poly to subimage */
376 nsv = box_clip_poly(sp->vl, sp->nv,
377 (double)x0/hres, (double)(x0+xsiz)/hres,
378 (double)y0/vres, (double)(y0+ysiz)/vres, spoly);
379 if (!nsv)
380 continue;
381 /* find common subimage (BBox) */
382 xmin = x0 + xsiz; xmax = x0;
383 ymin = y0 + ysiz; ymax = y0;
384 for (i = 0; i < nsv; i++) {
385 if ((double)xmin/hres > spoly[i][0])
386 xmin = spoly[i][0]*hres + FTINY;
387 if ((double)xmax/hres < spoly[i][0])
388 xmax = spoly[i][0]*hres - FTINY;
389 if ((double)ymin/vres > spoly[i][1])
390 ymin = spoly[i][1]*vres + FTINY;
391 if ((double)ymax/vres < spoly[i][1])
392 ymax = spoly[i][1]*vres - FTINY;
393 }
394 /* evaluate each pixel in BBox */
395 for (y = ymin; y <= ymax; y++)
396 for (x = xmin; x <= xmax; x++) {
397 /* subarea for pixel */
398 npv = box_clip_poly(spoly, nsv,
399 (double)x/hres, (x+1.)/hres,
400 (double)y/vres, (y+1.)/vres,
401 ppoly);
402 if (!npv)
403 continue; /* no overlap */
404 convex_center(ppoly, npv, cxy);
405 if ((sr.rmax = viewray(sr.rorg,sr.rdir,&ourview,
406 cxy[0],cxy[1])) < -FTINY)
407 continue; /* not in view */
408 if (source[sp->sn].sflags & SSPOT &&
409 spotout(&sr, source[sp->sn].sl.s))
410 continue; /* outside spot */
411 rayorigin(&sr, NULL, SHADOW, 1.0);
412 sr.rsrc = sp->sn;
413 rayvalue(&sr); /* compute value */
414 if (bright(sr.rcol) <= FTINY)
415 continue; /* missed/blocked */
416 /* modify pixel */
417 if (zbf[y-y0] != NULL &&
418 sr.rt < zbf[y-y0][x-x0])
419 zbf[y-y0][x-x0] = sr.rt;
420 pa = poly_area(ppoly, npv);
421 scalecolor(sr.rcol, pa*hres*vres);
422 scalecolor(pic[y-y0][x-x0], (1.-pa*hres*vres));
423 addcolor(pic[y-y0][x-x0], sr.rcol);
424 }
425 }
426 }
